Thermal efficency of IC engine
anand017
@anand017-vyh3Hr โ€ข Oct 26, 2024
๐Ÿ˜•
Hey friends!!
i was thinking of the effect in thermal efficiency of an ic engine ..
suppose if an engine is designed for place like Rajstahn which is quite hot and if we are running that engine at cooler place like Kashmir (himalayas region). then what will be the variation in THERMAL efficency of engine...
please give me explanatory answer......
Thankyou!!!!!!
Anand
  • din_Power Engg
    @din-power-engg-GyB0DZ May 29, 2009
    First basics,โ€‹
    The thermal Efficirncy can be given as,
    ฮท th = Energy Out / Energy inโ€‹
    in this case (internal Combustion Engines) it becames, ฮท th = Work Output / Heat Supplied
    Work Output is the difference between Heat Supplied and Heat rejected
    i.e., Work output comes as = Heat supplied โ€“ Heat rejected
    Therefore, the thermal Efficiency becomes = (Heat Supplied โ€“ Heat Rejected)/ Heat Supplied
    = 1- (Heat Rejected / Heat Supplied)โ€ฆโ€ฆโ€ฆEqn 1
    The inside engine temperature, in which combustion takes place is kept as Tin and the outside atmosphere to which the heat is rejected is kept as Tout . So ideally the Eqn. 1 can be modified as,
    ฮท th = 1- (Tout / Tin)โ€ฆโ€ฆEqn 2
    The Eqn. 2 is an ideal one. But in real cases other factors like friction, etc.. also play a part. But for designing purposes only ideal cases are taken into account.
    Now, coming to your question,
    From the Eqn. 2 it is clear that the thermal Efficiency is dependent on two factors, that is outside (atmospheric) temperature and inside temperature (Engine)โ€ฆ.So, while designing an IC engine these two factors are to be taken in to accountโ€ฆ.By optimizing any one of the factors the efficiency can be maintained throughout or improved furtherโ€ฆ.as in your question, and in general the outside temperature will not be same everywhere (not Rajasthan and Kashmir, it may not exactly be the same between even 100 m distance for even 1 minute)โ€ฆSo, the IC engines is not designed considering the outside temperature, but designed keeping the inside combustion temperature (Tin) and other factors like heat added by friction, load etc.. in consideration.
    Even in ideal case, generally the inside temperature will be much higher, somewhere between 800 โ€“ 1000 degree Celsius than the ambient temperature, some where between - 10 to 60 degree (though the average figure will be some where between 15 โ€“ 35 degree Celsius)โ€ฆ so there wont be much difference in the ratios of the temperature, resulting insignificant difference in the efficiency valuesโ€ฆโ€ฆ
    But in colder conditions, there may some other problems like starting trouble, choking, etcโ€ฆ.which are due to completely different reasonsโ€ฆ..
  • ShrinkDWorld
    @shrinkdworld-WWdBBc May 29, 2009
    good explanatin din
  • jhbalaji
    @jhbalaji-AH60JJ Jul 25, 2009
    Draw up a heat balance sheet mate...
