@narayana-z4W16q • Jan 29, 2011
well we can convert it but losses are more
i think current will be reduced -
@vinod12345madhu-FwUje1 • Feb 5, 2011
how can current produced? -
@narayana-z4W16q • Feb 6, 2011
as per in the other transformers
see here i think it is same as converting 11kv to 440kv at generating station but here we are dealing with low voltages so losses will be higher -
@freak16-XgiLj6 • Feb 8, 2011
Generating voltage at 12 volt is fine but we should know the current also.Because it the power requirement st receiving end which needs to meet with rated voltage and frequency.
Ist take care of frequency .
Yeah it can be converted to 220 v with transformer but amount of current reduced it means load can be driven will be small as power transfer is constant in transformer if assumed transformer to be ideal.
Also losses will be very high if tranmission is done at 220 v .
AS nm said.
current will produc if you complete the path of the wire in which voltage is produced.
@vinod it is the same concept of faradays law if there is a flux change then voltage will be induced in the conductor.. it is not a new thing..
Plz redress meif i am wrong. -
@narayana-z4W16q • Feb 12, 2011
ya its not a new concept well......
i need to confirm one thing here
see for example if we convert 11kv to 420kv suppose losses are 100v it may be not considerable
but when we do it for less voltages i.e...., 12v to 220v suppose losses are 10v or even 1v is considerable so it is not fine to convert lower voltages to step up -
@vinod12345madhu-FwUje1 • Feb 15, 2011
thanks guys
