help needed in java coding
ankititstime
@ankititstime-xtVTQF Oct 26, 2024
can anyone help me in java coding
i am trying to building a frame which will ask 4 username and psw and if they mathches by looking in database ,it will automatically show new frame which shows account info of login user by rerieving info from another table
  • hbk
    hbk
    @hbk-UY6MQq Jun 17, 2008
    u talking abt JDBC??
  • elric
    @elric-7vzoqS Jun 17, 2008
    You could be more specific, like in which part you need help? Database connectivity or GUI design?
  • jaichan
    @jaichan-vZRNGJ Jul 18, 2008
    Hi friend first of all u understand the database connectivity
  • Neha
    @neha-3vibjn Jul 23, 2008
    hi!
    This is all related to database connectivity.
    You'll have to maintain a database for the same recording the logins and the passwords etc and connect it to your file.
  • niraj.kumar
    @nirajkumar-6nokRG Jul 24, 2008
    You can follow this step
    1. You need to create a table to store this information
    2. Learn JDBC its easy ... make the connection.. u will find lots of tutorial on this .
    3. Make a simple UI is java swing ....
    thats it ... if u need further then reply ... i mean wat kind of problem u r facing ..... paste the error msg here ...(if u have any)
  • komputergeek
    @komputergeek-Yf5hJ4 Oct 21, 2008
    These are two classes from my project:
    Login.java :
    import javax.swing.*;
    import java.awt.event.*;
    import java.sql.*;
    public class Login
        static JFrame f;
        static JPanel p1;
        static JPanel p2;
        static JPanel p3;
        static JLabel lUserName;
        static JTextField tUserName;
        static JLabel lPassword;
        static JPasswordField pPassword;
        static JButton bLogin;
        static JButton bCancel;
        public static void showLoginWindow ()
            f = new JFrame ("Login");
            p1 = new JPanel ();
            p2 = new JPanel ();
            p3 = new JPanel ();
            lUserName = new JLabel ("User Name : ");
            tUserName = new JTextField (20);
            lPassword = new JLabel ("Password  :  ");
            pPassword = new JPasswordField (20);
            bLogin = new JButton ("Login");
            bLogin.setToolTipText ("Click here to Login");
            bLogin.setMnemonic('L');
            bLogin.addActionListener (new ActionListener ()
                public void actionPerformed (ActionEvent e)
                    try
                        Connection con = null;
                        Statement stmt;
                        ResultSet rs;
                           boolean flag=false;
                        con = DBConnect.getCon ();
                        stmt = con.createStatement ();
                        rs = stmt.executeQuery ("Select * from USERS  where USERNAME='" + tUserName.getText () + "' and PASSWORD = '" + pPassword.getText() + "'" );
                           while(rs.next())
                               if(rs.getString("USERNAME").equals(tUserName.getText()) &&   rs.getString("PASSWORD").equals(pPassword.getText()))
                                   flag=true;
                           if(flag==false)
                               Result_AnalysisFrame frame= new Result_AnalysisFrame();
                            frame.setVisible(true);
                            f.hide();
                           else
                               JOptionPane.showMessageDialog(null,"Login Failed !!!","Login Fail",JOptionPane.WARNING_MESSAGE);
                    catch (Exception ex)
                        JOptionPane.showMessageDialog (null, ex, "Error", JOptionPane.INFORMATION_MESSAGE);
            bCancel = new JButton ("Cancel");
            bCancel.setToolTipText ("Click here to Exit");
            bCancel.setMnemonic('C');
            bCancel.addActionListener (new ActionListener ()
                    System.exit (0);
            p1.add (lUserName);
            p1.add (tUserName);
            p2.add (lPassword);
            p2.add (pPassword);
            p3.add (bLogin);
            p3.add (bCancel);
            Box bx1 = Box.createVerticalBox ();
            bx1.add (p1);
            bx1.add (p2);
            bx1.add (p3);
            f.getContentPane ().add (bx1);
            f.setVisible (true);
            f.setDefaultCloseOperation (JFrame.EXIT_ON_CLOSE);
            f.setLocation (380, 280);
            f.pack ();
            f.setResizable (false);
    DBConnect.java :
    import java.sql.*;
    import oracle.jdbc.*;
    public class DBConnect
        public static Connection getCon ()
            String url = "jdbc:odbc:RA2";
            try
                Class.forName ("sun.jdbc.odbc.JdbcOdbcDriver");
                con = DriverManager.getConnection (url, "RA", "RA");
            catch (Exception e)
                JOptionPane.showMessageDialog (null, e, "Error", JOptionPane.INFORMATION_MESSAGE);
            return con;
  • xero
    @xero-28ehVN Oct 21, 2008
    the info is not sufficient to rectify. Looking at code(the jdbc ones) it seems more like a driver issue. But before proceeding further, i think you should first go thru the basics of jdbc and the types of drivers available with databases.
    I'll just give you intro with the 4 types of drivers ->
    1. JDBC ODBC driver - this is the driver you have used in your program. This driver converts the jdbc calls into odbc acting as a bridge. So make sure have configured the odbc correctly. eg if you are using oracle as db so you have to configure the odbc for oracle. (for more reference, google 😁)
    2. Native-API partly Java technology-enabled driver - in this the java converts the jdbc calls into db api calls.
    3. Net-protocol fully Java technology-enabled driver - in this JDBC API calls is translated into a DBMS-independent net protocol which is then translated to a DBMS protocol by a server
    4. Native-protocol fully Java technology-enabled driver - converts JDBC technology calls into the network protocol used by DBMSs directly. This is a pure java based driver !
    The above was just informative, don't need to think deep into it. It won't harm to know.
    So the take-away is that your code is using the driver of type 1 so first you must check the configuration for Db specific odbc configuration.
