Help!!!!
hi guys...please can anyone please direct me on how to connect and use the following :true RMS multimeter,function generator, variable resistor,oscilloscope to measure, compare and determine which is better between two different amplifiers for a better SOUND OUTPUT using these following specs for
1. linearity
2. gain
3 efficiency
4. bandwidth
5.noise
6. output dynamic range
7. slew rate
8. rise time
i will appreciate if i can get a full description on how i can use these instruments i hav at hand to determine the above specs.thank you
