@harshad-ukH5ww • Jun 29, 2013
If you are looking for ready circuit diagram then please don't waste your time. Why not start working on this idea and we can collect circuit diagram for different parts of this project and then we need to combine them all as per your application.dheekotianhello,
could u please provide me the circuit diagram of a wheelchiar controlled using the eye movements. i would also want to include a system which enables the wheelchair to follow the person using his location through bluetooth. could anyone help me out with this?
Let's start.
Here is the circuit diagram for Motor controlling which you can use for Chair movement.
@harshad-ukH5ww • Jun 30, 2013
Regarding the part in which you want your wheelchair to follow particular person.
Here is one Bluetooth Module #-Link-Snipped-# that we can use with wheelchair which receives signal from person's mobile and based on that it will give command to wheelchair to follow. -
@dheekotian-bWKBhY • Jul 8, 2013
hello sir!!!
thanks a lot sir!!! 😀
could you recommend me a motor for the wheelchair movement??
can i go with the wiper motors? -
@harshad-ukH5ww • Jul 8, 2013
Well that is one of the important parameter. We have to choose motors which is able to run with say 100 kg load and I think we need such motor which has good torque. So say Motor with less RPM is fine.dheekotianhello sir!!!
Try to research which motor is good in these parameter DC motor, Stepper motor or Servo motor. -
@Ash • Jul 8, 2013
I believe the "following eye movements" part is more of a software implementation than a circuit one. Have you researched on possible solutions on this as well? -
@dheekotian-bWKBhY • Jul 9, 2013
yes sir. we have decided to use labview for the implementation. -
@harshad-ukH5ww • Jul 9, 2013
So you need to attach one Laptop with wheelchair right? What's your plan for Camera mounting?dheekotianyes sir. we have decided to use labview for the implementation. -
need some structure to support from the back. which is flexible...
a small rod kind of structure, which is flexible. which can be moved up and down. i cant recall its name. it can be found in the reverse camera monitor mounting -
Great ! 👍dheekotianneed some structure to support from the back. which is flexible...
I suggest you to draw one sketch about the mechanism and post it here so you will get some suggestion from fellow CEans.
