@thebigk • Jun 19, 2012
Please post the full code in the post, title is just a title.
@dancer-engineer-EJ8rGI • Jun 19, 2012
If this is your code:
int a[] = {10,20,30}; System.out.println(a.length);Here 'a.length' gives the length of the array 'a'.
Vikash Verma OP
@vikash-verma-jF0MOy • Jun 19, 2012
I mean to find array length , we use arrayname.length .
What is this length variable, where it is generated, is arrayname a class,. . . -
@anoop-kumar-GDGRCn • Jun 19, 2012
I tried to find out source code for array but didn't got it. There is array class in java.lang.reflect package but that is different and similar to array functionality.
Well answer is Array is not a class. Its a reference type. There are three reference type in java class, interface and array
it is built-in JVM part and array.length is defined as
public final <variable> length. as array length is constant which stores length of array. -
#-Link-Snipped-#, you may take a look at these links:
<a href="https://docs.oracle.com/javase/tutorial/java/nutsandbolts/arrays.html" target="_blank" rel="nofollow noopener noreferrer">Arrays (The Javaโข Tutorials > Learning the Java Language > Language Basics)</a>
<a href="https://www.roseindia.net/java/master-java/Reference-Data-Types.shtml" target="_blank" rel="nofollow noopener noreferrer">Reference Data Types</a> -
@suraz-mouLU5 • Jun 19, 2012
check this out -
Vikash Verma OP
#-Link-Snipped-# you are right...๐
