Please help: Carnot cycle
rybyrd
@rybyrd-5USIPN โ€ข Oct 25, 2024
I'm trying to study for my physics test and I need help.
The problem is "A carnot engine operates with a cold reservoir temperature of 194 K and has an efficiency of 74.3 %. (A) What is the temperature of the hot reservoir? (B) If the engine does 8.99*10^4 J of net work during each cycle, how much heat does it absorb form the hot reservoir during a cycle?
I took the efficiency equation e=1-Tc/ Th and got 755 K for the first part of the equation, but I cannot seem to get the second part. Any suggestions??
How do you find out how much heat is absorbed by the hot reservoir during a cycle?
  • sharon09
    @sharon09-R9bAiT • Mar 29, 2010
    Efficiency also equals to Wnet/Qh . Plug in the values n u will get the answer.
  • shubhrajeet tiwa
    @shubhrajeet-tiwa-HbUaIL • Mar 31, 2010
    let source temp beT THEN
    EFFECIENCY ={{T-194}/T}=.743
    THIS GIVE VALUE OF T
    NOW
    AS W =8.99^4
    WHICH IS EQUAL TO Q1-Q2
    THERFORE
    W/Q1=EFFICENCY
    THIS GIVES Q1
