ISHAN TOPRE OP
@ishan-nohePN • Jun 3, 2011
Friends,
In this video, the person has explained the following commands.
1.Sweep-This is a useful command and is used for making a plane. This is done by a curve following the other.
MOST IMPORTANT THING TO NOTE: During a sweep command, the curve tries to follow another one in the best feasible manner. In the video, the plane follows the curve accurately, while that in the image attached, it does not pass through the guide curve.
2.Revolve-Here two types of angles are used. The govern angle of extrusion on both sides of a curve.
It should be noted that, the algebraic sum of both the governing angles shold be between 0-360 degree. It can also be 0 and 360, your choice, depending upon the situation
3.Join and cut. It is used to join various surfaces and cut them. Extrude command is also explained in it.
4.Also it should be noted that thickness of a plane in wireframe is *nil*. We need to provide it by using the thicken command. -
ISHAN TOPRE OP
Here is the image. See the plane is not passing through the guide curve, although it is following the curve. ๐
![[โIMG]](proxy.php?image=http%3A%2F%2Fi51.tinypic.com%2Fhwcqk9.jpg&hash=3507412621eeefe72f767a8b0e3c6dfc)
