Computer-Tips & Tricks
ms_cs
@ms-cs-Ab8svl โ€ข Oct 27, 2024
Here Post the computer tricks and tips:smile:. This can be any computer short cut keys, and locking mechanisms, software easter eggs, anything related to computers and internet.
  • ms_cs
    @ms-cs-Ab8svl • Jul 2, 2009
    Getting system properties faster : [shortcut key]
    This tweak is for those of you who consider right-clicking on My Computer, and then going down to the properties menu, a bit time consuming. Instead, to bring up the System Properties menu faster, do the following:
    * Hold down the Windows Key on the keyboard, and then press Pause/Break. (WinKey + Pause *
  • Anil Jain
    @CrazyBoy • Jul 2, 2009
    For Task manager:
    CTRL + SHIFT + ESC
    Very Very informative tHread... If we can handle this properly.
    -CB
  • ms_cs
    Thank you CB
    Locking Folders without any third party software
    Consider you want to lock a folder named in your E:\, whose path is E:\.
    Now open the Notepad and type the following
    ren .{21EC2020-3AEA-1069-A2DD-08002B30309D}
    Where is your folder name. Save the text file as loc.bat in the same drive.
    Open another new notepad text file and type the following
    Save the text file as key.bat in the same drive.
    Steps to lock the folder:
    To lock the folder, simply click the loc.bat and it will transform into control panel icon which is inaccessible.
    To unlock the folder click the key.bat file. Thus the folder will be unlocked and the contents are accessible
    PS: This is not worked fine in my system. But My Friend still arguing with me that this trick is working fine for him. So I thought Posting it here will be useful for others.
  • ashutoshglamour
    @ashutoshglamour-YcpJXd • Jul 2, 2009
    window+u(2 times)
    this can be used for shutdown ur computer
  • ashutoshglamour
    window+click on computer icon
    this will fast ur computer.
    @harshad-ukH5ww • Jul 2, 2009
    To Rename the Recycle bin - This is only for fun
    Type regedit in Run Command...
    Then go to :[FONT=Verdana, Arial, Helvetica, sans-serif]HKEY_CLASSES_ROOT/CLSID/{645FF040-5081-101B-9F08-00AA002F954E} and Change the Name.
    [/FONT]
  • RajdeepCE
    @rajdeepce-7UdrG8 • Jul 2, 2009
    Change the Default Location for Installing Programs
    XP uses the C:/Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/or directory by using a Registry hack. Run the
    Registry Editor and go to
    HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion
    Look for the value named ProgramFilesDir. By default, the value will be C:/Program Files. Edit the value to any valid drive
    or folder; XP will use that new location as the default installation directory for new programs.
  • shalini_goel14
    @shalini-goel14-ASmC2J • Jul 2, 2009
    Short cut for opening "Add or Remove Programs" window is
    1. Open Run
    2. Type appwiz.cpl
  • inbapuvi
    @inbapuvi-ol4SBc • Jul 3, 2009
    Alt+ctrl+delete
    This is for task manager.
    Alt+tab
    This is for easy way of select next minimize window
  • ShrinkDWorld
    @shrinkdworld-WWdBBc • Jul 3, 2009
    keep it up we creat the good collection of shortcurs!!!
  • safwan
    @safwan-NH7W5Y • Jul 4, 2009
    Use CTRL+C to Copy and CTRL+V for past
    simple that everyknows (haha!!)
  • ms_cs
    @ms-cs-Ab8svl • Jul 4, 2009
    How to Turn Your Num Lock On Forever?
    You can set your Num Lock to stay on by default when you logon your system.
    There are two different techniques to set Num Lock stay on by default.
    If you can use Registry Editor correctly then Click on start button and type Regedt32.exe in Run command. Here Navigate to HKEY_USERS\.Default\Control Panel\Keyboard and change the value for InitialKeyboardIndicators from 0 to 2.
    You can do same by configuring the script to change the NUM LOCK state. Click Start button and then open Notepad. Copy the giving code and paste in Notepad.
    set WshShell = CreateObject("WScript.Shell")
    WshShell.SendKeys "{NUMLOCK}"
    Now save this file with name "num.vbs" must including the quotes. At the end copy this file to user startup folder. The path for this folder is Documents and Settings\All Users\Start Menu\Programs\Startup.
    Now restart the computer. Num Lock should come on and stay on.
  • harshal000
    @harshal000-QpyAro • Jul 4, 2009
    ctrl+D gives u the desktop
    try it .
    @harshad-ukH5ww • Jul 4, 2009
    harshal000ctrl+D gives u the desktop
    try it .
    Its WINDOW+D not Ctr+D
  • shalini_goel14
    @shalini-goel14-ASmC2J • Jul 4, 2009
    WINDOWS + E - Opens Windows Explorer window.
  • Anil Jain
    @CrazyBoy • Jul 4, 2009
    Alt+ctrl+delete
    This opens the dialog from where we can open task Manager. For direct Task Manager shortcut is SHIFT + CTRL + ESc
    How to do this... couldn't get you?
    -CB
  • safwan
    @safwan-NH7W5Y • Jul 5, 2009
    go to start button and go to run type cmd and it will give you comand dos.
  • vincent_lwh
    @vincent-lwh-iugZqh • Jul 5, 2009
    ctrl+w
    close a window or tab of a browser. =)
  • Radhika Deshpande
    @radhika-o4Adk0 • Jul 5, 2009
    Useful Run commands:
    To Accessโ€ฆ.
    Run Commandโ€‹Accessibility Controls
    access.cpl
    Accessibility Wizard
    accwiz
    Add Hardware Wizard
    hdwwiz.cpl
    Add/Remove Programs
    appwiz.cpl
    Administrative Tools
    control admintools
    Adobe Acrobat (if installed)
    acrobat
    Adobe Designer (if installed)
    acrodist
    Adobe Distiller (if installed)
    acrodist
    Adobe ImageReady (if installed)
    imageready
    Adobe Photoshop (if installed)
    photoshop
    Automatic Updates
    wuaucpl.cpl
    Bluetooth Transfer Wizard
    fsquirt
    Calculator
    calc
    Certificate Manager
    certmgr.msc
    Character Map
    charmap
    Check Disk Utility
    chkdsk
    Clipboard Viewer
    clipbrd
    Command Prompt
    cmd
    Component Services
    dcomcnfg
    Computer Management
    compmgmt.msc
    Control Panel
    control
    Date and Time Properties
    timedate.cpl
    DDE Shares
    ddeshare
    Device Manager
    devmgmt.msc
    Direct X Control Panel (If Installed)*
    directx.cpl
    Direct X Troubleshooter
    dxdiag
    Disk Cleanup Utility
    cleanmgr
    Disk Defragment
    dfrg.msc
    Disk Management
    diskmgmt.msc
    Disk Partition Manager
    diskpart
    Display Properties
    control desktop
    Display Properties
    desk.cpl
    Display Properties (w/Appearance Tab Preselected)
    control color
    Dr. Watson System Troubleshooting Utility
    drwtsn32
    Driver Verifier Utility
    verifier
    Event Viewer
    eventvwr.msc
    Files and Settings Transfer Tool
    migwiz
    File Signature Verification Tool
    sigverif
    Findfast
    findfast.cpl
    Firefox (if installed)
    firefox
    Folders Properties
    control folders
    Fonts
    control fonts
    Fonts Folder
    fonts
    Free Cell Card Game
    freecell
    Game Controllers
    joy.cpl
    Group Policy Editor (XP Prof)
    gpedit.msc
    Hearts Card Game
    mshearts
    Help and Support
    helpctr
    HyperTerminal
    hypertrm
    Iexpress Wizard
    iexpress
    Indexing Service
    ciadv.msc
    Internet Connection Wizard
    icwconn1
    Internet Explorer
    iexplore
    Internet Properties
    inetcpl.cpl
    Internet Setup Wizard
    inetwiz
    IP Configuration (Display Connection Configuration)
    ipconfig /all
    IP Configuration (Display DNS Cache Contents)
    ipconfig /displaydns
    IP Configuration (Delete DNS Cache Contents)
    ipconfig /flushdns
    IP Configuration (Release All Connections)
    ipconfig /release
    IP Configuration (Renew All Connections)
    ipconfig /renew
    IP Configuration (Refreshes DHCP & Re-Registers DNS)
    ipconfig /registerdns
    IP Configuration (Display DHCP Class ID)
    ipconfig /showclassid
    IP Configuration (Modifies DHCP Class ID)
    ipconfig /setclassid
    Keyboard Properties
    control keyboard
    Local Security Settings
    secpol.msc
    Local Users and Groups
    lusrmgr.msc
    Logs You Out Of Windows
    logoff
    Malicious Software Removal Tool
    mrt
    Microsoft Access (if installed)
    access.cpl
    Microsoft Chat
    winchat
    Microsoft Excel (if installed)
    excel
    Microsoft Frontpage (if installed)
    frontpg
    Microsoft Movie Maker
    moviemk
    Microsoft Paint
    mspaint
    Microsoft Powerpoint (if installed)
    powerpnt
    Microsoft Word (if installed)
    winword
    Microsoft Syncronization Tool
    mobsync
    Mouse Properties
    control mouse
    Mouse Properties
    main.cpl
    Nero (if installed)
    nero
    Netmeeting
    conf
    Network Connections
    control netconnections
    Network Connections
    ncpa.cpl
    Network Setup Wizard
    netsetup.cpl
    Notepad
    notepad
    Object Packager
    packager
    ODBC Data Source Administrator
    odbccp32.cpl
    On Screen Keyboard
    osk
    Opens AC3 Filter (If Installed)
    ac3filter.cpl
    Outlook Express
    msimn
    Paint
    pbrush
    Password Properties
    password.cpl
    Performance Monitor
    perfmon.msc
    Performance Monitor
    perfmon
    Phone and Modem Options
    telephon.cpl
    Phone Dialer
    dialer
    Pinball Game
    pinball
    Power Configuration
    powercfg.cpl
    Printers and Faxes
    control printers
    Printers Folder
    printers
    Private Character Editor
    eudcedit
    Quicktime (If Installed)
    QuickTime.cpl
    Quicktime Player (if installed)
    quicktimeplayer
    Real Player (if installed)
    realplay
    Regional Settings
    intl.cpl
    Registry Editor
    regedit
    Registry Editor
    regedit32
    Remote Access Phonebook
    rasphone
    Remote Desktop
    mstsc
    Removable Storage
    ntmsmgr.msc
    Removable Storage Operator Requests
    ntmsoprq.msc
    Resultant Set of Policy (XP Prof)
    rsop.msc
    Scanners and Cameras
    sticpl.cpl
    Scheduled Tasks
    control schedtasks
    Security Center
    wscui.cpl
    Services
    services.msc
    Shared Folders
    fsmgmt.msc
    Shuts Down Windows
    shutdown
    Sounds and Audio
    mmsys.cpl
    Spider Solitare Card Game
    spider
    SQL Client Configuration
    cliconfg
    System Configuration Editor
    sysedit
    System Configuration Utility
    msconfig
    System Information
    msinfo32
    System Properties
    sysdm.cpl
    Task Manager
    taskmgr
    TCP Tester
    tcptest
    Telnet Client
    telnet
    Tweak UI (if installed)
    tweakui
    User Account Management
    nusrmgr.cpl
    Utility Manager
    utilman
    Windows Address Book
    wab
    Windows Address Book Import Utility
    wabmig
    Windows Backup Utility (if installed)
    ntbackup
    Windows Explorer
    explorer
    Windows Firewall
    firewall.cpl
    Windows Magnifier
    magnify
    Windows Management Infrastructure
    wmimgmt.msc
    Windows Media Player
    wmplayer
    Windows Messenger
    msmsgs
    Windows Picture Import Wizard (need camera connected)
    wiaacmgr
    Windows System Security Tool
    syskey
    Windows Update Launches
    wupdmgr
    Windows Version (to show which version of windows)
    winver
    Windows XP Tour Wizard
    tourstart
    Wordpad
    write
  • Anil Jain
    @CrazyBoy • Jul 5, 2009
    Now last post makes this thread an AMAZING Collection of short cut keys.
    Request to Mods to please make this thread as an sticky so that we will not miss this thread; otherwise this will surely go in oblivion.
    -CB
  • silverscorpion
    @silverscorpion-iJKtdQ • Jul 6, 2009
    wow, bring it slowly fellas!!
    That was amazing! I didn't know so much even existed in windows!
    Rock on!! ๐Ÿ˜€๐Ÿ˜€
  • ms_cs
    @ms-cs-Ab8svl • Jul 6, 2009
    to know the TCP/IP network configuration values, the command "ipconfig/all" can be used
  • RajdeepCE
    @rajdeepce-7UdrG8 • Jul 6, 2009
    Start->run->
    type msconfig, it will bring a control pannel. Fron this you will able to set preferences for startup.ini, boot.ini & some others.
    Hope this isnt repeated.
  • HEART-HACKER
    @heart-hacker-nZz25T • Jul 7, 2009
    crazyboyFor Task manager:
    CTRL + SHIFT + ESC
    -CB
    Its working like alt + tab. ๐Ÿ˜•
  • karcki
    @karcki-7VMqzL • Jul 8, 2009
    ๐ŸŽ‰
    ms_csHere Post the computer tricks and tips:smile:. This can be any computer short cut keys, and locking mechanisms, software easter eggs, anything related to computers and internet.
  • jhbalaji
    @jhbalaji-AH60JJ • Jul 25, 2009
    Just have a look here
    Ton's of Info's for you Guys...
  • ms_cs
    @ms-cs-Ab8svl • Jul 26, 2009
    jhbalajiJust have a look here
    Nice site balaji
  • Aashish Joshi
    @aashish-VrevFC • Jul 26, 2009
    HEART-HACKERIts working like alt + tab. ๐Ÿ˜•
    ctrl + shift + esc does function like ctrl+alt+del
    The key combo you are referring to is alt+shift+esc or alt+esc
  • Ashraf HZ
    @Ash • Jul 26, 2009
    Great contribution guys. Thread is stickied as requested ๐Ÿ˜€
  • Anil Jain
    @CrazyBoy • Jul 26, 2009
    mad_scientistctrl + shift + esc does function like ctrl+alt+del
    Have you guyz tried this (ctrl + shift + esc) or... just talking in air
    -CB
  • praveendarapu
    @praveendarapu-mkgsEc • Aug 4, 2009
    windows+L to log off
  • Aashish Joshi
    @aashish-VrevFC • Aug 4, 2009
    crazyboyHave you guyz tried this (ctrl + shift + esc) or... just talking in air
    -CB
    I have tried this, and it works like Ctrl+Alt+Del, i.e. it brings up the task manager!!
  • Mangesh6688
    @mangesh6688-2pfEFZ • Aug 4, 2009
    Display legal notice on startup:
    Wanna tell your friends about the do's and dont's in your computer when they login in your absence. Well you can do it pretty easily by displaying a legal notice at system start up.
    REGEDIT
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system]
    "legalnoticecaption"="enter your notice caption"
    "legalnoticetext"="enter your legal notice text"
  • saurabh2486
    @saurabh2486-Tr6NOC • Aug 5, 2009
    to access services in the run dialog box type "services.msc" without quotes
    and for directx type "dxdiag" without quotes lol
  • saurabh2486
    for services type "services.msc" in run dialog box widout quotes and for directx type "dxdiag" widout quotes
  • saurabh2486
    and for changing passwords u can type control userpasswords2 in windows xp
  • TARANJEET SINGH
    @taranjeet-singh-mdq4QW • Aug 6, 2009
    many crazy items to download and use
    <a href="https://www.technobuzz.net/" target="_blank" rel="nofollow noopener noreferrer">TechnoBuzz | How to Android Guides, Tips</a>
  • shashank734
    @shashank734-jxXXKs • Aug 6, 2009
    Best tips forever
    Here we will share most of th latest tips.......
  • shashank734
    Make your folders invicible
    1)Right Click on the desktop.Make a new folder
    2)Now rename the folder with a space(U have to hold ALT key and type 0160).
    3)Now u have a folder with out a name.
    4)Right click on the folder>properties>customize. Click on change icon.
    5)Scroll a bit, u should find some empty spaces, Click on any one of them.
    click ok
  • shashank734
    Turn Off Autoplay for Program CDs
    How can you stop Windows XP from launching program CDs?
    ยท Click Start, click Run, type GPEDIT.MSC to open Group Policy in the Microsoft
    Management Console.
    ยท Double-click Computer Configuration, double-click Administrative templates,
    double-click System, and then click Turn off autoplay.
    ยท The instructions on your screen describe how to configure this setting. Click
    Properties to display the setting dialog.
    ยท Click Enabled, and choose CD-ROM drives, then click OK, to stop CD autoplay.
    This setting does not prevent Autoplay for music CDs.
  • shashank734
    change fat -> ntfs
    To change ur File system from command prompt
    type: convert c:/fs:ntfs(ex:'c' is the drive letter)
  • shashank734
    Ipv6 installation for windows xp
    This protocol is distined to replace the Internet Protocal Version 4 used by Internet Explorer it uses hexadecimal ip addresses instead of decimal example (decimal ip 62.98.231.67) (hexadecimal IP 2001:6b8:0:400::70c)
    To install To install the IPv6 Protocol for Windows XP:
    Log on to the computer running Windows XP with a user account that has local administrator privileges. Open a command prompt. From the Windows XP desktop, click Start, point to Programs, point to Accessories, and then click Command Prompt. At the command prompt, type: ipv6 install
    For more information on IPv6, visit the site below:
    CODEhttps://www.microsoft.com/windowsxp/pro/techinfo/administration/ipv6/default.asp
  • shashank734
    Changing the Location of Special Folders
    You can modify the registry to change the location of special folders like:
    • My Documents
    • Favorites
    • My Pictures
    • Personal
    1. Start Regedit
    2. Go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    3. Double click on any locations you want to change and alter the path
    4. Logoff or restart for the changes to go into effect
  • shashank734
    Eliminating the Right Click on the Desktop
    To eliminate the right click on the desktop:
    1. Start Regedit
    2. Go to HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ Explorer
    3. Add a DWORD and give it a name of NoViewContextMenu
    4. Give it a value of 1
    5. Reboot
  • shashank734
    Do you know you can have Virtual Desktops (like in Linux) with PowerToys ?
    If you have powertoys installed on Windows XP Its available for free at Microsoft download webpage. It is very easy to enable Microsoft Virtual Desktop Feature. Simply right click on the Start Panel Bar also called TaskBar, Click on Tool Bar and select Desktop manager.
    You would see a set of 5 icons placed on the right portion of the TAskBar. Click on number 1 to 4 to go to any of the desktops. Now you have have four different Active Desktops.
    IMPORTANT NOTE: You may see a little degradation in performance.
  • shashank734
    Hide ur folders.. never known trick !!!!!!!!!! Disguise them to "Recycle Bin"
    Rename any folder with extension {645FF040-5081-101B-9F08-00AA002F954E}
    eg,
    if u've a folder games
    press F2,
    then type, "games.{645FF040-5081-101B-9F08-00AA002F954E}"
    c the magic....
    then 2 get to original form,
    remove the extension using
    "ren games.{645FF040-5081-101B-9F08-00AA002F954E} games" in dos or as a bat file
    n u are done..
  • shashank734
    Speed up ur acrobat reader (almost like notepad)
    Do u get irritated when acrobat reader takes 5/10 seconds to load when you want to open a pdf document. There is a way to speed up the loading.
    1. Go to the installation folder of acrobat reader
    (C:\program files\adobe\acrobat\reader\.. whatever)
    2. Move all the files and folders from the "plugins" directory to the "Optional" directory. (I repeat.. cut and paste the files NOT copy & paste).
    Also make sure that acrobat reader is not open else it will lock the files and not allow you to move the files).
    Now your acrobat reader will load very fast
    and almost as good as notepad..
  • shashank734
    Display message on startup.
    Start regedit, if you are unfamiliar with regedit please see our FAQ.
    Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    Modify the key legalnoticecaption with what you want to name the window.
    Modify the key legalnoticetext with what you want the window to say. Restart
  • shashank734
    Re: Best tips forever
    Hey just share here new tips and if u wants more just response it....
    @thebigk • Aug 6, 2009
    Threads merged.
