Question on power factor improvement by using phase advancer
Rakeshkumarrout
@rakeshkumarrout-rbS0Ua โ€ข Oct 26, 2024
This article is given in power system book by V.K.Mehta please read this and answer my question:
PHASE ADVANCER:phase advancers are used to improve the power factor of induction motors.The low power factor of an induction motor is due to the fact that its stator winding draws exciting current which lags behind the supply voltage by 90 degree.If the exciting ampere turns can be provided from some other A.C. source,then the stator winding will be relieved of exciting current and the power factor of the motor can be improved.This job is accomplished by the phase advancer which is simply an A.C exciter.The phase advancer is mounted on the shaft as the main motor and is connected in the rotor circuit of the motor. It provides exciting ampere turns to the rotor circuit at slip frequency.By providing more ampere turns than required,the induction motor can be made to operate on leading power factor like an over-excited synchronous motor.
My question is what is this A.C. exciter is? and from where it is supplied power
  • aj_onduty
    @aj-onduty-BvuwMK • Sep 12, 2010
    Dear friend, kindly view this post and ask if there is any doubt.
    Thank you.
  • Rakeshkumarrout
    @rakeshkumarrout-rbS0Ua • Sep 14, 2010
    I have already read this,please kindly you read my question and all the text given by me carefully and then give the answer
  • Rakeshkumarrout
    @rakeshkumarrout-rbS0Ua • Sep 15, 2010
    I have already read this,please kindly you read my question and all the text given by me carefully and then give the answer โ€‹
  • freak16
    @freak16-XgiLj6 • Feb 3, 2011
    Ac exciter is ac synchronous motor only which exclusively used for power factor correction devices. For power factor correction it is generally used in overexcited mode.
  • Mohammed Alrikabi
    @mohammed-alrikabi-K1zQnD • Aug 15, 2015
    Plz can help me by showing me the circuit diagram for the phase advancer?
