A BIg Problem with dynamic memory allocation
yamrajbhalla
@yamrajbhalla-ZPvBoL โ€ข Oct 21, 2024
i declared a array of pointer *nm[10];
in class
and i need to input data in it and dynamically allocate memory for this and also i have to show the output
thanks
  • Raviteja.g
    @ravitejag-02nJVr • Mar 25, 2009
    For dynamic allocation you can use malloc( ) or calloc( ) functions .
    can't you try it.
    and it is one and only way to allocate memory dynamically in C
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Mar 25, 2009
    yamrajbhallai declared a array of pointer *nm[10];
    in class
    As you have declared the array of pointers in a class (i.e., using C++), so you can use new/delete operators for this. Consider that the array is array of integer pointers, so code will look like:
    int *nm[10] = { 0 };              //Initializing array with all poiters set to NULL
    int i = 0;
    for(i = 0; i < 10; i++) {
        nm[i] = new int;              //Dynamic memory allocation
        *(nm[i]) = <some value>       //Assigning some data
        cout<<*(nm[i])<<endl;         //Writing data to output stream
        delete nm[i];                 //Deleting allocated memory
    -Pradeep
  • ms_cs
    @ms-cs-Ab8svl • Mar 25, 2009
    What error you got?
    For me I have compiled this part.It does not show any error.
    nm = new int; //Dynamic memory allocation
    *(nm) = <some value> //Assigning some data
  • yamrajbhalla
    @yamrajbhalla-ZPvBoL • Mar 26, 2009
    thnks for the fast rpyly i did it bt a prob lm occurs always
    after running the programm
    it gives me right output bt after that c++ complier closes and a error occurs
    will u plz hlp me to sort out this problem
  • yamrajbhalla
    and by the way thanks for ur precious time to viewing myne problem
    thanks a lotttttt
    bro
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Mar 26, 2009
    yamrajbhallait gives me right output bt after that c++ complier closes and a error occurs
    Could you please update which compiler you are using? Is there any error message displayed when the compiler is closed due to error? If yes, what the message?
    Also i had given a code snippet you must have written some code around it. It will be of help in analyzing the issue if you post your code here.
    -Pradeep
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Mar 27, 2009
    ~bill()
    {delete item;}
    Above part of the code is creating problem.
    This is destructor of the class 'bill' and it is called when the object of this class is destroyed. In your case it will be called when the object 'obj' is destroyed. As the object 'obj' is statically declared in the main function of the class so it gets destroyed when the execution of the main function completes. That's why you are getting error at end of program execution. Now read below for the reason why this particular code segment is causing problem.
    When the "delete item;" statement is executed, it tries to delete the memory statically allocated for the array and hence an exception. "delete" should be done for dynamically allocated memory. In your case, "delete" should be called for elements of array. So the destructor should look like
    ~bill() {
      for(int i = 0; i <= m; i++) {
        delete item[j];
    Let us know if you face the issue after above changes.
    -Pradeep
  • Raviteja.g
    @ravitejag-02nJVr • Mar 27, 2009
    well pradeep.
    you did a good job.As i don't know much(almost negligible) about C++ i thought pointers are used only in C.
    so i gave my suggestion to use memory allocation functions which allocates memory dynamically
    but now i came to know that pointers are there in C++ too.
    Am i right?
  • just2rock
    @just2rock-DkmPtO • Mar 27, 2009
    pradeep_agrawal
    ~bill()
    {delete item;}
    ~bill() {
        delete item[j];
    -Pradeep
    can you pls be more specific about the actual code generating from this.
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Mar 29, 2009
    Raviteja.gbut now i came to know that pointers are there in C++ too.
    Am i right?
    Yes, C++ have pointers too. And it provides better and more safe ways to handle memory allocations.
    just2rockcan you pls be more specific about the actual code generating from this.
    Is there anything specific in the description for which you need more details? I have already mentioned the code snippet of actual code that is causing problem and provided a sample code to fix that.
    -Pradeep
  • yamrajbhalla
    @yamrajbhalla-ZPvBoL • Feb 4, 2023
    #include<iostream.h>
    #include<conio.h>
    #include<stdio.h>
    #include<string.h>
    #include<ctype.h>
    #include<iomanip.h>
    class bill
    char *item[5];
    int m;
    float itmamt[5];
    public:
    void additem(char name[],int i,float prc)
    item=new char[strlen(name) +1];
    strcpy(item,name);
    m=i;
    itmamt=prc;
    void display()
    for(int j=0;j<=m;j++)
    cout<<item[j]<<setw(9)<<itmamt[j];
    ~bill()
    {delete item;}
    void main()
    {float prc;
    clrscr();
    char ch='Y';
    int i=0;
    char *name;
    bill obj;
    do
    cout<<"enter the name of item\n";
    gets(name);
    cout<<"enter the price ";
    cin>>prc;
    obj.additem(name,i,prc);
    ++i;
    cout<<"Enter CH";
