  • Kishan Gupta
    @kishan-gupta-IFXTPJ Aug 28, 2008
    i have buy a pen drive of 16 gb. But it can't store data more than 30 mb. After formatting it still show 15gb. I want to know how i can know the real capacity of my pen drive.
    As i hear that in market there are fake memory pen drives come, then how we know that it is fake or real?
  • anuragh27crony
    @anuragh27crony-mb8hAE Aug 28, 2008
    @jcksn...
    If you had bought pendrive recently... then you can approach the store to find out the Prioblem...since it's under warranty...
    This is the first time iam listening about the fake pen drives... do such things exist in market...?
    @thebigk Aug 28, 2008
    Silly suggestion - but worth a try.
    Try formatting the pen drive and try storing stuff in it again. Might work.
  • kedarjk
    @kedarjk-R7FdZW Aug 28, 2008
    I don't think you will get total 16GB of memory space to use.
    It took some memory space for the ratio is 1/10 mostly.
    In our PCs also for 40GB HD, we never get complete 40GB of memory but somewhere between 36 to 37GB. Same case here.
    So I would say, enjoy 15GB😀.
  • anuragh27crony
    @Kedarjk
    yeah it's true....
    But the main issue is "But it can't store data more than 30 mb and fake Pendrive"
  • kedarjk
    Ohhh..I thought after formatting he is able to use whole 15GB.
    Then its weird.
    Contacting a seller is the best option.
  • bayazidahmed
    @bayazidahmed-qg0JR9 Aug 28, 2008
    kedarjkI don't think you will get total 16GB of memory space to use.
    What if I look at the 40 GB this way.
    Let us suppose by 40 GB the manufacturers mean
    40000000000 (40 X 10^9) bytes of data
    which is equivalent to 39062500 KB if i divide it by 1024.
    Again if I divide it by 1024 I get 38146.97265625 MB.
    Again dividing by 1024 I get 37.252902984619140625 GB
    which is what your PC shows for a 40 GB hard disk
  • Ashraf HZ
    @Ash Aug 28, 2008
    This is related to our discussions here:
    To know whether the pen drive is fake or not depends on WHERE you get it from. Also, look at the price. 16GB of flash is probably relatively expensive at the moment (about $65 dollars) and if you got it cheap, then something fishy is up.
    Unfortunately, the only other way to know whether the drive is fake or not is to physically test it.
    Its best to just buy from shops and make sure there is warranty.
  • shadeslayer
    @shadeslayer-lMXOJ2 Aug 29, 2008
    it may be possible that its fake ..coz this type of pendrives exists... i better suggest buy the pendrives of reputed company and that to are having warrenty,,dnt buy stuff witout warrenty... now about your pendrive nothing can be done as i think,, njoy a greate 30mb pendrive that is what at the end i can say..
  • Kishan Gupta
    @kishan-gupta-IFXTPJ Aug 30, 2008
    i have allready done it. i format it many times, and always it shows capacity of 15 gb, but when i try to store data it got corrupt after 30 mb. i heared that there are some software that tell real memory of any such fake pen drives. any one know this type of software.
  • Kishan Gupta
    i really need that type of software because seller give me 5 year wareenty, so to replace me this fake pen drive i need to show him the real memory of it'
  • just2rock
    @just2rock-DkmPtO Sep 1, 2008
    Jckson,
    Gone through all posts.
    What i suggest on all...
    1>Go to seller & simply presuurize him to replace.
    2>Maybe 30mb data will be a reason of its corrupted EEPROM.
    3>Ask them to let you show around 15.3Gb of space as it will be or ask them to copy anything on it above 30 Mb.
    Hope you will find your solution
    Regards,
    J2R😁
    jcksni really need that type of software because seller give me 5 year wareenty, so to replace me this fake pen drive i need to show him the real memory of it'
  • linda
    @linda-qQ2JBp Sep 5, 2008
    A USB flash drive is a <a href="https://en.wikipedia.org/wiki/Flash_memory#NAND_memories" target="_blank" rel="nofollow noopener noreferrer">Flash memory - Wikipedia</a>-type <a href="https://en.wikipedia.org/wiki/Flash_memory" target="_blank" rel="nofollow noopener noreferrer">Flash memory - Wikipedia</a> <a href="https://en.wikipedia.org/wiki/Data_storage_device" target="_blank" rel="nofollow noopener noreferrer">Data storage - Wikipedia</a> integrated with a <a href="https://en.wikipedia.org/wiki/USB" target="_blank" rel="nofollow noopener noreferrer">USB - Wikipedia</a> (universal serial bus) interface. USB flash drives are typically removable and rewritable.SStorage capacities typically range from 64 MB to 64 GBtorage capacities typically range from 64 MB to 64 GB.
    Linda
  • Kishan Gupta
    @kishan-gupta-IFXTPJ Sep 6, 2008
    thenks J2R...
  • zaid_chauhan
    @zaid-chauhan-b143S5 Sep 21, 2008
    It's not type fake storage device,
    But many times in Company Manufacturer some device not properly made or configured so if your pen drive is branded then replace it to company
    If not then buy a branded pen drive because they give life time warranty
  • pranaysingh
    @pranaysingh-MKnvYz Oct 10, 2008
    I have bought a new 30gb pen drive. When i transfer data (about 1 gb), it shows that the data has been transferred but when I remove the pen drive and plug it again in my laptop or any other comp, there is no data and the folders are empty, word docs are coverted into some other format that cannnot be deleted.
    Please Help!!!
  • scandalouskk
    @scandalouskk-jM6BHF Oct 28, 2008
    Hello ,
    my pen drive is detecting when it is inserted into port.
    When i tried to open, system displays an message "INSERT DISK INTO DRIVE "..
    My keyboard and mouse are working properly which when connected through same port.
    I tried at different port but in vain.
    wat shall i do???
    Thx in advance
  • nitz3D
    @nitz3d-H1KVJW Dec 17, 2008
    Problem With Kingston DT 32GB
    Hi.. I have bought a Kingston DT 32GB and whenever i am copying anything in it.. the files are getting corrupted.. and some files get disappear and shows some rubbish files.. with rubbish extensions.. What could be the problem.. Could you help..
    Nitesh
  • Ashutosh_shukla
    @ashutosh-shukla-ed4Ei4 Dec 23, 2008
    Check for viruses and also try to format once using the command prompt
  • Kishan Gupta
    @kishan-gupta-IFXTPJ Mar 2, 2009
    Hi, i cheque my fake 16 gb pen drive, it has realy 4 gb memory. Now when i format this pen drive in fat it shows 4 gb space, but when again format it in fat 32 or ntfs it shows 16 gb. Is any way or any tool by which i can got at least that 4 gb of space.
    If any one know this type of software or tool plz tell me.
  • Kishan Gupta
    @kishan-gupta-IFXTPJ Mar 3, 2009
    Hi guys, today i got a software that make my 16 gb fake pen drive into working 4 gb pen drive. If any one have this type of fake pen drive then use this software-"HP Drive Key Boot Utility".
    You got it from hp website. I hope it work for you as well...
  • d21deepesh
    @d21deepesh-fqS8mL Apr 3, 2009
    hey jackson ,
    i think i may help you..
    actually pendrives are usually made up of capacitors(not real aluminium spinddle)
    these capacitors are used as flash memory as charge is stored in there
    in market capacitor can have (at max) 4gb of storage capacity
    to make larger size pendrive we connect the capacitors in series so if one capactior fails(or is of cheap quality)others follow..
    you will encounter problems like this either your data is corrupt or it is not shown at all(but you find size equilent)..
    so
    1. never buy pendrives above 4gb of storage(at least for a year or so)
    2. always look for serial no on your pen-drive(tell me the distributor i'lltell you where to find it)
    genrally this is escaled on your pendrive's metallic part (the one that is plugged into your pc)
  • engineer_vinay
    @engineer-vinay-vETp5V May 4, 2009
    I think you purchased it from street shop. is it right?
  • g_rakesh2
    @g-rakesh2-CVEauh May 5, 2009
    So buy pendrives of reputed companies...
    I think Kingston is the good one or even transcent
  • abhi_003_sonu
    @abhi-003-sonu-ZuVBU3 Apr 3, 2010
    how can i stop my usb pen drive by viruse
  • optimystix
    @optimystix-4yMPKC Apr 3, 2010
    abhi_003_sonuhow can i stop my usb pen drive by viruse
    pendrive viruses are mainly activated by autorun.inf . to reduce the problem disable autorun feature(autorun is different from autoplay).
    read more about autorun problem <a href="https://babbleona.blogspot.com/2009/07/autorun-problem.html" target="_blank" rel="nofollow noopener noreferrer">Technorama Blog: Autorun problem !!</a> and download the registry crack for stopping it at the end of the post.
    also, use autorun eater . get it from here for #-Link-Snipped-#. it will automatically kill malicious autorun.inf files in the usb drives.
    additionally you may also use the free panda usb vaccine and use it to vaccinate your drives and usb drives. download from #-Link-Snipped-#
    follow the steps and you will be relieved from most usb drive related problems.
    also take care to scan your usb drive once before using it , with an antivirus.
  • Pensu
    @pensu-8tNeGU Apr 3, 2010
    Ya you may have got a fake pen drive.One of my friend also got a pen drive like that.It shows 80Gb storage space but you cant store more than 512Mb in it.He went to the shop and got that replaced.
    Just try to contact the dealer as soon as possible,may be he can help you.
  • rohit bisht
    @rohit-bisht-qByuHY Jun 6, 2010
    i also think tha same. bcoz there are also chinese pendrive exists in the market , that don't store the capacity writen on them, and also they are not reliable.so u should go for a pendrive of a good company..
  • karge
    @karge-DVJ95K Jul 23, 2010
    Hello guys,
    3 Newest USB pen drive launched and theire name is Key, Spin and Hulk from Strontium.#-Link-Snipped-#
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Jul 31, 2010
    recently a lot of news about fake pen drives.
    i have heard that fake pen drives contain software which increases its storage capacity but its fake capacity.
    once u format pen drive, it contains no software in it, hence its capacity reduces to a great extent.
    these pen drive are available without any warrenty so we cannot claim anybody later
  • Vikram kumar
    @vikram-kumar-417Kh6 Sep 18, 2010
    Yes fake pen drives do exist.But in your case a 16gb pendrive is providing 15gb space,what more you want.Its working properly,for example a 2gb pendrive provives space of 1.88gb.
  • anandkumarjha
    @anandkumarjha-jzdDMA Sep 18, 2010
    Re: Problem With Kingston DT 32GB
    nitz3DHi.. I have bought a Kingston DT 32GB and whenever i am copying anything in it.. the files are getting corrupted.. and some files get disappear and shows some rubbish files.. with rubbish extensions.. What could be the problem.. Could you help..
    Nitesh
    as we know that the pen drive must be of EEPROM type....so it may happen that you have bought the pendrive which does not support EEPROM
  • anandkumarjha
    how to format pen drive using command prompt??please suggest
  • headRush
    @headrush-Wnzwdz Sep 19, 2010
    jcksni have buy a pen drive of 16 gb. But it can't store data more than 30 mb. After formatting it still show 15gb. I want to know how i can know the real capacity of my pen drive.
    Very much so sir.
    [​IMG]
  • lovejeet
    @lovejeet-etHdkD Oct 16, 2010
    actually the manufacturing of a usb drive/ pen drive is very cheap....... almost 8-10 bucks only........... so dats why most of the companies doesn't replace them easily........... n there r chances to get even d fake one also........... try buying transcend pen drives......
  • lovejeet
    to format, just simply type format:drive_letter;
  • BCA_GIRL
    @bca-girl-wzX9cA Oct 16, 2010
    Format it twice or trice.Because i have noticed with my pendrive, formatting single time doesn't effect it.But when i format it twice then i got the efficient space.
  • nvrajasekhar
    @nvrajasekhar-fsF97b Dec 20, 2010
    Hi, Simply i am giving you the solution that 'Change your pen drive' otherwise if u want to try to recover the pendrive,it will eat your valuable time. I think the pendrive name is Kingston,because most of the fake flash drives found on that name(Chinese). The operations that can try to do recover are
    --Formatting the Pendrive was of no use(even 100 times).
    --Disk Check utility to see whether the bad sectors could be recovered but the program used to hang on initiating it. It will consume ur hours of time,but can't say.
    --On opening the pendrive we can find the PCB was in a pretty bad condition,It had a 2GB RAM chip and was patched in firmware to make it look as it was of 32 GB or 16 gb or something
    --Many Hidden system folders with random names having files more that 2.5 GB of size appeared randomly and you cannot delete them.
    --so on......
    Better to dont buy at out side including ebay(may be fake).
    Try to buy the pendrives at reputed showrooms.
  • sachin bankar
    @sachin-bankar-tI6gke Dec 20, 2010
    May be you have bought chinese pen drive.
    Some chinese pen drive have capacity upto 32GB But can store only upto 1 or 2 GB
    So go for Iball,Transcend,Moserbear,HCL etc.
  • lovejeet
    @lovejeet-etHdkD Dec 23, 2010
    1) has any1 tried to replace his usb drives??? how was the response????
    2) has any1 used his flash drive as a RAM ????? did it really helped????
    waiting ur replies...............
  • 4M4N
    @4m4n-jQmegc Dec 23, 2010
    usb as a ram was helpful....
  • lovejeet
    @lovejeet-etHdkD Dec 24, 2010
    but i guess it doesn't speed up the process.......does it........ n dats because actual ram is much faster in operating than the solid state devices........ correct me if i m wrong..........
  • ashishgupta652
    @ashishgupta652-nzpKVu Jan 9, 2011
    how to make pen drive bootable for installing windows xp.
  • 4M4N
    @4m4n-jQmegc Jan 9, 2011
    lovejeetbut i guess it doesn't speed up the process.......does it........ n dats because actual ram is much faster in operating than the solid state devices........ correct me if i m wrong..........
    ofcourse the speed can never be equal to the actual ram u are absolutely right, but it was useful in case u need for example 2 gb ram to run any application and you have less than 2 gb
  • Kishan Gupta
    @kishan-gupta-IFXTPJ Jan 16, 2011
    ashishgupta652how to make pen drive bootable for installing windows xp.
    Use above link for downloading Winsetupfromusb. This software very easy for making windows xp bootable pendrive.
  • Kishan Gupta
    4M4Nofcourse the speed can never be equal to the actual ram u are absolutely right, but it was useful in case u need for example 2 gb ram to run any application and you have less than 2 gb
    Yes i agree with 4M4N. if wana read more about it then go to this link <a href="https://en.wikipedia.org/wiki/ReadyBoost" target="_blank" rel="nofollow noopener noreferrer">Readyboost</a>
  • crazy_neo
    @crazy-neo-9P4Tdc Jan 20, 2011
    Thanks for such a good comment.....
  • ramana_slv
    @ramana-slv-xx4JdA Jan 29, 2011
    shadeslayerit may be possible that its fake ..coz this type of pendrives exists... i better suggest buy the pendrives of reputed company and that to are having warrenty,,dnt buy stuff witout warrenty... now about your pendrive nothing can be done as i think,, njoy a greate 30mb pendrive that is what at the end i can say..
    ya shadeslayer your correct. In present days lot of pendrives come to market with high capability but it's not work yaar. So,I better suggest buy the pendrives of reputed company and that to are having warrenty,don't buy stuff witout warrenty...
  • balus143
    @balus143-fyfBy9 Feb 6, 2011
    hi... is it possible to design a circuit diagram for pen drive??i'm studying b.tech final year.. i want to make a pendrive , blutooths.. if know that pls help me or post the ckt diagrams and book links
    Thanku
  • narayana murthy
    @narayana-z4W16q Feb 6, 2011
    hope this may help you
    <a href="https://www.google.co.in/images?hl=en&q=pen+drive+circuit+diagram&um=1&ie=UTF-8&source=univ&ei=a89OTdr3OMGrcbO1sOQL&sa=X&oi=image_result_group&ct=title&resnum=3&ved=0CDcQsAQwAg&biw=994&bih=601" target="_blank" rel="nofollow noopener noreferrer">pen drive circuit diagram - Google Search</a>
