VoiCE News Cover About Ultraflow Transmit Time Portable Flow-Meter
CE-InFocus
@ce-infocus-ps8QOO โ€ข Nov 14, 2024
A flow meter is a meter that essentially measures the rate of flow of liquid flowing through the pipe. Tracking the flow is of utmost importance in industrial as well as domestic sector to avoid accidents and loss of the resources. At the same time, the device must be easy to use and portable. This [...]
  • scharfautomation
    @scharfautomation-CTR3Ig • Jun 20, 2011
    Its very tough to set an ultrasonic portable flow meter at site. We had purchased one earlier but were unable to take the readings ever.
    Instead we would recommend to the electromagnetic flow meters which are far more rugged and have a very high accuracy.
    For technical details #-Link-Snipped-#.
    For Line Size selector chart w.r.t. flow range #-Link-Snipped-#.
  • Heremeter
    @heremeter-elUKX1 • Jul 6, 2011
    Portable ultrasonic flow meter has been widely in many industry and have a good reputation.
    But no matter mag-flowmeter or ultra-flowmeter,the right installing and operation should be the basic step.
    So it is necessary to learn the details of ultrasonic flow meter before using.
    You may click #-Link-Snipped-# and #-Link-Snipped-# to learn more.
    If you have any problem in ultrasonic flow meter, you may contact me please.
  • scott_white85
    @scott-white85-mvB27S • Nov 24, 2011
    just want to add info about flow meter, it is actually an instrument which measures linear, nonlinear. also used for monitoring, measuring or discharge of a fluid.
    is an industrial process control and instrumentation which is commonly used in water/wastewaster, building energy management, semi conductor industry, pharmaceutical,petrochemical, F&B. It has the capability of measuring bi-directional flow and pipe diameter.
  • Huang Ella
    @O5Z1tbR • Nov 14, 2024
    Hello, we are Flow meter, water meter, air meter, gas detector manufacturer. https://www.lnalsafe.com/, WhatsApp: +8613437856962
