Comparing two AC Currents and using the output to drive a alarm circuit.
neo23
@neo23-KisbGm • Oct 26, 2024
I want to compare two AC currents . And if the difference between the two exceeds a certain limit it should give a output signal , to drive an alarm circuit. I can make the latter i.e the alarm circuit . But i do not know how to compare the AC Currents. Any ideas?
Note - The currents to be compared are as high as 120 Ampere.
  • aarthivg
    @aarthivg-HH344f • Feb 1, 2012
    consider two currents i1 and i2. these currents can be given as input to a micro controller, difference in current can be found based on the coding. if the difference in current exceeds a certain value, it will drive the relay and energize the close coil of circuit breaker in order to give supply to the alarm circuit.
    @ramani-VR4O43 • Feb 1, 2012
    Try using two current transformers and compare the outputs.
  • aarthivg
    the secondary of current transformers is generally 1 amps or 5 amps, then we need a booster to boost the current rating.
  • neo23
    neo23 OP
    @neo23-KisbGm • Feb 1, 2012
    can you name some devices which can compare ac currents? And yes i am using 2 ct s , plus i do not want to overburden them as they are already being used for metering and protection.
  • neo23
    neo23 OP
    Please give ideas on comparing the ac currents , as this is the main part confusing me.
  • aarthivg
    i think, u can code such a way to compare two currents in microcontroller.
    neo23Please give ideas on comparing the ac currents , as this is the main part confusing me.
    If you can have shunts on the neutral side of the loads, the two loads being compared can have a common ground. In which case the two shunt voltages can be compared. It should be possible to amplify the differential signal and use for control.
  • neo23
    neo23 OP
    bioramaniIf you can have shunts on the neutral side of the loads, the two loads being compared can have a common ground. In which case the two shunt voltages can be compared. It should be possible to amplify the differential signal and use for control.
    Just like a differential relay works?
  • neo23
    neo23 OP
    But i am afraid sir as i have my limits. The CT s are loaded on the first hand and i have to watch that too. Perhaps microcontroller method could be less power consuming.
    neo23But i am afraid sir as i have my limits. The CT s are loaded on the first hand and i have to watch that too. Perhaps microcontroller method could be less power consuming.
    What is the load on the CTs? You may still be able to take out a small signal to asuitable op amp or comparator circuit. This should not add anything to the existing load on the CT.
  • neo23
    neo23 OP
    Can the comparator work on AC or do i have to use an ADC in it?
    neo23Can the comparator work on AC or do i have to use an ADC in it?
    If the two wave forms are in perfect phase it would work. It may be a better option to individually amplify the signal, rectify and compare.
  • aarthivg
    @aarthivg-HH344f • Feb 2, 2012
    i do a similar project, when the ct current exceeds a certain value, this input is given to the micro controller to drive the relay.
  • neo23
    neo23 OP
    @neo23-KisbGm • Feb 2, 2012
    aarthivgi do a similar project, when the ct current exceeds a certain value, this input is given to the micro controller to drive the relay.
    Are you experimenting on Ac Current or dc? and what are you using for comparing?
  • aarthivg
    ac only.
  • neo23
    neo23 OP
    @neo23-KisbGm • Feb 3, 2012
    aarthivgac only.
    But bro what exactly are you using for comparing? op amp ? Microcontroller? And are you using ADC to rectify the AC Currents?
  • aarthivg
    @aarthivg-HH344f • Feb 3, 2012
    neo23But bro what exactly are you using for comparing? op amp ? Microcontroller? And are you using ADC to rectify the AC Currents?
    microcontroller and adc.
    what "bro" stands for?
    @ramani-VR4O43 • Feb 3, 2012
    Brother
  • Bionic
    @bionic-y3kcfA • Feb 3, 2012
    All you need to do is to connect the two different ac source to two different loads of the same magnitude, then calculate each separately and read off the excess ac current, then you can now compare them...
  • aarthivg
    BionicAll you need to do is to connect the two different ac source to two different loads of the same magnitude, then calculate each separately and read off the excess ac current, then you can now compare them...
    but this needs manual calculations?
  • neo23
    neo23 OP
    @neo23-KisbGm • Feb 4, 2012
    bioramaniIf the two wave forms are in perfect phase it would work. It may be a better option to individually amplify the signal, rectify and compare.
    Bioramani sir , how about i use a null meter to see the difference in currents. I have seen null meter being used for to show the difference in two voltages. But i am not sure whether that would work out for 2 Currents.
  • aarthivg
    @aarthivg-HH344f • Feb 4, 2012
    A null detector is a device built for maximum sensitivity to small voltages or currents. It is used in voltmeter circuits to indicate the absence of voltage between two points, thus indicating a condition of balance between an adjustable voltage source and the voltage being measured.
    @ramani-VR4O43 • Feb 4, 2012
    neo23Bioramani sir , how about i use a null meter to see the difference in currents. I have seen null meter being used for to show the difference in two voltages. But i am not sure whether that would work out for 2 Currents.
    If one terminal can be common you can do that without additional circuitry. Unless some sensitive info is involved and you cannot reveal data, we can advise better if we know the application, voltages involed, AC single /multiple phases and such details.
  • Bionic
    @bionic-y3kcfA • Feb 4, 2012
    aarthivgbut this needs manual calculations?
    yeaq that's what am saying you connect the two loads of same magnitude across the two ac read off the corresponding ac then do the calcutions that follow....
    Or maybe you try using a potentiometer or you design a kechoff's circuit for it hope this helps?
    @ramani-VR4O43 • Feb 7, 2012
    An update. This component may help:
