Why Do Computers Use Binary (0,1) Only?
pnv ganesh
@pnv-ganesh-Yk4BUQ โ€ข Oct 27, 2024
Computers use binary as their fundamental language because it simplifies the representation and manipulation of information in electronic circuits.
Binary is a base-2 numeral system, meaning it only uses two digits: 0 and 1. This choice of base is closely tied to the underlying hardware design of computers, specifically electronic switches.
Computers are built using electronic components, such as transistors, which can be in one of two states: on or off.
These states are often represented as 1 and 0, respectively. The switch-like behavior of transistors allows them to control the flow of electric current, enabling the construction of logic gates that perform binary operations.
These gates are the building blocks of all digital circuits.
By using binary, computers can easily represent and process information electronically.
Binary digits, or bits, can be represented physically using two voltage levels or two distinct electrical states.
This simplicity greatly simplifies the design of electronic circuits and allows for reliable and efficient computation.
Why Binary is Preferred by Computers
There are several reasons why binary is preferred over other numeral systems:
1. Simplicity of electronic circuits: Binary circuits are easier to design, build, and maintain than circuits based on other numeral systems. The binary nature of transistors allows for straightforward implementation of logic gates and arithmetic circuits.
2. Reliability: Binary circuits are less prone to errors compared to circuits that use multiple voltage levels or more complex representations. With just two states, it is easier to distinguish between high and low voltage levels, reducing the chances of errors caused by noise or interference.
3. Compatibility: Binary is a universal language understood by all digital systems. Computers, microprocessors, and other digital devices can easily communicate and exchange information using binary representations. This standardization allows for interoperability and the development of a wide range of hardware and software.
4. Efficiency: Binary arithmetic and logical operations are highly optimized in modern computer architectures. Operations involving binary numbers can be executed quickly and efficiently using simple hardware components. This efficiency is crucial for the fast and complex computations performed by computers.
While binary is the foundation of computing, it doesn't mean that other numeral systems are entirely absent from computer systems.
Higher-level programming languages and software can represent and manipulate data using decimal, hexadecimal, or other numeral systems for convenience.
However, these representations are ultimately converted to binary for processing at the hardware level.
In summary, computers use binary because it aligns with the underlying electronic hardware, simplifies circuit design, ensures reliability, enables compatibility, and offers efficient computation. Binary provides a robust and universal foundation for representing and manipulating information in the digital realm.
    @thebigk Sep 29, 2012
    pnv ganeshwhy computer can understand only binary language?
    That's a nice question. To understand why computers use Binary; you'll first have to understand that binary language is basically just two digits - 0 and 1. Each of these digits actually represent 'state'; let's call it 'On' and 'Off'. To understand this better in electronics; an 'on' state could be thought of as a positive voltage say '5V' and 0 would represent '0' volts. These are the two states the electronic devices can understand.
    Now, the data can be represented using a series of these on and off stages. That is we can represent the information through the series of on and off states in electronics.
    So visualize it as follows: The circuits themselves don't understand anything except that they can be in the on state or off states. A series of on and off signals can be used to represent data - and that's why computers understand binary code.
    I'd like more inputs from the electronics and computer science engineers. I'm not sure whether I can explain this in even simpler words.
  • grayhat
    @grayhat-FImbA5 Sep 29, 2012
    0 and 1 is nothing but if the current is passed on the circuit is represent by 1.
    and otherwise it is represent like 0,thats why computer understand only 0s and 1s
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Sep 29, 2012
    Not exactly current as the losses due to current transmission is very high and lot of heat is generated
    Instead now a days we use more voltage to represent 1 and 0
    Recently I heard of MOS having high rating = 1.7 V and low rating of 0V
  • Jeffrey Arulraj
    Next your question what other form of input can you imagine of giving to a computer
    If it is written in hand each of our hand writing is different and so programming becomes more tedious (data sensing ) so to have a more generalised form of Input we go for BIT representation
  • Lokesh Choudhary
    @lokesh-vy8a07 Oct 9, 2018
    who consider 0's and 1's as a off and on states?
