Mesh Gear Boxes Running At 0 rpm & 3000 rpm
AHMED ABDELAZIZ
AHMED ABDELAZIZ
@ahmed-abdelaziz-byqgwj Oct 24, 2024
can we mesh gear at zero rpm rotating with another gear rotating at 3000 rpm
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Jan 4, 2013
    Be logical buddy one is static and other is at a higher speed when coupled with rigid couplings Both the gears are doomed
  • zaveri
    zaveri
    @zaveri-5TD6Sk Jan 5, 2013
    a static gear however cannot be meshed with a rotating gear.
    in fact even in the case of meshing two gears rotating at different speeds, synchronization of speeds is done before meshing. (bringing the gears to rotate at the same speed).
