The CE Coding Challange
Sanyam Khurana
@sanyam-Nl7Zqc โ€ข Oct 26, 2024
Yeah, it's time to code, here give your tricky questions on Programming, and we will all try to do that.
This would improve your thinking ability and refine your logic.
First we would have some simple questions and then move to more tricky ones.
I would like to roll the dice first.
Q1. Write a Program in C/C++ to print a statement ( say "Hello World") without using a semicolon (in the entire program).
Q2. Write a Program to add two numbers without using "+" .
Q3. Write a Program to multiply two numbers without using "*" .
Now that was a bit kiddish, don't worry, now let's face some questions which are more tricky
-> Write a Program that print it's own source code ie it would then recompile and run itself !
PS :- Though you may find solutions to the above questions googling them, but it would ruin the craziness .
This thread is created so that everyone can learn and improve their programming.
And keep adding more questions to this thread..!!
_______________________________________________________________________
Edit : While answering the questions, please explain the logic also, it would help others in understanding what you have done and others can also learn more stuff.
  • avii
    @avii-TGGs8o • Sep 6, 2013
    Please explain me how does printing Hello World without semi colon improves my logic ?
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Sep 7, 2013
    aviiPlease explain me how does printing Hello World without semi colon improves my logic ?
    Is not just about printing hello world but its more than that
    of course for printing something without semi colon you have to think differently which would improve your logic
    try all the questions and choose them
    lets see who does that and if these questions seems kiddish to you don't worry we will move to more complex questions soon.......
  • Vishal Sharma
    @vishal-pysGmK • Sep 7, 2013
    I think the program will run unconditionally and infinitely if it recompiles itself and runs the exe generated.
    Here's my code there is some problem with process leaving the control of Untitled1.exe and go to recompiled.exe but it works fine.
    (Assuming that the gcc compiler already has a path in variables)
    #include<stdlib.h>
    #include<stdio.h>
    #include<windows.h>
    int main() {
        printf("source code, recompile, display output\n\n");
        system("type Untitled1.cpp");
        Sleep(500);
        system("g++ -o recompiled Untitled1.cpp");
        Sleep(1000);              // stabilizing time
        system("recompiled.exe");
        return 0;
  • Vishal Sharma
    Q1. Write a Program in C/C++ to print a statement ( say "Hello World") without using a semicolon.
    #include<stdio.h>
    int main()
        if(printf("I don't have semi colon"))
              fflush(stdin);
              getchar();
  • Vishal Sharma
    #include<stdio.h>
    void multi(int,int);
    int main()
        int a = 40,b = 30;
        if(a>b)
            multi(a,b);
        else
            multi(b,a);
    void multi(int greater, int smaller) {
        int ans = 0;
        while(smaller != 0) {
            ans += greater;
            smaller--;
        printf("%d",ans);
  • Vishal Sharma
    #include<stdio.h>
    int main()
        int a = 32,b = 15;
        while( b != 0) {
            int c = a & b;
            a = a ^ b;
            b = c << 1;
        printf("%d",a);
  • Vishal Sharma
    Adding another question here!!
    write a program to swap all the occurrences of 0 to the end of the array!
    ex:
    input -> 1,0,2,0,3,0,4
    output -> 1,2,3,4,0,0,0
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Sep 8, 2013
    Vishal0203
    #include<stdio.h>
    int main()
              fflush(stdin);
              getchar();
    Actually your code shouldn't use any semi colon.
    So, it would be something like this..
    #include<stdio.h>
    int main()
    Your logic is right, just there wouldn't be any code in between the if statement.
    I would also like to request you to edit your above posts and explain the logic you used too, it would help many newbies, and other people.
  • Vishal Sharma
    @vishal-pysGmK • Sep 8, 2013
    Sanyam KhuranaActually your code shouldn't use any semi colon.
    #include<stdio.h>
    int main()
    I printed the statement without using semi colon. I don't think it needs to be pointed out
    the code i've written inside if block is just to make it stay
    anyway,
    another way to do that (it satisfies your rules)
    #include<stdio.h>
    int main()
        switch(printf(" hello mere doston :P "))
  • Sanyam Khurana
    Vishal0203Adding another question here!!
    ex:
    I have designed this code for 10 elements and would work as given.
    #include<iostream.h>
    #include<conio.h>
    void main()
    int a[10],i,j,b[10],count;
    clrscr();
    for(i=0;i<10;i++)
    cin>>a[i];
    for(i=0,j=0;i<10;i++)
        if(a[i]!=0)
          b[j]=a[i];
          j++;
        else
        count++;
    for(i=j;i<10;i++)
    b[i]=0;
    for(i=0;i<10;i++)
    cout<<b[i];
    getch();
  • Vishal Sharma
    Sanyam KhuranaI have designed this code for 10 elements and would work as given.
    #include<conio.h>
    void main()
    clrscr();
    for(i=0;i<10;i++)
    cin>>a[i];
        if(a[i]!=0)
          b[j]=a[i];
          j++;
        else
        count++;
    for(i=j;i<10;i++)
    b[i]=0;
    for(i=0;i<10;i++)
    cout<<b[i];
    getch();
    You need to swap the values instead of taking a separate array!
    I mean the changes are to be made within the array which is used to take input from user
  • Sanyam Khurana
    Vishal0203I printed the statement without using semi colon. I don't think it needs to be pointed out
    Sorry, the question was actually that you don't have to use semi colon anywhere in the entire program. ๐Ÿ˜€
    PS:- I know I forgot to mention it clearly that you can't use the semicolon in the entire program , no problem, I'm going to edit that ...!!!
    Sorry for that, but please explain all your programs too...
    Vishal0203You need to swap the values instead of taking a separate array!
    Ok, will work on it..
  • Vishal Sharma
    2 of my programs are self explanatory, i'll add tags to my addition program
  • Sanyam Khurana
    Ok, will work on it...
    Vishal0203
    #include<stdio.h>
    int main()
        int a = 32,b = 15;
        while( b != 0) {
            int c = a & b;
            a = a ^ b;
            b = c << 1;
        printf("%d",a);
    Can you explain this program, I'm not getting what you have done here....
    basically these three lines of code is what I need to understand..
    I have never seen this before ๐Ÿ˜”
     int c = a & b;
            a = a ^ b;
            b = c << 1;
    Thanks in advance..!!
  • Vishal Sharma
    Sanyam KhuranaOk, will work on it...
     int c = a & b;
            a = a ^ b;
            b = c << 1;
    I am just operating on the bits... I'll explain this in detail!
    I'll take a few small numbers to give an explanation..
    Say, a = 9 (1001 in binary) and b = 3 (0011 in binary)
    the variable c here indicates the carry. if I perform AND operation on a & b
    i.e. c = a & b;
    it executes like this,
    1 0 0 1
    0 0 1 1
    0 0 0 1 (performing AND operation according to truth table)
    hence the carry i.e. c = 1 (0001 in binary)
    the next step is a = a ^ b where we are performing XOR operation on bits to calculating sum without adding the carry
    i.e.
    1 0 0 1
    0 0 1 1
    1 0 1 0 (performing XOR operation according to #-Link-Snipped-#)
    hence value of a = 10 (1010 in binary)
    the next step is b = c << 1 (left shift of c)
    as we saw above c = 1 (0001) after left shift it becomes (0010) viz stored in b
    so at 1st iteration a = 10 , b = 2 , c = 1
    since it is in loop, we perform the 1st operation again i.e. c = a & b
    at this step, the value of a = 1 0 1 0 and b = 0 0 1 0
    so c becomes
    1 0 1 0
    0 0 1 0
    0 0 1 0
    hence c = 2 (0010 in binary)
    i.e.
    1 0 1 0
    0 0 1 0
    1 0 0 0
    therefore, a = 8 (1000 in binary)
    next step b = c << 1 i.e. b = 0 1 0 0
    so at 2nd iteration a = 8 , b = 4 , c = 2
    again in next iteration, c = a & b
    1 0 0 0
    0 1 0 0
    0 0 0 0
    i.e. c = 0
    next step, a = a ^ b
    1 0 0 0
    0 1 0 0
    1 1 0 0
    i.e a = 12
    next step, b = c << 1;
    i.e. b = 0;
    since b = 0, loop breaks and value of a i.e. 12 is printed and that's the answer ๐Ÿ˜€
  • Vishal Sharma
    @#-Link-Snipped-# take time to read it and keep a paper and pen with you ๐Ÿ˜‰
  • simplycoder
    @simplycoder-NsBEdD • Sep 8, 2013
     int c = a & b;
            a = a ^ b;
            b = c << 1;
    Basically this is the same as full adder. where c is the carry.
    ex:
    I didn't find time to write a code, but here is an algorithm which I would use.
    Keep an counter of non-zero numbers(n), this would either be less or equal to numbers entered(m).
    print all the numbers the way they are and then print (m-n) zeroes.
  • Vishal Sharma
    treat 0 as highest number(replace 0 with infinity.. (if its an int array, treat 0 as 4294967295 and so).
    Sort in descending order and once we know the correct place, replace infinity by 0
    I think we can sort it normally!?
  • simplycoder
    Vishal0203I think we can sort it normally!?
    My bad, I have edited my previous post, your problem never said sorting, it was my wrong assumption, refer to above edited post.
  • Vishal Sharma
    simplycoderMy bad, I have edited my previous post, your problem never said sorting, it was my wrong assumption, refer to above edited post.
    hehe but i gave an example ๐Ÿ˜› anyway lets see if anyone tries your algorithm!
  • Sanyam Khurana
    Ok, it's done..!
    ๐Ÿ˜›
    Here it is, just removed the second array and used first array itself..
    #include<conio.h>
    void main()
    int a[10],i,j,count;
    clrscr();
    for(i=0;i<10;i++)
    cin>>a[i];
        if(a[i]!=0)
          a[j]=a[i];
          j++;
        else
        count++;
    for(i=j;i<10;i++)
    a[i]=0;
    for(i=0;i<10;i++)
    cout<<a[i];
    getch();
  • Sanyam Khurana
    I think, count isn't required in this case, so it can be ignored and the else part too..
    The code would work fine without these also...
  • Sanyam Khurana
    Ok, tell the output of this code
    and reason too for your answer
    #include<stdio.h>
    #include<conio.h>
    void main()
    int a=-29, b=-3;
    printf('%d",a%b);
    getch();
    I know, vishal and crazycoder would immediately answer this.. ๐Ÿ˜›
  • Vishal Sharma
    Sanyam KhuranaOk, it's done..!
    ๐Ÿ˜›
    #include<conio.h>
    void main()
    clrscr();
    for(i=0;i<10;i++)
    cin>>a[i];
        if(a[i]!=0)
          a[j]=a[i];
          j++;
        else
        count++;
    for(i=j;i<10;i++)
    a[i]=0;
    for(i=0;i<10;i++)
    cout<<a[i];
    getch();
    I'm sorry but you need to swap...
  • simplycoder
    @#-Link-Snipped-#
    #include<iostream>
    using namespace std;
    #define total_count 10
    int arr_numbers[total_count];
    int main(int argc,char**argv)
        int non_zero_count=0; // Count non-zero numbers.
        int index;
        // Take the input.
        for(index=0; index<total_count;index++)
            cin>>arr_numbers[index];
        // Print only the nonzero number.
        for(index=0; index<total_count; index++)
            if(arr_numbers[index])
                cout<<arr_numbers[index];
                non_zero_count++;
        // Print the 0s
        for(index=0; index<total_count-non_zero_count; index++)
            cout<<"0";
        // Program end.
        cout<<endl;
        return 0;
  • Vishal Sharma
    Sanyam KhuranaOk, tell the output of this code
    #include<stdio.h>
    #include<conio.h>
    void main()
    int a=-29, b=-3;
    printf('%d",a%b);
    getch();
    So lets wait for others to answer this! ๐Ÿ˜‰
  • Vishal Sharma
    simplycoder@#-Link-Snipped-#
    #include<iostream>
        int index;
        // Take the input.
                non_zero_count++;
        // Print the 0s
            cout<<"0";
        // Program end.
        cout<<endl;
        return 0;
    umm... It gives the output but doesn't change the array... The question says "swap" , means the entire array will be modified
    ex:
    if array is
    1 0 2 0 3 0 4 0 5 0
    then after performing the sort
    the array will become
    1 2 3 4 5 0 0 0 0 0
  • Sanyam Khurana
    Vishal0203I'm sorry but you need to swap...
    oops..
    Sorry, my bad..
    just forgot that it says swap..
    but what's the use of sort here..?
    Why do we have to sort..?
    Can't we just swap the element which is equal to zero?๐Ÿ˜
  • Vishal Sharma
    Sanyam Khuranaoops..
    Sorry, my bad..
    means the same!
    actually changes need to be made in array itself and the final result of array will be the array itself after the sort
    if array is
    1 0 2 0 3 0 4 0 5 0
    1 2 3 4 5 0 0 0 0 0
  • simplycoder
    #include<stdio.h>
    #include<conio.h>
    void main()
    int a=-29, b=-3;
    printf('%d",a%b);
    getch();
    Its pretty simple if we think this as math question.
    1) '/' operator would give quotient.
    2) '%' operator would give remainder.
    3) Dividend=Divisor*Quotient+remainder
    4) a=b*(a/b)+(a%b)
    Don't discard b's in b*(a/b)!!
    => a/b gives -29/-3 = 9
    b*(a/b) gives -3*9=-27
    hence a%b=-2.
  • avii
    @avii-TGGs8o • Sep 8, 2013
    Sanyam KhuranaIs not just about printing hello world but its more than that
    Did I say these are kiddish ?
    Printing hello world in C without semi colons just shows how good your knowledge in C. It does not improve your logic. If you are targeting to end up working in companies like Infosys, Wipro, continue doing these. These will help you clear the placements.
    But if you think beyond them, for companies like Microsoft, Google etc, then start solving actual problem which will just f*ck your brains out. Something like this :
    The prime 41, can be written as the sum of six consecutive primes:
    41 = 2 + 3 + 5 + 7 + 11 + 13
    This is the longest sum of consecutive primes that adds to a prime below one-hundred.
    The longest sum of consecutive primes below one-thousand that adds to a prime, contains 21 terms, and is equal to 953.
    Which prime, below one-million, can be written as the sum of the most consecutive primes?
    This is 50th problem from project euler.
    Just today I finished interviewing bunch of people who probably were same like you guys. I am like, man, I don't give two f*cks about whether you do it in C or Java, I just want to know how you do it. They happily answer how to swap two numbers without using temp variable and all that stuff. Fact is, I don't care. And good companies or start ups don't care.
    Don't worry about languages. Think in terms of algorithms. Stop solving 'Tricky C questions' etc. Start doing, 'tricky questions'. Which are agonistic to any language. Your solution shouldn't be dependent on language.
    Anyways, these are my two cents. You may absolutely ignore my advice. Best of luck.
    @abhishek-fg9tRh • Sep 8, 2013
    See, Knowledge of language is equally important as logic. Many people in world are good at logic, but they can't program.
    How would be the situation if a man can solve most trickiest query on paper, but couldn't program the shit ?
    All I mean is, both are equally important.
    And BTW, no need to flame on eachother, guys. Calm down.
    Don't like the thread ? Ignore it & move further. There is no need to give free suggestions to anyone until it's asked.
    Peace!
  • Vishal Sharma
    the prime number is 9384209 ?????
    can anyone confirm this answer??
    Nope. Because 9,384,209 > 1,000,000.
  • Vishal Sharma
    Abhishek RawalNope. Because 9,384,209 > 1,000,000.
    oh shit i took it for 10,000,000 ๐Ÿ˜› my bad
    then is it 958577 ???
  • Sanyam Khurana
    aviiDid I say these are kiddish ?
    What I wanted to say is, I'm not a good programmer, not I'm a pro at forming algorithms, but we all have to start somewhere. So, I started this thread (as a learning opportunity), so that people like me, could grab the basic things first. I can't really code a bigger thing in one shot, if I'm even not clear with my basics.
    Sorry, if you got offended.
  • Vishal Sharma
    Sanyam KhuranaWhat I wanted to say is, I'm not a good programmer, not I'm a pro at forming algorithms, but we all have to start somewhere. So, I started this thread (as a learning opportunity), so that people like me, could grab the basic things first. I can't really code a bigger thing in one shot, if I'm even not clear with my basics.
    it's okay guys forget about it!
    and please confirm the answer i got? ๐Ÿ˜ฒ
  • Vishal Sharma
    ex:
    Answer to the above question!!
    #include<stdio.h>
    int n,a[15];
    void sorter();
    int main()
        printf("Enter the no. : ");
        scanf("%d",&n);
        printf("Enter the numbers : ");
        for(int i = 0 ; i < n ; i++) {
          scanf("%d",&a[i]);
        sorter();
        printf("sorted! \n");
            printf("%d",a[i]);
        fflush(stdin);
        getchar();
        return 0;
    void sorter() {
        //swapping only when 2 adjacent elements are not zero
            if(a[i] == 0 && a[i+1] != 0) {
                  int temp = a[i];
                  a[i] = a[i+1];
                  a[i+1] = temp;
                  if(i == 0)
                      i -= 1;
                  else
                      i -= 2;     // a proper decrement of index to reduce the no of comp
        //if 2 adjacent elements are zero, toggle through array until two adj elements
        // are non-zero
            if(a[i] == 0 && a[i+1] == 0) {
                continue;
  • Sanyam Khurana
    Here's one more..
    Write a Program to print all Pythagorean Triplets that occur between 100 and 900.
    PS: Pythagorean Triplets are the numbers which satisfy Pythagoras Theorem, Example is 3,4,5.
  • Vishal Sharma
    Sanyam KhuranaHere's one more..
    Do you mean all a,b,c values above 100 and below 900 ?
  • Sanyam Khurana
    Vishal0203Do you mean all a,b,c values above 100 and below 900 ?
    Yes, we want Pythagorean Triplets..
    Which means you have to print all the three values between 100 to 900 ...
  • Vishal Sharma
    @vishal-pysGmK • Sep 9, 2013
    Sanyam KhuranaYes, we want Pythagorean Triplets..
    I dont think we have any triplet with all 3 numbers between 100 to 900
    any way here's my code that gives you triplets up to 900
    #include<stdio.h>
    #include<stdlib.h>
    int main() {
        int a,b,c;
        for(int i = 1 ; i <= 200 ; i++) {
            int m = i;
            int n = i+1;
            a= n*n - m*m;
            b = 2*m*n;
            c = m*m + n*n;
            if(c > 900)
                break;
            printf("%d, %d, %d\n",a,b,c);
        return 0;
  • Sanyam Khurana
    @sanyam-Nl7Zqc • Sep 9, 2013
    Find the product of Pythagorean Triplet whose sum is 1000.
    It's just unique.
    PS: I just finished doing this one..!
  • Sanyam Khurana
    Sanyam KhuranaQ3. Write a Program to multiply two numbers without using "*" .
    What I did for this one is
    #include<conio.h>
    void main()
    int a,b,c;
    clrscr();
    cout<<"Enter two numbers";
    cin>>a>>b;
    for(i=0;i<b;i++)             //Edited...
    c+=a;
    cout<<c;
    getch();
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Sep 9, 2013
    @#-Link-Snipped-#
    #include<conio.h>
    void main()
    int a,b,c;
    clrscr();
    cin>>a>>b;
    for(i=0;i<b;i++)    // Condition has to be this
    c+=a;
    cout<<c;
    getch();
    Am I not right
    Cos it has to be added from 0 to N-1 or from 1 to N
  • Sanyam Khurana
    Jeffrey Samuel@#-Link-Snipped-#
    #include<conio.h>
    void main()
    int a,b,c;
    clrscr();
    cin>>a>>b;
    c+=a;
    cout<<c;
    getch();
    Am I not right
    Yup you are right ...
    This time didn't copied code, but just wrote it, and by mistake I wrote that equality sign.
    If we do add equality sign, then the loop will run one more time, so if we are multiplying 5*3, it would give 5*4.
  • Sanyam Khurana
    Adding one more...
    Although I have done this, but my code was inefficient if the value is large, I Want to know a better way of doing this..(can't find a way to have a loop)
    Ok, question is..
    Find the smallest positive number which is divisible by numbers from 1 to 20.
  • Sanyam Khurana
    Vishal0203I dont think we have any triplet with all 3 numbers between 100 to 900
    #include<stdio.h>
    #include<stdlib.h>
    int main() {
        int a,b,c;
            int m = i;
            int n = i+1;
            a= n*n - m*m;
            b = 2*m*n;
            c = m*m + n*n;
            if(c > 900)
                break;
        return 0;
    It is printing triplets even like 3,4,5 and 5,12,13...
    We wanted from 100 to 900...
  • rahul69
    @rahul69-97fAOs • Sep 9, 2013
    int checkint(int f)
    for(int i=100;i<900;i++)
    if((i*i)==f)
    return i;
    return 0;
    main()
      int a,b,c;
      int f,sq;
    for(int i=100;i<700;i++)
      a=i;
              for(int j=i+1;j<700;j++)
                    b=j;
                    f= ((a*a)+(b*b));
                      sq=checkint(f);
                      if(sq)
                        c=sq;
                      else
                        c=999;
                      if(c<900)
                        cout<<"\n"<<a<<"\t"<<b<<"\t"<<c;
  • rahul69
    Sanyam KhuranaFind the product of Pythagorean Triplet whose sum is 1000.
    It's just unique.
    31875000?
