Problem with Motor Driver
I would like to know whether can i use L298 driver IC to drive a motor of around 20-30kg torque (loaded)?
A problem which i encounter normally with this ic is...it works properly in one direction but in other direction the ic gets heated up and the motor stops working...wat could be d fault?
Is der any readymade driver board available which can deliver upto 5-7A current?Please giv the specifications 4 d same.
