Project for gesture control of electronic equipment
Lakshana
@lakshana-Lx8JcZ โ€ข Oct 26, 2024
my project idea is based on usage of gestures for control of electronic equipment... i was advised to do the project using LabVIEW. i need to get an idea of the Vision and Motion toolkit in LabVIEW. can someone help me with this??
    @harshad-ukH5ww • Jul 28, 2013
    Hi #-Link-Snipped-# are you talking about NI's LabView? I am not sure if it has module for motion detection but you can interface your camera signal to PC and use that signal in LabView.
  • Lakshana
    @lakshana-Lx8JcZ • Jul 31, 2013
    yes sir i am talking about LabVIEW. thank you for replying... but i searched ni.com and found that it is possible to implement using it. but i am not able to get sufficient resources...
    @harshad-ukH5ww • Jul 31, 2013
    Lakshanayes sir i am talking about LabVIEW. thank you for replying... but i searched ni.com and found that it is possible to implement using it. but i am not able to get sufficient resources...
    In this month NI is going to arrange one seminar at my place I am planning to attend this event and I will put your query in-front of them may we have some better solutions.
  • Lakshana
    @lakshana-Lx8JcZ • Aug 3, 2013
    thank you so much sir... it is very kind of you. i hope your information will be helpful to me.
  • Nayan Goenka
    @nayan-Dhpt4N • Aug 11, 2013
    You can use sensors to do so too i believe. Proximity sensors can serve this purpose. They can detect movement around your gadget and analyse the pattern of the signal. you can then program them to do particular task. I hope this must be close.
  • Lakshana
    @lakshana-Lx8JcZ • Aug 12, 2013
    Yes it is. Thank you. You mean to say i could construct the system to work within a particular distance.
    Alright. But i need my system to detect the motion of the hand. And not just detect the presence of an object. Hope you get my point...and the difficulty involved..
  • Nayan Goenka
    @nayan-Dhpt4N • Aug 12, 2013
    LakshanaYes it is. Thank you. You mean to say i could construct the system to work within a particular distance.
    Yes I understand your idea. Its good one. Do you happen to know any kind of sensors that are sensitive to touch on the surface which can be deployed on the body of the gadget itself. Not the screen touch type. I think that sort of thing can help you too.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Aug 12, 2013
    Use telemetry sensors or IR sensors they can easily detect the variations in the position of the hand at any instant time
    Another solution is having a low frequency IR source and a receiver If the source is altered(moved) Then the intensity of IR received by the Receiver will vary and thereby you can detect the motion of hand
  • Lakshana
    Nayan GoenkaYes I understand your idea. Its good one. Do you happen to know any kind of sensors that are sensitive to touch on the surface which can be deployed on the body of the gadget itself. Not the screen touch type. I think that sort of thing can help you too.
    i'm sorry... could you be a little more clear about your point??
  • Lakshana
    ConquerorUse telemetry sensors or IR sensors they can easily detect the variations in the position of the hand at any instant time
    thank you for the information... will try to implement any of your ideas.
  • Nayan Goenka
    Lakshanai'm sorry... could you be a little more clear about your point??
    I dont know if this is available but I am giving it a try
    Is there any sensor available to detect touch on surface of gadgets? That can serve the purpose. Like touchscreen on mobiles. You are working on gesture control, this sensor can help for this project.
  • Lakshana
    Nayan GoenkaI dont know if this is available but I am giving it a try
    hmmm... i haven't heard about any such sensor... but i ll try see if i can find any.
  • Jeffrey Arulraj
    mate direct interface is not possible but we have tech to do that for us
    <a href="https://www.crazyengineers.com/threads/vibrations-turn-any-surface-into-responsive-touch-screen.69143">Vibrations Turn Any Surface Into Responsive Touch-Screen</a>
  • Nayan Goenka
    Conquerormate direct interface is not possible but we have tech to do that for us
    This is you are talking about making screen as touch sensitive. My doubt was a sensor which will make the body of any gadget, touch sensitive, Like a Coffee Machine or Radio or Juicer, mixer etc.
  • Jeffrey Arulraj
    Nayan GoenkaThis is you are talking about making screen as touch sensitive. My doubt was a sensor which will make the body of any gadget, touch sensitive, Like a Coffee Machine or Radio or Juicer, mixer etc.
    Making a plain surface touch sensitive is itself not easy so irregular objects
    And what is the use of having an irregular object touch sensitive
    PS: We are drifting away from topic gesture can easily be sensed using intensity of radiation tx and Rx that will be the easiest to do
  • Cyborg 009
    @cyborg-009-7H92N2 • Aug 12, 2013
    3 Axis Accelerometer can sense tilt & acceleration..
    It can be built into a hand glove\ attached under palm for sensing hand movements...
  • Lakshana
    @lakshana-Lx8JcZ • Aug 14, 2013
    Cyborg 0093 Axis Accelerometer can sense tilt & acceleration..
    thank you for your suggestion...!!
