List down file names in a folder
Differential
@differential-0aMwAJ โ€ข Oct 27, 2024
On my computer, I have a folder which contains many files. I want all these file names to be listed in an spreadsheet. How do I do that? DOes windows provide any facility for that?
๐Ÿ˜›
  • ms_cs
    @ms-cs-Ab8svl • Mar 26, 2009
    DifferentialOn my computer, I have a folder which contains many files. I want all these file names to be listed in an spreadsheet. How do I do that? DOes windows provide any facility for that?
    ๐Ÿ˜›
    You can use the following java code part to get the names of files in particular directory and use FileWriter class to write the file names in a excel file
    File folder = new File("c:/");
    File[] listOfFiles = folder.listFiles();
    System.out.println("File " + listOfFiles.getName());
  • Differential
    @differential-0aMwAJ • Mar 26, 2009
    ms_csYou can use the following java code part to get the names of files in particular directory and use FileWriter class to write the file names in a excel file
    Finally some hope for me................
    Thanks for your reply. ๐Ÿ˜€
    BUT, I am totally unknown to Java and Filewriter and whatever they are.
    You might have to tell me in detail and in step by step to get these file names to excel (spreadsheet). And Yeah, I am little familiar with excel macros. Would that help in this task?
  • ms_cs
    @ms-cs-Ab8svl • May 9, 2009
    you can store it in excel sheet by,
    1.open the command prompt
    2.just type,
    dir > filename.xls
    Hope this may help you ๐Ÿ˜€
  • Differential
    @differential-0aMwAJ • May 9, 2009
    ms_csyou can store it in excel sheet by,
    2.just type,
    dir > filename.xls
    I can store what in excel sheet? Pls explain what you want to say in detail.
  • ms_cs
    You can store the names of the files with the size,
    try this,
  • shalini_goel14
    @shalini-goel14-ASmC2J • May 13, 2009
    ConanThis tool is very helpful to list down when we have more number of files, say in 100's in a folder. It is best when linking of it also enabled.
    Hi Conan,
    About which tool you are talking about? Please name it, I couldn't get it. ๐Ÿ˜•
    Thanks !
