Explain this C Code: Calculate Sun of 5 digits
gsk_ssit
@gsk-ssit-KY7Fvw โ€ข Oct 26, 2024
/* To calculate sum of five digits*/
int num,a,n;
int sum=0;
system("cls");
printf("Enter a five digit number\n");
scanf("%d",&num);
a=num%10;
n=num/10;
sum=sum+a;
a=n%10;
n=n/10;
sum=sum+a;
a=n%10;
n=n/10;
sum=sum+a;
a=n%10;
n=n/10;
sum=sum+a;
a=n%10;
sum=sum+a;
printf("The sum of the five digits of %d is %d\n",num,sum);
    @thebigk • Jan 28, 2013
    Which part of the above do you find difficult to understand? I think it is the part where it says -
    a= num%10;
    n= num/10;
    Am I right?
    First part of understanding the code would be to understand what the % operator does.
    @anoop-kumar-GDGRCn • Jan 28, 2013
    Check this out simpler program:
    int num,sum=0;
    printf("Enter a number\n");
    scanf("%d",&num);
    while(num >0){
                sum=sum+num%10;
                num=num/10;
    printf("The sum of the digits of %d is    %d\n",num,sum);
    It will return you sum of any digit number.
    % operator is also called as modulo, That means it will return the reminder of operation.
    ps: I wrote this program in java. I hope it good in syntax wise for C.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Jan 30, 2013
    It does not find sum of 5 numbers But it finds the sum of the digits of a five digit number
  • ashwin sarangula
    @ashwin-sarangula-Eb5r0N • Jan 30, 2013
    it would be good if we use for loop in this program
