PHP- SQL utility
hbk
hbk
@hbk-UY6MQq • Oct 26, 2024
hi guys...
i'm developing a site 4 my college.... theres a link onthe site to checkur results...
there's this backend datbase(MySQL), the front end being HTML+PHP+CSS....
the database table(called result) contains columns (Roll NUmber, subject 1, subj2 etc)...
i ask the user to enter his roll number via a HTML form(POST method).... and on the target page of the form, i retreive the roll number he had entered....
i then compare the eneterd value with entries in the 'Roll NUmber' column of the databsae table.... and when a match is found, i print the entire record for that roll number...
plain and simple..
but i'm facing a problem...
when i try to retrieve the record (of the enetered roll number) using mysql_fetch_array($xyz), i get an error...
here's the source code...
the user form (collecting the roll number)
<form action="results2.php" method="post">
Roll Number: <input type="text" name="Roll Number" />
<br><br>
<input type="submit" value="Submit"/>
</form>
processing the form(comparing with database)
<?php
$rno = $_POST["Roll Number"];
$con = mysql_connect("localhost","root","");
if (!$con)
die('Could not connect: ' . mysql_error());
mysql_select_db("database", $con);
$data = mysql_query("SELECT * FROM result WHERE 'Roll Number' = $rno ");
while(mysql_fetch_row($data))
echo "HI";
mysql_close($con)
please help me figure out the error.... i'll be really grateful...
  • elric
    @elric-7vzoqS • Jun 17, 2008
    i think there is an error in your query string
    try something like
    $data = mysql_query("SELECT * FROM result WHERE 'Roll Number' = \"".$rno."\"" );
  • hbk
    hbk OP
    @hbk-UY6MQq • Jun 17, 2008
    thanks for the reply, but even this doesnt seem to work..... it gives the same output(blank screen--> no error message though) as with my original bit of code...
  • elric
    @elric-7vzoqS • Jun 18, 2008
    ok i have added mysql_error() calls to try debuggin where the error is, try out the following code and see what happens:
    <?php
    if (!$con)
    mysql_select_db("database", $con) or die (mysql_error());;
    $data = mysql_query("SELECT * FROM result WHERE 'Roll Number' = $rno ") or die (mysql_error());
    $row=mysql_fetch_row($data) or die (mysql_error());
    while($row)
        echo "HI";
    mysql_close($con)
  • hbk
    hbk OP
    @hbk-UY6MQq • Jun 18, 2008
    Thanks for the reply.. though even this doesnt work....
    it gives the following error message:
    You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
    now what does that mean??
    the entire source code is as follows:
    <html>
    <head>
    <title>Result</title>
    <?php
    include "menu.php";
    </head>
    <?php
    if (!$con)
    while($row)
    echo "HI";
    mysql_close($con)
    </html>
  • elric
    @elric-7vzoqS • Jun 19, 2008
    ok the error means your query isnt proper.
    try this:
    <?php
    if (!$con)
    $query="SELECT * FROM result WHERE \'Roll Number\' = $rno ";
    echo $query;
    $data = mysql_query($query) or die (mysql_error());
    while($row)
        echo "HI";
    mysql_close($con)
    now the query that php is sending mysql will also be printed, now try to execute this query from the mysql shell and see what happens.
    I guess that not using the escape slash for 'Roll Number' has made the query malformed. Anyways check the new code.
  • hbk
    hbk OP
    @hbk-UY6MQq • Jun 20, 2008
    thanks for the suggestion elric.... i tried what u said...
    but that gives the following error message---
    SELECT * FROM result WHERE \'Roll Number\' = You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '\'Roll Number\' =' at line 1
    please help...
  • elric
    @elric-7vzoqS • Jun 20, 2008
    ok, the escape slashes werent needed for 'Roll Number'
    next your query is
    so that means your $rno is blanck, that is $_POST["Roll Number"] is empty.
    Iam quite uncomfortable using a space in the name for the text box name, so try this in your html form
    Roll Number: <input type="text" name="Rollno" />
    <br><br>
    </form>
    and let your php file be
    <?php
    $rno = $_POST["Rollno"];
    if (!$con)
    $query="SELECT * FROM result WHERE 'Roll Number' = ".$rno ";
    echo $query;
    while($row)
        echo "HI";
    mysql_close($con)
    Also which version of php are you using? if you are using php5 then shouldn't be a problem but as far as i know in php4 (not sure), you cant embed a variable within a string and expect the string to have the contents of the string, ie.
    $rno = "foo";
    $query = "select * from $rno";
    now $query wont be a string "select * from foo"
    to obtain which you will need to use the dot operator as
    $query = "select * from ".$rno
    above is just an example. So to support backward compatibility dont embed variables within strings, if your script has to run on a php4 running server it would be a problem.
  • th3 ied kid
    @th3-ied-kid-AAVSGR • Jun 23, 2008
    well try using (back tic)` <the one over tilde > instead of(small quote) ' over the field names coz i found the default myphp admin softwtre doing xactly that.
    Secondly use the less power full quote to cloak the more power full one i.e. use less of " and more ' whenever possible.try this:
    $query ='SELECT * FROM result WHERE `Roll Number` ='. $rno;
    coz something like this worked in php5-mysql combi engine in my case.
    Well take a look at this working piece of line:
    $query='UPDATE chat SET Data ='."$val".'WHERE Pass ='.$Too;
    Please note that i have 2 kinds of quotes over variables and i didn't use back tic but i tested otherwise too and it seems to work with me
  • hbk
    hbk OP
    @hbk-UY6MQq • Jun 25, 2008
    hi guys...
    thank u all for ur time n effort...
    i finally figured out the solution (though it happened by chance)
    here is the FORM page:
    <form action="rs2.php" method="post">
    Roll Number: <input type="text" name="Roll" />
    <br><br>
    </form>
    </html>
    and here is the other page
    $xyz=$_POST["Roll"];
    $res = mysql_query("SELECT * FROM result where ID = '$xyz' ",$db);
    if ($myrow = mysql_fetch_array($res)) {
    echo "<table border=1>\n";
    echo "<tr><td>Name</td><td>Roll Number</td><td>Subject 1</td><td>Subject 2</td><td>Subject 3</td><td>Subject 4</td><td>Subject 5</td></tr>\n";
    do {
    printf("<tr><td>%s</td><td>%s</td><td>%s</td><td>%s</td><td>%s</td><td>%s</td><td>%s</td></tr>\n", $myrow["Name"], $myrow["ID"], $myrow["Subject 1"], $myrow["Subject 2"], $myrow["Subject 3"], $myrow["Subject 4"], $myrow["Subject 5"]);
    } while ($myrow = mysql_fetch_array($res));
    echo "</table>\n";
    } else {
    echo "Sorry, no records were found!";
    </body>
    </html>
    hope this helps anyone with a similar problem...
    cheers... and thx again...
