Struts in eclipse
Nikumbh
@nikumbh-lmTCgS โ€ข Oct 22, 2024
Hi Folks,
Whenever i start creating a dynamic web application, I ended up with the following error
type Status report
message /StrutsHelloWorld
description The requested resource (/StrutsHelloWorld) is not available.
Could you please help me where i'm making mistake. Well Thanks in advance
NOTE: I'm using Eclipse INDIGO f
    @anoop-kumar-GDGRCn • Jun 23, 2013
    Paste your directory structure and struts.xml here.
    Looks like action path given in struts.xml not correct. if possible upload you project.
  • Nikumbh
    @nikumbh-lmTCgS • Jun 23, 2013
    @ianoopI don't know how to upload the directory
  • Nikumbh
    <!-- index. jsp -->
    <%@ page language="java" contentType="text/html; charset=UTF-8"
        pageEncoding="UTF-8"%>
        <%@ taglib prefix="s" uri="/struts-tags"%>
    <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "https://www.w3.org/TR/html4/loose.dtd">
    <html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
    <title>Insert title here</title>
    </head>
    <body>
    <h1>Hello World From Struts2</h1>
      <form action="hello">
          <label for="name">Please enter your name</label><br/>
          <input type="text" name="name"/>
          <input type="submit" value="Say Hello"/>
      </form>
    </body>
    </html>
    <!-- HelloWorld.jsp -->
        <%@ taglib prefix="s" uri="/struts-tags" %>
    <html>
    <head>
    </head>
    <body>
    Hello World, <s:property value="name"/>
    </body>
    </html>
  • Nikumbh
    //HelloWorldAction.java
    package com.tutorialspoint.struts2;
    public class HelloWorldAction {
        private String name;
          public String execute() throws Exception {
              return "success";
          public String getName() {
              return name;
          public void setName(String name) {
              this.name = name;
    // web.xml
    <?xml version="1.0" encoding="UTF-8"?>
    <web-app xmlns:xsi="https://www.w3.org/2001/XMLSchema-instance" xmlns="https://java.sun.com/xml/ns/javaee" xmlns:web="https://java.sun.com/xml/ns/javaee/web-app_2_5.xsd" xsi:schemaLocation="https://java.sun.com/xml/ns/javaee https://java.sun.com/xml/ns/javaee/web-app_3_0.xsd" version="3.0">
      display-name>Struts 2</display-name>
      <welcome-file-list>
          <welcome-file>index.jsp</welcome-file>
      </welcome-file-list>
      <filter>
          <filter-name>struts2</filter-name>
          <filter-class>
            org.apache.struts2.dispatcher.FilterDispatcher
          </filter-class>
      </filter>
      <filter-mapping>
          <url-pattern>/*</url-pattern>
      </filter-mapping>
    </web-app>
    //struts.xml
    <!DOCTYPE struts PUBLIC
      "-//Apache Software Foundation//DTD Struts Configuration 2.0//EN"
      "https://struts.apache.org/dtds/struts-2.0.dtd">
    <struts>
    <constant name="struts.devMode" value="true" />
      <package name="helloworld" extends="struts-default">
          <action name="hello"
                class="com.tutorialspoint.struts2.HelloWorldAction"
                method="execute">
                <result name="success">/HelloWorld.jsp</result>
          </action>
      </package>
    </struts>
  • Nikumbh
    #-Link-Snipped-# Am I able to clear you?
    structure seems fine but problem with struts that what is working in Struts 2.X.2 may not work in struts 2.x.11. I have faced similar issue.
    Can you try this tutorial they have mentioned particular struts library also?
    If not I have working project, I will upload from home.
  • Nikumbh
    Could you please upload the code you're having at home, if it doesn't follow the maven plugin. Well #-Link-Snipped-# Thanks mate...๐Ÿ˜€
    @anoop-kumar-GDGRCn • Jun 24, 2013
    Find attachment and add following to your lib path from struts 2.3 libraries
      struts2-core.jar
          freemarker.jar
          xwork-core.jar
          ognl.jar
          commons-fileupload.jar
          commons-lang.jar
          commons-io.jar
    This should work. I have tested it.
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Jun 24, 2013
    Where have you done the mapping for StrutsHelloWorld ?
  • Nikumbh
    @nikumbh-lmTCgS • Jun 24, 2013
    ianoopFind attachment and add following to your lib path from struts 2.3 libraries
      struts2-core.jar
          freemarker.jar
          xwork-core.jar
          ognl.jar
          commons-lang.jar
          commons-io.jar
    Thank You very much mate. ๐Ÿ˜€
  • Nikumbh
    Anand TamariyaWhere have you done the mapping for StrutsHelloWorld ?
    #-Link-Snipped-# : Thank you very much for your reponse.... But i've found the solution by the #-Link-Snipped-# 's reponse. Anyways thank you very much buddy.
  • Nikumbh
      struts2-core.jar
          freemarker.jar
          xwork-core.jar
          ognl.jar
          commons-lang.jar
          commons-io.jar
    #-Link-Snipped-# FYI:
    Previously i didn't have the
    freemarker.jar, xwork-core.jar in my libraries list. But it works
    perfect now... Thanks again dude...
    ๐Ÿ‘
