  • Mohit Patil
    @mohit-n7d2qt Feb 21, 2019
    6.6A is the right answer.
  • Vontari Keerthana
    @vontari-Sryisp Feb 21, 2019
    can you explain
    @thebigk Feb 21, 2019
    #-Link-Snipped-# - Better approach would be to explain how you arrived at two different answers. Could you give it a try?
  • Vontari Keerthana
    As they are in series I1 and I3 adds.
    But as there is tapping im a little bit confused.
    So can you help me out of it.
  • Vontari Keerthana
    @vontari-Sryisp Feb 22, 2019
    #-Link-Snipped-#  please suggest what is the correct answer and complete solution.
    I have got 4.9A, but my friend is saying that it may be 6.6A.
  • Vontari Keerthana
    #-Link-Snipped-# Thanks for your answer
    @ramani-VR4O43 Feb 23, 2019
    #-Link-Snipped-# , you were right.  The tapping at the middle two resistors joining the middle of the two battery banks can be ignored because there is no potential difference between the two ends of the wire.
    Therefore, the total current will be the sum of the currents in the two parallel lines.
    The current through the two resistors in series will be 31/(9.05+9.05)=1.713 A, the current in the other line is 31/9.5=3.26 A totaling 4.976 A.
  • Vontari Keerthana
    @vontari-Sryisp Feb 23, 2019
    Thank you sir #-Link-Snipped-#Â
