  3. Groups >
Database connectivity using C/C++ Tutorial!!!
Question asked by slashfear in #Databases on May 19, 2009
slashfear
slashfear · May 19, 2009
Rank C1 - EXPERT
Hi CEans,
I thought of putting this tutorial here in CE, so that it would be useful for other CEans!! Some of you out there would have never heard of this too, "Connecting Database with C++ program???" right, anyways no prob's CE is here to help you out 😉(and enlighten you!!! )
SO here is the Tutorial for making your C++ program to communicate with what ever database you want..... (ie., Oracle, Sybase, MySQL etc....)
The Tutorial is broken down from the very basics,
Before starting the Tutorial I would like to introduce you the following:
-> Compiler: Code::Blocks IDE with MinGW compiler Download Link: Download binary
The reason behind choosing this compiler is simple, Code::Blocks is a cross compiler (It can run on any platform like windows, Linux and Mac and hence called as a cross compiler😁) And it is Free to download. This IDE is specially designed for C and C++ and easy to use.
-> API: We are going to use SQLAPI++ Download Link: SQLAPI++ Library - Download
SQLAPI++ is a API ( Application Programming Interface) designed specially for C++ database communication(Nothing but a set of header files), This is the Key for communicating with the database, you have other methods also like Pro*C (comes along with your ORACLE) and other methods too, but I choose this SQLAPI++ because it is easy and makes your work simple (smart way in other terms).
-> OCCI: Oracle C++ Call Interface Download Link: OCCI Downloads
OCCI is an interface defined by the database company ORACLE that defines for the C++ programmer a comfortable interface to access the ORACLE database with classes using parameters that are reminiscent of SQL statements. The interface exists for ORACLE 9i and ORACLE 10g. OCCI comes along with your ORACLE but still If you guys don't have it, you can download it from the above link (NOTE: You have to be a member to download that file, Its simple just fill in a forum and you are a member!!!)
Download and install the above three (If you dont have), Now we are almost ready to start,
Prior Thing to be done before starting:
-> Open the code::blocks IDE and go to or click on settings -> compiler and debugger settings (You will now see global compiler settings)
-> Now click on “Linker settings” in the linker settings click on ADD button and add the following
If your using windows OS :
[B]
   C:\SQLAPI\lib\libsqlapiddll.a
   C:\Program Files\CodeBlocks\MinGW\lib\libuser32.a
   C:\Program Files\CodeBlocks\MinGW\lib\libversion.a
   C:\Program Files\CodeBlocks\MinGW\lib\liboleaut32.a
   C:\Program Files\CodeBlocks\MinGW\lib\libole32.a[/B]
These will be found in your SQLAPI++ (If you have not extracted in C: drive then select the appropriate location and add the mentioned files to linker settings)
If you using Linux OS:
[B]
  /home/anandakumar/Desktop/SQLAPI/lib/libsqlapi.so
  /home/anandakumar/Desktop/SQLAPI/lib/libsqlapi.a
  /usr/lib/libcodeblocks.so[/B]
And similarly for MAC OS,
For those of you who are wondering why we are including these files (library files), Its to Link the C/C++ Program with the SQLAPI++.
Now we are ready to Go guys......
First simple Program:
This program illustrates you how to connect and Disconnect from Database:
[B]#include <stdio.h>  // for printf
#include <SQLAPI.h> // main SQLAPI++ header
int main(int argc, char* argv[])
    SAConnection con; // create connection object
      try
        // connect to database
        // in this example it is Oracle,
        // but can also be Sybase, Informix, DB2
        // SQLServer, InterBase, SQLBase and ODBC
        con.Connect(
            "arvind",     // database name
            "slashfear",   // user name
            "Crazy Engineers",   // password
            SA_Oracle_Client);    //client name
        printf("We are connected!\n");
        // Disconnect is optional
        // autodisconnect will ocur in destructor if needed
        con.Disconnect();
        printf("We are disconnected!\n");
    catch(SAException &x)
        // SAConnection::Rollback()
        // can also throw an exception
        // (if a network error for example),
        // we will be ready
        try
            // on error rollback changes
            con.Rollback();
        catch(SAException &)
        // print error message
        printf("%s\n", (const char*)x.ErrText());
     return 0;
[/B]
The output of the program is simple as shown below,
OutPut:
We are Connected!
We are Disconnected!
Examining the above Code:
#include <SQLAPI.h>
- main header, should be used whenever SQLAPI++ is used.
SAConnection con
- To connect to a database you should create a connection object and then connect it., here con is the connection object
con.Connect( "arvind", "slashfear", "Crazy Engineers", SA_Oracle_Client); - This syntax is used for establishing connection with the database. Here the first value is the name of the database (DNS name), the second value is the user name and the third user name is the password. Then the SA_Oracle_Client is the client name we are going to use (In our example its oracle )
con.Disconnect – This syntax is used for disconnecting from the database.
Simple isn't it ;-)!!! That's It we are now able to successfully connected and disconnected from the DATABASE, Now to go one step further..... That's how to execute a SQL query like creating a table and inserting values in the table. This is covered in the next Post.... stay connected;-)
-Arvind(slashfear) Posted in: #Databases
slashfear
Rank C1 - EXPERT
Hi Guys,
Ok Now that we know how to Connect and Disconnect from a Database,
Lets now move on with the execution of the query's, (All the example's are for ORACLE database, for other database use the appropriate query's 😛)
First lets look into Creating a table (assuming that you have little knowledge in SQL query's :smile😀:
For creating a table, we use the following query:
[B]create table arvind (id number, name varchar(10));[/B]
So how to execute this from your C++ program, It is done as follows:
First establish the connection to the database then, after your con.connect; method you should use cmd.setCommandText method to pass the query's to Database, it is as shown below:
[B]con.Connect("arvind", "slashfear", "Crazy Engineers", SA_Oracle_Client);
cmd.setCommandText("create table arvind (id number, name varchar(10));");
[/B]
And then to Execute the query we have to use the following command:
[B]cmd.Execute();[/B]
SO your Final code will look like this:
[B]
cmd.Execute();[/B]
SO this query will create a table named arvind with two column id and name. Similarly we can use the cmd.SetCommandText to execute any SQL query
The following example shows how to create a table and insert five values into the created table in a single program:
[B]
#include   // for printf
#include  // main SQLAPI++ header
    SAConnection con; // connection object
    SACommand cmd;    // create command object
    try
        // connect to database (Oracle in our example)
        // associate a command with connection connection can also be specified in SACommand constructor
        cmd.setConnection(&con);
        // create table
        cmd.Execute();
        // insert value
        cmd.setCommandText(
            "Insert into arvind values (1, "Bigie")");
    cmd.setCommandText(
            "Insert into arvind values (2, "ES")");
    cmd.setCommandText(
            "Insert into arvind values (3, "shalini")");
    cmd.setCommandText(
            "Insert into arvind values (4, "godfather")");
    cmd.setCommandText(
            "Insert into arvind values (5, "slashfear")");
        cmd.Execute();
        // commit changes on success
        con.Commit();
        printf("Table created, row inserted!\n");
        // SAConnection::Rollback() can also throw an exception (if a network error for example),
        // we will be ready
        try
            con.Rollback();
    return 0;
}   [/B]
As we know Oracle is not auto committed so, we have to commit it!! (committing is nothing but making permanent reflection of data's in the Database, so for doing that we have to use the following command,
[B]con.Commit();[/B]
and similarly we can roll back the transactions when an exception occurs, so to do that we use,
[B]con.Rollback();[/B]
For deleting a row we use this command,
[B]cmd.setCommandText("delete from arvind where id= 5");[/B]
And you can execute any query like stored procedures, triggers what ever you want from C++ programs....
So guys we are done with the Tutorial!!! and If you have any doubts or questions feel free to post it across.......;-)
By the way Thanks for reading!!! 😁
-Arvind(slashfear)
slashfear
Rank C1 - EXPERT
Hi guys,
You will have demo programs along with the SQLAPI++ setup file, like how to use BLOB etc.... Make sure you go through them too!!!;-)
-Arvind(slashfear)
pradeep_agrawal
pradeep_agrawal · May 19, 2009
Rank C2 - EXPERT
Its good to see a article on a topic that many C/C++ programmer usually does not know about. Thanks for writing this article Slashfear.
slashfear
For those of you who are wondering why we are including these files, Its to recognize the header files and methods we are going to use in the program (To make it simple, we include them so that we can use the methods defined in those files)
These files are the library files and and not the headers. We need to mention these files so that after compilation, the code where the SQLAPI++ API's are called can be linked with the actual executable code. Correct me if i am wrong.
slashfear
An interesting item to see here with be:
1. When is set some 'select' query as the command and execute, in what form do i get the result and how do i display each entry.
2. Does the API's always throw exception in case of error or do they return some error codes in specific cases? If it support error codes than could you please list done some of the common codes that may be regularly used.
-Pradeep
slashfear
Rank C1 - EXPERT
Hi Pradeep,
I dint mention that those files are header files !!!! I just mentioned that those files (Library files) should be included so that, the header files (like #includeand methods (like cmd.Execute, SA_connection) can be recognized by the compiler. I dint mention it as Header file buddy.....😉
-Arvind(slashfear)
slashfear
Rank C1 - EXPERT
-Pradeep
Hi Again buddy,
Regarding your doubts......
1) You will Get the output in the console as you get output for all C/C++ Programs
2) Yes the Exception handling mechanism is allowed in SQLAPI++ , The errors which occur in the database will be captured by your exception handling mechanism (that's through try , catch block) and would be displayed in the console if something goes wrong.
// we will be ready
try
con.Rollback();
The above code is used to handle Exceptions, and this code as shown below:
  [I][FONT=Book Antiqua, serif]printf("%s\n", (const char*)x.ErrText());[/FONT][/I]
is used to catch and display the error......
Hope your doubt is cleared......😉 , if you got any more doubts ask dude!!!
-Arvind(slashfear)
pradeep_agrawal
Rank C2 - EXPERT
slashfear
I just mentioned that those files (Library files) should be included so that, the header files (like #include and methods (like cmd.Execute, SA_connection) can be recognized by the compiler.
That's what my point is, why you need to include the lib files for recognizing header files?
You are specifying command "#include" and if the compiler gets the corresponding file in path, it will include it or will throw an error.
And you don't need lib files to recognize the methods, they are checked against the definition present in the header file you have specified.
The lib files are required to link your code with the SQL API code present in the lib.
-Pradeep
pradeep_agrawal
Rank C2 - EXPERT
slashfear
Is there some way through which i can get the output of select query in some object instead of command line?
slashfear
From the examples you had given earlier i got that it throws exceptions. My query was instead of throwing exceptions, are there any cases where the API's return some error code?
-Pradeep
slashfear
Rank C1 - EXPERT
pradeep_agrawal
That was my point, why you need to include specify the lib files for recognizing header files?
-Pradeep
Exactly methods are checked in your header files and then Library are used to link the program to SQLAPI++ dude !!!
Thanks I will change it !!!
-Arvind(slashfear)
slashfear
Rank C1 - EXPERT
Hi Pradeep,
1) I have Not experimented it still but you can try and Let me know (I will also try that😉)
2) It would throw exceptions for sure !!!
-Arvind(slashfear)
SzuwarJr
SzuwarJr · Jun 18, 2009
Rank E2 - BEGINNER
Hi,
Nice tutorial...
I have to do application in Visual Studio 2008...
Do You know what I have to do???
I have also another questions:
1. Why "main" have parameters, what it represents???
2. If "try" and "catch" mandotory???
3. Can i write just:
void main()
SAConnection con;
con.Connect("whatever");
con.Disconnect();
PS: Application in CodeBlocks works fine...
PS2: sorry for my english... xD
EDIT: I already solve this problem... xD
HEART-HACKER
HEART-HACKER · Jul 7, 2009
Rank D3 - MASTER
Can you explain same thing about C# and SQL connectivity ?
CEMember
CEMember · Jul 7, 2009
Rank C3 - EXPERT
HEART-HACKER
Hi HEART-HACKER
Not sure about him whether he can explain or not but by that time you can check MSDN's site. There is lot of related stuff for you. An example is Database Access (C# vs Java)
@Mods Please check if any illegal link shared.
Thanks !
golucki
golucki · Aug 15, 2009
Rank E2 - BEGINNER
Hi,
Can you please explain how i can use SQLAPI++ to connect to sql compact edition 3.5 database. With SQL CE database file, the file has a password, we do not have any user name as such.
Thanks,
Ganesh
slashfear
Hi CEans,
[B]
[B]
[B]#include   // for printf
      try
        con.Connect(
        con.Disconnect();
        // we will be ready
        try
            con.Rollback();
     return 0;
[/B]
OutPut:
We are Connected!
#include
SAConnection con
-Arvind(slashfear)
vishnu priya
vishnu priya · Sep 29, 2009
Rank B2 - LEADER
Can anybody help with the connectivity of SQL database and VB?
tnhems
tnhems · Sep 30, 2009
Rank E2 - BEGINNER
I m using CodeBlocks on MAC OS.
In the linker settings, i added these 2 files:
/home//Desktop/SQLAPI/lib/libsqlapi.so
/home//Desktop/SQLAPI/lib/libsqlapi.a
But the third file mentioned is not in Mac os,
Where can i find it or should i download it seperately???
Without this file, I m getting the following error:
Linking console executable: bin/Release/DBConnect
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld: warning empty table of contents: /Users//Desktop/SQLAPI/lib/libsqlapi.a (can't load from it)
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld: /Users//Desktop/SQLAPI/lib/libsqlapi.so bad magic number (not a Mach-O file)
collect2: ld returned 1 exit status
And can I use the same code in XCode2.5 to connect to the database?If yes how do i add the above files?
Someone please guide me...
antonio8a
antonio8a · Dec 7, 2010
Rank E2 - BEGINNER
hi, i need to make a software on linux, i using code::blocks but i don't understand that a database with code::blocks, are you help me?
flipmedia
flipmedia · Jan 25, 2011
Rank E2 - BEGINNER
Hi pals,
I saw your Thread Regarding Connecting with Oracle, But My Requirement is
to connect my mysql Database table in my local system(Windows Xp,Dev C++) Environment
to C++. How it can do , pls Reply me
Thankfully
Anes P. A :sshhh:
Navratan
Navratan · Jan 25, 2011
Rank E2 - BEGINNER
seminar
hey....
please suggest me for info. tech . seminar topic.....
jara hatke......
slashfear
slashfear · Feb 7, 2011
Rank C1 - EXPERT
Hi Flipmedia,
Follow this link: Dev-C++ and SPTK
Which has the pictograph-cal instructions on how to do it.....
-Arvind
flipmedia
Hi pals,
Thankfully
Anes P. A :sshhh:
shivang16
shivang16 · Feb 7, 2012
Rank E2 - BEGINNER
Sir thanks for sharing articals vc++ /sqlapi,but sir i am getting error
Error 1 error LNK2019: unresolved external symbol "public: virtual __thiscall SAConnection::~SAConnection(void)" (??1SAConnection@@UAE@XZ) referenced in function __catch$_main$0 Oratry.obj
approx 13 error i am getting .
#include "stdafx.h"
#include
#include
int main()
SAConnection con;
SACommand cmd;
try
con.Connect("", "scott", "tiger", SA_Oracle_Client);
cmd.setCommandText(
"Create table test_tbl(fid integer, fvarchar20 varchar(20), fblob blob)");
cmd.Execute();
cmd.setCommandText(
"Insert into test_tbl(fid, fvarchar20) values (1, 'Some string (1)')");
cmd.Execute();
con.Commit();
try
con.Rollback();
// Enabling Windows XP visual effects before any controls are created
return 0;
i ve added all .a lib file in liner setting ..so plz gimme solution for this ineedly needed .
thanks
prasad.ram126
prasad.ram126 · Mar 30, 2012
Rank E1 - BEGINNER
it is nice
and if you have any tutorial related to database connectivity using c only
and using GNU complier please tell me
Preethi Gowri
Preethi Gowri · Jun 14, 2012
Rank E1 - BEGINNER
slashfear
Hi Flipmedia,
-Arvind
guys plz help me out...
im using codeblock compiler, i followed all the steps which arvind had mentioned previously..
my problem is after the succesful compilation it says libsqlapid.dll file or directory not found😔 , when i try running the code...
Sasikumar VK
Sasikumar VK · Jul 11, 2012
Rank E2 - BEGINNER
Hi Arvind,
Thanks for the tutorial..
I've followed all the procedures mentioned above & pasted your code in Code::Blocks,but it is throwing following errors..
E:\Can\datac\main.c|2|error: SQLAPI.h: No such file or directory|
E:\Can\datac\main.c||In function 'main'😐
E:\Can\datac\main.c|5|error: 'SAConnection' undeclared (first use in this function)|
E:\Can\datac\main.c|5|error: (Each undeclared identifier is reported only once|
E:\Can\datac\main.c|5|error: for each function it appears in.)|
Could you please..guide me to proceed further..
Thanks in advance..
Preethi Gowri
Preethi Gowri · Jul 12, 2012
Rank E1 - BEGINNER
check the path of your header.. else mention the whole path of your header in the include line, within double codes...
Sasikumar VK
Sasikumar VK · Jul 27, 2012
Rank E2 - BEGINNER
Preethi Gowri
Tanx Gowri..
JAI_SINGH
JAI_SINGH · Sep 4, 2012
Rank E2 - BEGINNER
Hi I have done this but when I then my cursor gets into "sqlapi.h" file and it starts blinking
class ISAClient;
class ISAConnection;
class ISACursor;
class SAMutex;
class SAConnection;
class SACommand;
struct sa_Commands;
class saOptions;
class SAParam;
class SAField;
class SAException;
class saPlaceHolder;
class SABytes;
class SALongBinary;
class SALongChar;
class SABLob;
class SACLob;
class SAValueRead;
and shows errors in the above given lines.......
Akash Agrawal
Akash Agrawal · Mar 2, 2013
Rank E2 - BEGINNER
Hi Frnds,
I am trying to connect VC++ and Oracle10 g.
But i am getting Error " LNK2019 Unresolved Externals"..
I am using VS 2008 i.e. VC9.
I have also tried with VS2012 and MySQL. But Same Error was there.
Please Help me out in this Problem.
I have also followed all the steps above but... ;( same Error... " LNK2019 Unresolved Externals" Plz Help ....
Preethi Gowri
Preethi Gowri · Mar 2, 2013
Rank E1 - BEGINNER
check this link out
rahul69
rahul69 · Mar 2, 2013
Rank B2 - LEADER
Akash Agrawal
Hi Frnds,
Could be many reasons, maybe you are using some variable without declaring, or you are using some function without including appropriate headerfile, so check ur code!
and if u still fail, then paste it here, maybe we could help😁
Good Luck!!!😀
Kaustubh Katdare · Mar 15, 2013
Rank A1 - PRO
slashfear - It'd be great to have you back on CE and take this thread forward. Looking forward to your participation again 😀
DP RWT
DP RWT · Jun 26, 2013
Rank E2 - BEGINNER
i want a project on database connectivity programming in c++ or dotnet.so plz solve my problem.
DP RWT
Rank E2 - BEGINNER
rahul69
rahul69 · Jun 30, 2013
Rank B2 - LEADER
DP RWT
Are u searching for Ideas? Well if that is the case there can be a lot of projects possible, for example:
Online Quiz Software, in which u use C++ or C# or VB for GUI creation and for back-end (ie storing databases), any SQL, and connect both to make it work, the choice of language depends on your interest.😀
Sarthak Sinha
Sarthak Sinha · Aug 20, 2015
Rank E2 - BEGINNER
can you please explain that once i populate the database...and then how can i extract data and use it in C++...
Pankaj_malviya5
Pankaj_malviya5 · Jan 12, 2016
Rank E2 - BEGINNER
I need a c program that, when given a table name and database name as arguments, will query the informix & postgresql system tables to get all permissions granted to various users on that table. The program will then generate sql statements to grant all these permissions on the table and write these statements to a file which can be run later.(AIX OS Using).
Sobhita Kumar Sahu
Sobhita Kumar Sahu · Apr 16, 2016
Rank E2 - BEGINNER
Could you please make similar tutorial OCCI.
Sobhita Kumar Sahu
Rank E2 - BEGINNER
Could you please make similar tutorial on OCCI.
skobu
skobu · Apr 20, 2016
Rank E2 - BEGINNER
Hi Guys,
Just need one confirmation from your side all those who
have run this database connectivity pgm , I wanted to know have they downloaded sqlapi_trial.exe or sqlapi_trial.tar.gz for SQLAPI++ Library............... . And also while trying to execute
the program i was getting errors in SQLAPI.h..... was anybody facing the same issue
Shiva Abhijith
Shiva Abhijith · Jul 9, 2018
Rank E1 - BEGINNER
Kaustubh Katdare · Jul 10, 2018
Rank A1 - PRO
@Shiva - Could you explain the problem you are facing so that we can help? The screenshot doesn't say much.
Shiva Abhijith
Shiva Abhijith · Jul 11, 2018
Rank E1 - BEGINNER
I runned the given program and I found those errors(in screenshot).I am unable to proceed as I can't understood those errors.
Divisha Madupalli
Divisha Madupalli · Jan 26, 2020
Rank C1 - EXPERT
This a frequent question raised here .
To use the Sql DB and Vb we must have all these downloaded in our system first so it makes our work  easier to complete:
  1. Microsoft SQL Server
  2. Visual Basic .NET
You must have a piece of knowledge on the topics :
  • ADO.NET concepts
  • SQL Server concepts and Transact-SQL (T-SQL) syntax
create a new Visual Basic Windows Application project named SQLDataAccess.
Open Form1. In the first line of Form1.vb, add a reference to the ADO.NET namespace as follows:
Imports System.Data.SqlClient
Make sure SQL is running on the server
Then,
Public Class Form1
Inherits System.Windows.Forms.Form
'Create ADO.NET objects.
Private myConn As SqlConnection
Private myCmd As SqlCommand
Private myReader As SqlDataReader
Private results As String
The SqlConnection object establishes a database connection, the SqlCommand object runs a query against the database, and the SqlDataReader object retrieves the results of the query.
Then , make a connection string :
myConn = New SqlConnection("Initial Catalog=dbname;" & _
                "Data Source=localhost;Integrated Security=SSPI;")
       'Create a Command object.
myCmd = myConn.CreateCommand
myCmd.CommandText = "SELECT FirstName, LastName FROM Employees"
'Open the connection.
        myConn.Open()
myReader = myCmd.ExecuteReader()
When the myCmd.ExecuteReader method is executed, SqlCommand retrieves two fields from the Employees table and creates a SqlDataReader object.
 To display the query results, add the following code to the
'Concatenate the query result into a string.
Do While myReader.Read()
results = results & myReader.GetString(0) & vbTab & _
myReader.GetString(1) & vbLf
Loop
'Display results.
        MsgBox(results)
Then close it :
'Close the reader and the database connection.
myReader.Close()
        myConn.Close()
Click to Log-In or Sign-Up
