Unique Electronics Switching Design Problem (Please Help)
hshah8970
@hshah8970-F1h8Ox โ€ข Oct 23, 2024
Hello everybody!
I'm working on a project and am facing a problem I simply cannot solve. I'm unable to design the electronic circuit that accomplishes the following task:
I want to couple 2 DC inputs in such a way that when Input 2 reaches certain voltage level (from zero), both inputs become connected in series. Before this threshold voltage level is reached by Input 2, we simply get Input 1 at the output. Check out #-Link-Snipped-# to see what I mean: #-Link-Snipped-#
For voltage values of DC Input 2 higher than the threshold voltage, the series combination is maintained.
I would highly appreciate it if somebody helped me out with this! Thanks! And an explanation to go along the circuit would be nice too. Again, thanks a lot to anybody who responds!
    @ramani-VR4O43 • Sep 18, 2011
    hshah8970Hello everybody!
    Why not connect source 2 in series with source 1 isolating S2 from S1 by a relay using NC contacts. Using a Zener and a transistor switch the relay using S2 at the desired voltage. Wire the NO contacts of the relay to put S2 In series.
    If S2 < set voltage, relay bypasses S2 and only S1 operates. When S2 reaches set voltage S2 switches on the relay and the NO contacts puts S2 in series.
  • hshah8970
    @hshah8970-F1h8Ox • Sep 18, 2011
    @bioramani: Thanks for your response!
    I'm a student a quite weak in electronics! I haven't dealt with relays before but I'm getting an idea of what you're saying. A rough schematic though would be immensely appreciated! Also, could you elaborate on the zener and transistor connections as control for the relay?
    hshah8970@bioramani: Thanks for your response!
    What is the voltage at which you need to put Input 2 into circuit? The choice of the Zener depends on this value.
  • hshah8970
    @bioramani: Let's say that Input 1 will be operating at 12V and Input 2 will be included when it reaches 5V.
    @ramani-VR4O43 • Sep 19, 2011
    Your circuit is the equivalent of: If V2<V(threshold), then Output = V1, Else Output = V1 + V2.
    I feel that this circuit will do the job. You may have to add a 3V Zener in series with the base resistor if you want accuracy. The circuit here uses the base-emitter forward drop to adjust the potentiometer for switching the transistor.
  • hshah8970
    @hshah8970-F1h8Ox • Sep 19, 2011
    @bioramani: Thanks a million! I'll be trying this out soon enough. May I bother you again if I've got any queries regarding this circuit?
    hshah8970@bioramani: Thanks a million! I'll be trying this out soon enough. May I bother you again if I've got any queries regarding this circuit?
    You certainly may.
