Mechanical Engineer mini project ideas
mechanical24
@mechanical24-blieTt โ€ข Oct 26, 2024
Automatic fuel valve - Turn it automatically via remote control.
Prevent robbery of vehicle via anti-robbery mechanism
Auto-piloting of the aircraft and related control systems.
Design of air-cooling systems using AutoCAD
Air-Engine - Mechanical Engineering Final Year Project
Magnetic Bearing control systems
Jet Cutting Tool - Analysis & Study
Orthogonal metal sheet cutting system design and development.
Flywheel energy conservation and utilisation study.
Forklifter - using R/C electronics systems
Laser guided robotic arm
Four Bar Linkage
Hydrogen Fuel Cell Study
Weapon Technology - Use of mechanical weapons.
CNG conversion kit of automobiles
Remote Steering Systems for the mega-Ships
Hydro-Jack for large sized cranes
RT-Sequencing Control & Analysis
Radial Piston mechanism study and analysis
Plama welding technology and its advantages
Non-Conventional sources of energy
  • jaisam
    @jaisam-ens2HQ • Feb 1, 2008
    ๐Ÿ˜i need some topics for mini project in fabrication field,
  • TheBugInYou
    @thebuginyou-wQQijE • Feb 3, 2008
    Nice...
    First..
    Mech 24...
    niceman...
    Already ou are a Mechanical Engineer......
    Still you are looking for projects...
    I thinkyou might be in a confusionto select he suitable one..
    If you are intrested in Thermal then go for study of Internal combustion engines..(Live like comparing the differences between CBZ and CBZ-xtr) or somethings link Air Coompressorswih Single and Multi Cylinder's ...
    In the above two studys your report must contain thefollowing:
    1) What are the major Diff
    2) Why did he made it so...
    3) wht are the advantages and dis-adv and whatsthe response inresults in
    practice..
    4) drawbacs you found still to be made in the new model
    5) your suggestions...
    This is how you can make a perfect Live Project with Less Cost and More and more knowledge hunt.
    If you are doing so...
    i guess you might be refering a minimum of 20 books by the end of your project.
    if you want ay mini proks from other feilds do message...
  • TheBugInYou
    Dear Fabricator......
    can you please specify...
    either its plastic or metal or sheet or wire or cloth....
  • satheesh27887
    @satheesh27887-baQnlX • Feb 12, 2008
    i'm fabricating with metal only
    can u give some ideas regarding mini projects in mechanical field.....
  • vinod sampalli
    @vinod-sampalli-HI0Fsc • Feb 17, 2008
    please suggest topics for mechanical projects,
  • tino_onit
    @tino-onit-5zx8ek • Feb 22, 2008
    hi.
    am a mech enggg student.. please suggest some topics for mini project
  • krish123
    @krish123-jYSMxb • Feb 26, 2008
    hai, can u plz provide some mini project ideas,,,, some working models
  • jerincboben
    @jerincboben-Ua3VGu • Mar 11, 2008
    heyy CEans
    I am a third year mechanical eng. student. Please help me to find a simple miniproject and I hav not much idea about it,, as I am studying in a new college.
  • vijay gosain
    @vijay-gosain-VoT4mS • Mar 15, 2008
    mechanical24hi i m a mechanical engg,
    want projects mean mini project.
    i m a me student , can u plz provide some mini project ideas,,,, some working models
  • satheesh27887
    @satheesh27887-baQnlX • Jul 25, 2008
    TheBugInYouDear Fabricator......
    hi i'm doing finalyear mechanical engineering...
    i'm searching for a good project.....
    plz.. give me some ideas.....
  • sonasathish
    @sonasathish-ASg8rC • Jul 25, 2008
    krish123hai, can u plz provide some mini project ideas,,,, some working models
    To start with u can do projects in production! Like we did! Especially in masss production and automation which will reduce the production cost as well as the labor skills need! If u want more suggestions then message me!
  • shahadat kabir
    @shahadat-kabir-s12w21 • Jul 27, 2008
    hi
    i am a third year mechanical engineering student. i want some projects that are simple . please help me..
  • yudi
    @yudi-9hjHvc • Jul 28, 2008
    hi shahadat & others
    if you want some simple project then get a water cooler & submit it as your project.....
    or else you can try some project from Automobile domain like
    --fuel indicator
    --braking systems
    --spart distributor
    --like other utilities.
  • sexy
    @sexy-9brQhD • Jul 29, 2008
    hello gyes
  • abhishek kumar
    @abhishek-kumar-0eGyc8 • Aug 2, 2008
    hi my self abhishek kumar can u give some idea abt mini project in mechanical field such as
    heat recovery in ic engine
    solar pond
    how to reduce noise and NOx formation
  • yatendra
    @yatendra-uMvcq7 • Aug 10, 2008
    ๐Ÿ˜hello friends, i need some topics for mini project in mechanical engineering field. i am working on project uni power transmission on bicycle.can tell me it is practically possible...
  • kishorekgupta
    @kishorekgupta-9m8FDp • Aug 26, 2008
    i have done my min project on autocollimator to check the straightness of a given surface plate.
  • kishorekgupta
    i have done my min project on autocollimator to check the straightness of a given surface plate.๐Ÿ˜
  • inforaushan
    @inforaushan-U3UQAu • Aug 26, 2008
    hi..
    i m in mechanical engg. 3rd year
    i m very much intrested in designing ...
    do u have any project related to designing ....
  • puneet_ngl15
    @puneet-ngl15-F6l6Gl • Sep 4, 2008
    hi i am final year student thinking about project to run a engine with water
    @thebigk • Sep 4, 2008
    Hello,
    Good to know that. Best of luck!
  • tikkucit
    @tikkucit-UqXjOn • Sep 10, 2008
    hello
    i want some mini project ideas in mechanical/
  • rupeshezhu
    @rupeshezhu-VPxJvE • Sep 26, 2008
    hiiiiiiiiiiiiiiiii I would like to request for some miniproject ideas
  • kishor1990
    @kishor1990-jT9ert • Oct 1, 2008
    hi i m mechanical student of be 3rd year & want project idea
  • Ranjith Babu
    @ranjith-babu-pJENJM • Nov 6, 2008
    Mechanical Engineer mini project, ideas
    Hi, am Ranjith babu now undergoing 7sem, we are a 4members team, could u help me in giving tips on projects such as Shall we do the projects on our ideas [individual] or as a project trainee by joining a company
  • Differential
    @differential-0aMwAJ • Nov 6, 2008
    Ranjith Babu ! Welcome to the forum !
    Working on our own idea is alwasy good than working on someone else's idea ! If you couldn't find any idea you can approach an industry to ask if they have some requirement which will become as your project.
  • mechsathya
    @mechsathya-kaAsGe • Nov 30, 2008
    yes i want
  • mechsathya
    i need some mini fabrication project titles in mechanical engineering
  • raghunathareddy
    @raghunathareddy-RZLwcO • Dec 2, 2008
    hai i am raghu can u give me some mini project lists
  • Rohit1990
    @rohit1990-UkhQJe • Jan 7, 2009
    hi i m a mechinical engg student need a help frm u for my mini project....
    @thebigk • Jan 7, 2009
    Look here -> #-Link-Snipped-#
  • apsoni123
    @apsoni123-6tEYlZ • Jan 8, 2009
    Hi Engineers. I am a student of third yr mechanical engineering. I have a 4 month semester project. I need suggestions for the topic. Some of the projects done in previous year were
    Redesign of brake assembly of Formula SAE car
    Hydraulic car lift
    โ€‹Lift for small recreational vehicles (โ€˜Motor cycle jackโ€™)
    Stair climbing hand cartโ€‹Wheel chair accessible transfer seat base
    โ€‹Paper towel dispenserโ€‹Automatic labeling system
  • kingbala
    @kingbala-g9rMaw • Jan 10, 2009
    im doing 3 yrs mechanical engg, i want some idea to do project
  • nijas33
    @nijas33-PpIqdf • Jan 12, 2009
    hey can u give me some ideas about robotics
  • R3D D3V!L
    @r3d-d3vl-u0fZau • Mar 26, 2009
    go for a vtol r quad rotor r unmaned aerial vechile if ur intrsted in aerodynamics
  • rajith kumar
    @rajith-kumar-a4o3lw • Apr 1, 2009
    presently m doin ma 3rd yr engineering......m very much interested in doing mechanical projects which s based on subjects like kinematics of machines ,dom etc..can anyone tel me abt this.....plz
  • Differential
    @differential-0aMwAJ • Apr 1, 2009
    Hi and welcome to the forum ! Please search forum for project ideas. You will get plenty of them. Choose one and then we can discuss on it here!
    Best ! ๐Ÿ˜€
  • praneshb
    @praneshb-HKbCfU • Jul 16, 2009
    i am a diploma stud in MECH ENGG.. i need some ideas for Miniproject...
  • sachinphule333
    @sachinphule333-6fcKEC • Aug 8, 2009
    ๐Ÿ˜want projects mean mini project.
    plzzzzzz help me
  • jhbalaji
    @jhbalaji-AH60JJ • Aug 8, 2009
    jaisam๐Ÿ˜i need some topics for mini project in fabrication field,
    Have a look here guys
  • remshad medappil
    @remshad-SleoG8 • Aug 20, 2009
    Try coconut husk #-Link-Snipped-# machine
  • sunsanj
    @sunsanj-N9TtMu • Aug 24, 2009
    ๐Ÿ˜
    vinod sampalliplease suggest topics for mechanical projects,
    hi i also need some ideas in automobile regarding engine for degree project
  • remshad medappil
    @remshad-SleoG8 • Aug 25, 2009
    1.6strok engine
    2.High Performense aero dynamic design
  • Er saumil
    @er-saumil-7JeaOO • Aug 25, 2009
    hi i m saumil i am in diploma in third year, i want some topics of seminar and projects,so you please help me......
  • kirubhamech
    @kirubhamech-DoYV0N • Sep 9, 2009
    plz give any mini project idea
  • amitmishraer
    @amitmishraer-6y2Xj1 • Feb 16, 2010
    I want some ideas on minor project & their working related to mechanical engg.๐Ÿ˜”
  • ashish28nov
    @ashish28nov-z246G0 • Feb 27, 2010
    free generation of electricity
    i am working on a mini project:free generation of electricity`
    requirement:1 CD,10 small magnets,1 large magnet,a dynamo(which can light up an LED) and a LED.
    working:attach the CD with dynamo,now stick the 10 small magnets around the CD(in circular manner).now connect LED with the dynamo.finally bring the large magnet near the CD having small magnets in such a way that the CD starts rotating due to repulsion force.
    problem:i tried it,but i am unable to make the CD rotating.i dont know why?
    it may be due to distance between each small magnet,or may be due to the diffrence in distance of magnet through the center of disc or may be the poles of the magnets are not matching..
    i need some suggestions to solve it..?
  • ashishgupta652
    @ashishgupta652-nzpKVu • Feb 28, 2010
    hi ce's m 3rd yr mech student ,.,can u suggest name of certain projects in which i can work upon.
  • ashishgupta652
    @ashish_28nov
    i think a rotor must also be used to make the roation ease,
  • kittus347
    @kittus347-nXk8Oa • Apr 9, 2010
    yudihi shahadat & others
    --fuel indicator
    --braking systems
    --spart distributor
    hi im kittu's frm suryapet im mech 3rd i want full information on fuel indicator can u give me that information
