Why not replace 8 cylinders in engine with one cylinder of same displacement?
Why have eight cylinders in an engine?Why not have one big cylinder of the same displacement of the eight cylinders instead?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Mar 30, 2013
    The net force required to drive the single piston will be more there by the efficiency of the system will be reduced so go for multi cylinder engines and Never single cylinder engines
  • zaveri
    @zaveri-5TD6Sk Mar 30, 2013
    for a single cylinder engine, you require a heavy and a big flywheel.
    now just think of this : how big will the flywheel of the single cylinder engine be, which has the displacement of eight cylinders ?
    and in case, this engine is for automotive use, then won't this increase the weight of the vehicle.
  • NAVATHE SACHIN
    @navathe-8fNDWG Mar 30, 2013
    Are there 8 flywheels for 8 cylinders?
  • zaveri
    N.SACHINAre there 8 flywheels for 8 cylinders?
    Oh no man ! there is only one flywheel for any I.C engine, no matter how many cylinders it has.
    what i am trying to say is that the flywheel of a multicylinder engine is far more lighter than that of single cylinder engine.
  • Gurjap
    @gurjap-blPmg9 Apr 2, 2013
    Interesting question. Obviously size is not a problem, seeing Fairbanks/Morse and Wartsila manufacture huge diesel engines larger than an average house anyway. Neither is manufacturing, because pretty much anything you want manufactured can be manufactured.
    I think the problem might be with control of the combustion chemistry and noise. Would welcome any more inputs on this thread.
  • Anand Tamariya
    @anand-tamariya-DnfjEX Apr 2, 2013
    More the number of cylinders, smoother the ride. Also, you can achieve more efficiency by reducing the number of cylinders that fire at lower RPMs and only use full capacity at higher RPMs when you need it.
  • NAVATHE SACHIN
    @navathe-8fNDWG Apr 5, 2013
    There are a couple of reasons why a big 4.0-liter engine has eight half-liter cylinders rather than one big 4-liter cylinder. The main reason is smoothness. A V-8 engine is much smoother because it has eight evenly spaced explosions instead of one big explosion. Another reason is starting <a href="https://auto.howstuffworks.com/auto-parts/towing/towing-capacity/information/fpte.htm" target="_blank" rel="nofollow noopener noreferrer">How Force, Power, Torque and Energy Work | HowStuffWorks</a>. When you start a V-8 engine, you are only driving two cylinders (1 liter) through their compression strokes, but with one big cylinder you would have to compress 4 liters instead.
  • The Observer
    @the-observer-Vms2ZU Apr 7, 2013
    do not forget the vibrations it would cause. May feel like a horse ride i suppose. the casing would also get heavy cuz of the energy it is supposed to contain. You need to have balanced masses to counter the effects its gonna cause. a 2 cyl opposed configuration engine may seem better .
  • riteshbstkr
    @riteshbstkr-RmIjjB Apr 18, 2013
    Hey Sachin
    There are so many reasons for why no use of single cylinder rather use of multicylinder
    1 there is very high friction for large single cylinder delivering high force
    hence problem of lubrication
    2 Less compression ratio obtained compared to multicylinder.
    3 very less efficiency.
    4 one cylinder have very large weight not possible to carry.
  • Ric Zambales
    @ric-zambales-vaGZNb Jan 11, 2017
    There would be problems in weight, operation and maintenance of the engine. Imagine in a diesel power plant like where I work every engine has pretty big 16 cylinders and pistons (each has 400mm bore size) and we have 21 units of it. The noise and vibrations are high. imagine those 21 units having much larger single cylinder and piston (each unit will have 6,400mm or 6.4m bore size!) and other parts. it would cause a massive vibration, less efficiency, harder maintenance (due to much more massive parts)
