  • Neeraj Sharma
    @neeraj-iAaNcG • Jun 12, 2012
    aarthivgwhat is the function of 'main' in 'c' programming?
    int main (void)
    In the above statement, void represent??
    void represents that main function is not taking any argument while its execution. You can even skip that void and write main(). main takes two arguments like main(int argc, char *argv[])
    where argc is the counter that counts the number of arguments passed to main and argv means argument vector which stores all the arguments passed in the form of a character array
  • aarthivg
    @aarthivg-HH344f • Jun 12, 2012
    I remember using as such: void main()
    whats the difference between these statement.
    void main()
    int main(void)
  • aarthivg
    Nick_Sharmavoid represents that main function is not taking any argument while its execution. You can even skip that void and write main(). main takes two arguments like main(int argc, char *argv[])
    Is arguments and parameter, both mean the same
    @anoop-kumar-GDGRCn • Jun 12, 2012
    void main() means... this function is not returning any value.
    int void main() is a illegal declaration .
    either it could be int main() , which must have a integer type return statement as last line of function
    or another type of return.
  • aarthivg
    ianoopvoid main() means... this function is not returning any value.
    sorry, its int main(void)
    aarthivgsorry, its int main(void)
    that means main function is not taking any argument and will return a integer type value.
    why should not you make some programs about your doubts.compiler itself will tell you .
  • aarthivg
    ianoopthat means main function is not taking any argument and will return a integer type value.
    ya I have too. I don't have the software๐Ÿ˜”
  • Neeraj Sharma
    aarthivgIs arguments and parameter, both mean the same
    Yeah they are same...!
  • Dancer_Engineer
    @dancer-engineer-EJ8rGI • Jun 13, 2012
    aarthivgya I have too. I don't have the software๐Ÿ˜”
    Take a look at this video:
  • silverscorpion
    @silverscorpion-iJKtdQ • Jun 13, 2012
    The function definition in C is like this..
    <return-type> function-name(<list-of-arguments>)
    Here, return-type can be of any data-type, like int or char etc.. It can also be "void" which means that function doesn't return anything.
    In the list of arguments, you can give one or more arguments (or) 'parameters' to the function. If the function doesn't take any arguments, you can specify that by writing 'void' in place of the arguments. Hence 'function-name(void)'. But usually, if a function doesn't take any arguments, it's name is simply followed by a set of parentheses, like so.. "function-name()"
  • aarthivg
    @aarthivg-HH344f • Jun 13, 2012
    return statement means?
  • Neeraj Sharma
    @neeraj-iAaNcG • Jun 13, 2012
    aarthivgreturn statement means?
    return type depicts the type of value that your function returns. return statement returns a value to the caller function. Consider following program
    main()
    int c;
    c=sum();
    printf("%d",c);
    return 0;
    int sum()
    int a=1,b=2;
    return(a+b);
    In the above program, return(a+b) is called return statement as it returns an integer value to the calling function that is main. Now as an integer value is returned, there must be a variable to hold the returned data and even that must be of the same type as the type of value returned i.e. int in this case..
  • herrey
    @herrey-bokSq9 • Jun 13, 2012
    Well how differ main from array?
    I know in C++ array are so important so can you explain its difference?
  • Neeraj Sharma
    herreyWell how differ main from array?
    There is no match between main and array. They are two different things all together. main() marks the beginning point of execution of a program whereas array is simply a collection of objects of same type which are referred under a same name whose memory is allocated statically. main() is a function whereas array is a collection of elements of the same data type
  • aarthivg
    Nick_Sharmareturn type depicts the type of value that your function returns. return statement returns a value to the caller function. Consider following program
    main()
    int c;
    c=sum();
    printf("%d",c);
    return 0;
    int sum()
    int a=1,b=2;
    return(a+b);
    return 0 implies ?
  • Neeraj Sharma
    As I have not specified any return type for main, by default it will be int. So as the system calls the main function, you are just returning a dummy integer value. It doesn't do anything..
  • aarthivg
    then getch() is used for?
  • Neeraj Sharma
    @neeraj-iAaNcG • Jun 14, 2012
    aarthivgthen getch() is used for?
    getch() is used to read a character from keyboard...
  • aarthivg
    @aarthivg-HH344f • Jun 14, 2012
    #include<stdio.h>
    #include<stdlib.h>
    int main()
    int a,b,sub;
    printf(" enter the value of a");
    scanf("%d",&a);
    printf("enter the value of b");
    scanf("%d",&b);
    sub=a-b;
    printf(" %d",&sub);
    return 0;
    just tried out a simple program.... but cant able to get the output... whats wrong in it
    for 3-2 ... getting output as 9016
  • Neeraj Sharma
    aarthivgprintf(" %d",&sub);
    Here is the mistake. & is called address operator. So when you are printing &sub, you are printing the address at which the result is stored and not the result. replace the above line with
    printf("%d",sub);
    This will make your program work perfectly..
  • aarthivg
    Nick_SharmaHere is the mistake. & is called address operator. So when you are printing &sub, you are printing the address at which the result is stored and not the result. replace the above line with
    printf("%d",sub);
    ya...thanks... got it
  • aarthivg
    what is the use of SYSTEM("PAUSE") command
  • Neeraj Sharma
    aarthivgwhat is the use of SYSTEM("PAUSE") command
    System() is used to call OS functions. System("pause") causes the DOS output screen to be held. It does the same function as getch() when used as the last line in program. If you don't write getch() or System("pause") in the earlier versions of C then the black screen just flashes and then disappears. Then you must press alt+f5 to view the output. System("pause") and getch() prevents the flashing of screen and holds it till a character is entered
  • aarthivg
    Is there a header file defined Boolean constant as stdbool.h?
    #include<stdio.h>
    #include<stdbool.h>
    int main(void)
    bool x=true;
    bool y=false;
    printf(" the boolean values are %d %d\n",x,y);
    return 0;
  • aarthivg
    @aarthivg-HH344f • Jun 17, 2012
    #include<stdio.h>
    #include<stdbool.h>
    int main(void)
    bool x=true;
    bool y=false;
    return 0;
    help me out
    Tagging #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-#
    @anoop-kumar-GDGRCn • Jun 17, 2012
    I have no idea about it... ๐Ÿ˜
  • Neeraj Sharma
    @neeraj-iAaNcG • Jun 18, 2012
    Same here. No idea. Tried searching it but with no significant answer.. Anyway the above program is not working in Turbo C++ 4.5. I downloaded stdbool.h and tried but then also there are errors...
    @abhishek-fg9tRh • Feb 16, 2013
    Sorry for bumping in old thread (Killing time);
    Yes, there's a header file defined boolean constant as stdbool.h
    1 4
    Using emacs editor & GCC 4.7
  • sulochana anand
    @sulochana-anand-OrGmKr • Mar 4, 2013
    the execution of program starts from main function.
  • bithamang
    @bithamang-9pwN1D • Mar 14, 2013
    in 11th line u should write as
    printf("%d",sub);
    only u put & before sub so it displays the address of sub
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Apr 4, 2013
    int main (void)
    The main function has two basic functions :-
    1) It allocates the memory for program.
    2) It guides the compiler, that compilation will start from the main function.
    In the statement
    int main (void); (always terminate a statement with a semicolon) ๐Ÿ˜›
    void represents that the function do not takes any arguments.
    The statement is same as
    int main(); ๐Ÿ˜€
    If you still have any doubts, feel free to ask ๐Ÿ˜
  • rahul69
    @rahul69-97fAOs • Apr 4, 2013
    Sanyam Khuranaint main (void); (always terminate a statement with a semicolon) ๐Ÿ˜›
    Not always!!๐Ÿ˜Ž Actually avoid semicolon in case of loops and conditional statements(ie if blocks)
    eg:
    int i=0;
    while (i<10);
    i++;
    . Big Blunder!!๐Ÿ˜‰๐Ÿ˜
  • lit-857
    @lit-857-hXUEGJ • Apr 4, 2013
    int main() return value to whom??
  • lit-857
    last line should be printf("%d",sub);
  • lit-857
    aarthivg#include<stdio.h>
    #include<stdlib.h>
    int main()
    int a,b,sub;
    scanf("%d",&a);
    scanf("%d",&b);
    sub=a-b;
    printf(" %d",&sub); //error//
    return 0;
  • avii
    @avii-TGGs8o • Apr 4, 2013
    lit-857int main() return value to whom??
    to the system. Or to the caller.
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Apr 5, 2013
    rahul69Not always!!๐Ÿ˜Ž Actually avoid semicolon in case of loops and conditional statements(ie if blocks)
    eg:
    int i=0;
    while (i<10);
    i++;
    haha, yes that's true, I was talking about General statements ๐Ÿ˜›
  • lit-857
    @lit-857-hXUEGJ • Apr 5, 2013
    who call the main function
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Apr 6, 2013
    lit-857who call the main function
    What do you mean?
  • Vishal Sharma
    @vishal-pysGmK • Apr 6, 2013
    actually it returns a value.. but its not specific so we call it void..
  • Vishal Sharma
    its the operating system...
    and main() is always "public" so that it is visible to the OS
    @abhishek-fg9tRh • Apr 6, 2013
    Vishal0203its the operating system...
    As per my knowledge, RTE calls the main function & not just OS.
  • lit-857
    @lit-857-hXUEGJ • Apr 6, 2013
    wts RTE and main () return value to whome???
  • Vishal Sharma
    RTE stands for run-time environment..
    main() returns value to RTE itself, indicating its status of execution
  • lit-857
    plz explain it i can't understend
  • Vishal Sharma
    @vishal-pysGmK • Apr 7, 2013
    Means, if main returns a null value, then the program is executed successfully.. 0 indicates EXIT_ON_SUCCESS
    any value other than zero indicates unusual execution..
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Apr 7, 2013
    lit-857plz explain it i can't understend
    A c program is compiled into assembly code(and finally into binary). The main() function enables the compiler to put the code present in this method as first line in the compiled version - the entry point of the program when you execute it.
  • Vishal Sharma
    main is a function and array is a collection of elements of same data type defined under same name..
    no point of getting confused here.
  • lit-857
    @lit-857-hXUEGJ • Apr 11, 2013
    wts d/f b/w celloc() and melloc() fn
  • Vishal Sharma
    @vishal-pysGmK • Apr 11, 2013
    lit-857wts d/f b/w celloc() and melloc() fn
    ummm... do you have a text Book to learn C??
    I think you must refer that.. text books are the first companions. after reading that, still you face problems in understanding, we'll help you
