Overriding concept
Sachin Jain
@sachin-0wuUmc โ€ข Oct 17, 2024
Suppose we have a base class A and a derived class B.
A and B both have same method as:-
void show() {
Now in class B we also define show method with some other definition.
We say now show method is overridden.
But now i want to access the base class's show method using object of derived class.
Can we do that ?
  • csiscool
    @csiscool-qA5mGA Dec 11, 2010
    ya we can ๐Ÿ˜€ But you need to assign the base class instance to child class instance.
  • Sachin Jain
    @sachin-0wuUmc Dec 12, 2010
    @ csiscool
    Can you please explain more ?
  • csiscool
    @csiscool-qA5mGA Dec 12, 2010
    What is the real purpose of doing so?
    PS: google it. you can find it
  • Morningdot Hablu
    @morningdot-6Xuj4M Dec 13, 2010
    Yes you can by overloading concept..
    Check this code...
    class k
    public void show(int x)
    System.out.println("mohit kumar singh ");
    public class p extends k
    public void show()
    System.out.println("mohit cboy hack the world");
    k k1;
    p p1=new p();
    k1=p1;
    p1.show(2);
    p1.show();
    Otherwise it will hide the method of base class.
  • csiscool
    @csiscool-qA5mGA Dec 13, 2010
    mohit007kumar00Yes you can by overloading concept..
    Check this code...
    Hey he is asking in the case of overriding., but you have posted in overloading,why?
  • Deepika Bansal
    @deepika-jf1ysv Dec 13, 2010
    Yes you can do this using scope resolution operator, SRO ( :: ).
    public class A   //base class
      public void show()
        System.out.println("In base class");
    public class B extends A   //derived class
      public void show()   //over-ridden function
        A::show();   //calling the function of base class
        System.out.println("In derived class");
    And not just this, you can use SRO to resolve other type of ambiguities also like between a global and a local variable with same variable name..
  • Insatiable
    @insatiable-S9ushb Dec 14, 2010
    Polymorphism With Function Overloading is a way out :-
    class a{
    void show(String x){System.out.println(x);}
    class b extends a{
    void show(String x, String y){}
    class c {
    public static void main(String []args){
    a a1 = new b();
    a1.show("base");
  • Sachin Jain
    @sachin-0wuUmc Dec 15, 2010
    But i wanted over-ridden method of parent class to be called using object of derived class.
    Please do not confuse with over-loading.
    I hope i am clear now.
    I have to call an over-ridden method of parent class using object of derived class.
    Is that possible ?
  • Insatiable
    @insatiable-S9ushb Dec 15, 2010
    then there is no way out because if you want object of derived class with overriding it wont work because its the REFERENCE variables who decide which method to call while using function overriding and not the Objects.
