    @abrakadabra • Jul 26, 2012
    A lot of people are writing to me saying they are having a hard time finding solutions to these questions. Anyone here wants to try figuring out the answers?
  • kanwar singh
    @kanwar-singh-5i1NqD • Aug 31, 2012
    ne1 having some other set of questions?
    i have solved these questions
  • sheena.gurm
    @sheenagurm-xKA9O6 • Sep 15, 2012
    yes i want solutions to these ?s as m going to encounter thoughtworks assesmnt in october in colg placemnt
  • gowthurag
    @gowthurag-g3qiOe • Aug 22, 2013
    tell me the technic to solve logic assesment problem
  • DivyaBalsa
    @divyabalsa-uiSUwG • Oct 7, 2013
    i need answers pls
  • DivyaBalsa
    Ankita KatdareA lot of people are writing to me saying they are having a hard time finding solutions to these questions. Anyone here wants to try figuring out the answers?
    i need answers please
    @abrakadabra • Oct 7, 2013
    DivyaBalsai need answers pls
    Start putting up questions one by one OR in a list - and we will discuss the solutions here.
    @abrakadabra • Nov 20, 2013
    nomadtravelerHey Ankita!
    Can you please explain how you solved question 3?
    I believe this is the question -
    Screen Shot 2013-11-21 at 1.11.19 PM
    Step 1:
    2 + 3 = 5
    5 in Box 11
    Step 2:
    8 in Box 10
    Step 3:
    Yes. The Box number is 1, which is an odd number.
    Step 4:
    Number in Box 6 = 2
    Number in Box 2 = 6
    Therefore going to instruction 6
    Step 6:
    4 + 5 = 9
    9 in Box 11.
    Step 7:
    Box 2 and Box 9
    Step 8:
    8 !< 9
    Therefore, NO.
    Step 9:
    8 in Box 10.
    Answer is
    Box 8 has 11
    Box 11 has 9
    Solved it in a jiffy. Please correct if I am wrong.
  • nomadtraveler
    @nomadtraveler-CFztZo • Nov 21, 2013
    Thanks so much for such a quick reply! I messed up on the question numbers though ๐Ÿ˜” Calculated the sample tests as questions as well. My bad.
    I was actually referring to problem 1 and problem 2 (Image number 3)
    @abrakadabra • Nov 21, 2013
    nomadtravelerThanks so much for such a quick reply! I messed up on the question numbers though ๐Ÿ˜” Calculated the sample tests as questions as well. My bad.
    Could you share your solution with us please? We can verify it and discuss the correct solution. ๐Ÿ˜€
  • nomadtraveler
    Sure! For Problem 1, my answer was 27. Is that correct?
    nomadtravelerSure! For Problem 1, my answer was 27. Is that correct?
    A step by step solution I meant. It will be useful for fellow engineers who want to know the procedure to solve these problems. ๐Ÿ‘
    There are no correct solutions available.
  • nomadtraveler
    Emm, there has to be a correct solution. Not putting in the step by step process primarily because, if it is not the right one, I don't want others to get confused. Sure I can put it up if I know that the answer is right.
  • sharad225
    @sharad225-jwxg17 • Dec 26, 2013
    hello Ankita, Could you show us how to solve problem numbers 4, 5 and 8, please? Doing step by step would be helpful, the way you showed solution to one of the problem above in this thread. I am not talking about the sample problems. appreciate your help.
  • ushe
    @ushe-9mFaEy • Jan 21, 2014
    Could u pls solve this step by step? Thanks a ton!
  • osheen raina
    @osheen-raina-izmvD7 • Mar 20, 2014
    please help me solve these patterns.i have interview on 22nd.. my id is #-Link-Snipped-# and tell me the easy steps to crack the tech interviews as i am from non IT field.eagerly waiting for your reply
  • niksw7
    @niksw7-P2jPAo • Sep 30, 2014
    Ankita KatdareI believe this is the question -
    Step 1:
    2 + 3 = 5
    5 in Box 11
    Step 2:
    8 in Box 10
    Step 3:
    Step 4:
    Number in Box 6 = 2
    Number in Box 2 = 6
    Step 6:
    4 + 5 = 9
    9 in Box 11.
    Step 7:
    Box 2 and Box 9
    Step 8:
    8 !< 9
    Therefore, NO.
    Step 9:
    8 in Box 10.
    Answer is
    Box 8 has 11
    Box 11 has 9
    Go to statement 3. U need to start again from 3 and not just end at step 9
  • chaitanyaM
    @chaitanyam-ornvnc • Dec 2, 2014
    could you please explain me step by step procedure for this below problem...plz provide solution as early as possible,because I have exam on 5th dec,2014..
  • ANURADHAM89
    @anuradham89-QjMjWh • Mar 17, 2015
    can you plz solve the problem four
  • ANURADHAM89
    is the answer for problem 4 .............6
    @abrakadabra • Mar 17, 2015
    Anyone up for solving this problem?
    READ THESE DIRECTIONS:
    In the following problem you are told something about the result, and you must determine what the content of the boxes must have been, in order to obtain the result.
    In these problems, the expressions (number in box x) is abbreviated as (x)
    In each of the following problem no two boxes contain the same number.
    The object of the following flow-chart is to rearrange the numbers in boxes 3, 4 and 5in such a fashion that, at the end:
    Box 3 will always contain the smallest number,
    Box 5 will always contain the largest number,
    However, this flow-chart is INCORRECT. As it stands, it will not accomplish the desired purpose. Which one instruction must be changed to correct the flow-chart?
    8_1
    In order to correct this flow-chart, we must change Instruction No. ______
    So that the first box-number mentioned in it is box-number ______
    And the second box-number mentioned in it is box-number ______
    #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-#
  • Kuldeep Aggarwal
    @kuldeep-aggarwal-nDJLLU • Apr 1, 2015
    Step 1:
    2 + 3 = 5
    5 in Box 11
    Step 2:
    8 in Box 10
    Step 3:
    Step 4:
    Number in Box 6 = 2
    Number in Box 2 = 6
    Step 6:
    4 + 5 = 9
    9 in Box 11.
    Step 7:
    Box 2 and Box 9
    Step 8:
    8 !< 9
    Therefore, NO.
    Step 9:
    8 in Box 10.(I think, here we have done a little mistake, we need to put value of Box2 in Box9, i.e. 6 in Box 9)
    Answer is
    Box 8 has 11
    Box 11 has 9
    So again,
    Step 3
    No, Box number is even # => Move to step 6
    Step 6
    9 + 4(box5) = 13
    step 7
    Box 3 and Box 8
    step 8
    8 < 8 ? No, go to step 2
    step 2
    Put "5"(box 3) in Box 8.
    step 3
    Yes, Box number 3 is odd.
    Number in Box 6 = 2
    Number in Box 2 = 6
    step 6
    put 13(box 11) + 4(box 5) in box 11
    step 7
    Box 4 and Box 7
    step 8
    7 < 8 ? Yes, => END
    value in Box 8: 5
    value in Box 11: 17
    p.s.: Please correct me if I took any wrong step or misunderstood the question.
  • Kuldeep Aggarwal
    ANURADHAM89is the answer for problem 4 .............6
    I got 14.
    Step 1
    put 9(box 12) - 0(box 12) in box 2
    step 2
    Box 12 and Box 14
    step 3
    We can't let the condition be false as there is no Box 14, so we have to put "14" in box 3 to make the condition 14 == value in Box 3 be true.
    so the answer might be 14.
  • Sujith EthanHunt
    @sujith-ethanhunt-lB4z0L • May 18, 2015
    Hi Ankitha,
    I hope you are doing fine, I was just trying to solve this questions. In sample question 2 they gave answer has 11 but I'm getting 8, could you please tell me how to solve this.
    Thanks in advance.thoughtWorks 002
  • timer
    @timer-ykNyVK • May 19, 2015
    Hi Ankita,
    Can u please explain one problem from each section?
  • prachi agrawal
    @prachi-agrawal-rs3iYb • May 20, 2015
    the ans of 1st question is 20...is it correct..please provide me the solutions..needed urgently..have interview on monday..
  • ugomar
    @ugomar-7JWVKK • Jun 1, 2015
    the answer of the problem1 should be 27
  • Nitincool
    @nitincool-9iR1nh • Jun 20, 2015
    plz provide me answers on #-Link-Snipped-#
  • Jassi Kaur
    @jassi-kaur-i7ErNF • Jun 24, 2015
    see I try solving the paper and i got these as the answers Please tell if any of them is wrong
    Problem 1 ans-27
    problem 2 ans 22
    problem 3 ans 5 and 17
    problem 4 ans 8
    problem 5 ans 7
    problem 6 ans 11
    problem 7 ans 4
    and rest I have not solved
    Please tell if they are correct
  • Jassi Kaur
    Pro
    Jassi Kaursee I try solving the paper and i got these as the answers Please tell if any of them is wrong
    Problem 1 ans-27
    problem 2 ans 22
    problem 4 ans 8
    problem 5 ans 7
    problem 6 ans 11
    problem 7 ans 4
    problem 1 answer is 27 not -27 sorry for the mistake
  • DILIP KUMAR E
    @dilip-kumar-e-jbn1zM • Aug 6, 2015
    solution of problem 6-10
  • kaka ji amu
    @kaka-ji-amu-NaVTut • Aug 15, 2015
    pls give me the solution of this question
  • Vineet Agrawal
    @vineet-agrawal-TYULJO • Sep 26, 2015
    Can someone give the step-by-step solution for problem no. 6, attached here
  • Vishal Sangave
    @vishal-HumbQd • Nov 4, 2015
    Problem 1 ans-27
    problem 2 ans 22
    problem 4 ans 8
    problem 5 ans 7
    problem 6 ans 11
    problem 7 ans 4
    Same answers I got
    Problem 8 ans Largest=2 and Smallest 1
    Problem 11 ans Step to change is Step 1 First box should be 3 and then 4
  • Jacopo Marcantonio
    @jacopo-marcantonio-5asSkD • May 19, 2016
    Hi could anyone please help me with the step by step solution for problem 8,9 10.
    I cannot understand how to tackle them.
    Thanks,
    Jacopo
  • Swati_5868
    @swati-5868-5CGgDg • Jun 23, 2016
    Hi.. Can anyone please tell whats the meaning of "Change Instruction 2 : increase the sencond box number mentioned in it by 1" in sample test 2. ( Same kind of sentence is mentioned for problem 2 also) i am not able to get its meaning and i think because of which i am not able to get correct answer. Please Please reply asap.
    @abrakadabra • Jun 27, 2016
    #-Link-Snipped-# Could you post a screenshot of the problem you are trying to solve? We could understand it better that way.
  • NOOTHAN
    @noothan-3mIrbo • Jul 7, 2016
    THOUGHT WORKS is going to visit our campus soon.
    can anyone help me with more FLOWCHART based problems and CODING PROGRAMS to clear the first two rounds.
    thank you,
  • Aishwarya Mittal
    @aishwarya-mittal-yg2bqX • Jul 25, 2016
    Can anyone help me with the solution of prob-2. I got stuck in loop.Please help asap
  • Aishwarya Mittal
  • narendra hm
    @narendra-hm-2FqnmH • Jul 30, 2016
    f
  • narendra hm
    for problem 2 answer should be 19
  • Aishwarya Mittal
    @aishwarya-mittal-yg2bqX • Aug 5, 2016
    narendra hmfor problem 2 answer should be 19
    Can u give me the solution ?
  • Aishwarya Mittal
    someoneUnkownSame answers I got
    Can u provide us solution of problem statement 11 ? How u reached this conclusion? Thanks in advance!!
  • dayal1234
    @dayal1234-joKFb7 • Oct 16, 2016
    Ankita KatdareI found some questions from their logic assessment test.
    Check them here:
    escume me... i have found some solution own my own.. but still which is blank i m not able get the concept of these questions..
    please help me and responce ASAP..
    thanks
  • dayal1234
    kanwar singhne1 having some other set of questions?
    Bro i need that 5 image question which is blank how to fill tht not able to get the logic behind tht.. or can say not able to get these questins.. ๐Ÿ˜”
    teel me logic beghind it.... or mail me Solutions PLEASE
  • jayalakshmi abhinaya
    @jayalakshmi-IJJSwI • Oct 27, 2016
    hi every one๐Ÿ˜.. how do you solve that one??๐Ÿ˜”...what are the logic behind like this???๐Ÿ˜’...flow of the program could not understood myself๐Ÿ˜ณ...if any one known that logic explained ๐Ÿ‘๐Ÿ‘๐Ÿ‘
  • dayal1234
    @dayal1234-joKFb7 • Nov 15, 2016
    Jayalakshmi Jayabalhi every one๐Ÿ˜.. how do you solve that one??๐Ÿ˜”...what are the logic behind like this???๐Ÿ˜’...flow of the program could not understood myself๐Ÿ˜ณ...if any one known that logic explained ๐Ÿ‘๐Ÿ‘๐Ÿ‘
    only first type of question i understood
  • nameless129
    @nameless129-GHxbxn • Jul 11, 2017
    Step 1:
    2 + 3 = 5
    5 in Box 11
    Step 2:
    8 in Box 10
    Step 3:
    Step 4:
    Number in Box 6 = 2
    Number in Box 2 = 6
    Step 6:
    4 + 5 = 9
    9 in Box 11.
    Step 7:
    Box 2 and Box 9
    Step 8:
    8 !< 9
    Therefore, NO.
    Step 9:
    8 in Box 10.
    Answer is
    Box 8 has 11
    Box 11 has 9
    in step 9 control goes to step3. after that dont we need to slove 4,5,6... steps again?
  • Prajkta Kedare
    @prajkta-SDr9Hi • Feb 8, 2019
    DQOX-problem09.jpgI want answer of above question, any one have answer please reply quickย
