spi to mmc
i got a working code for pic uc(18f4520) from the net.
i have also tried the example code on the mikroC pro for pic , index but i am not able to write into the memory card.
i am doing an academic project can someone please help me out with this and guide me if possible
thankyou,
The source codes are:
1:
SD CARD PROJECT
In this project a SD card is connected to PORTC as follows:
CS RC2
CLK RC3
DO RC4
DI RC5
The program opens a file called Test.TXT on the SD card
and writes the string "Writing to SD Card..." to this file.
Author: studentcompanion.co.za
Date: July 2013
File: Test.C
char filename[] = "Test.TXT";
unsigned char txt[] = "Writing complete to SD Card...";
// MMC module connections
sbit Mmc_Chip_Select at LATC2_bit; // for writing to output pin always use latch (PIC18 family)
sbit Mmc_Chip_Select_Direction at TRISC2_bit;
void main()
UART1_Init(9600);
// Initialise the SPI bus
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV16,_SPI_DATA_SAMPLE_MIDDLE,
_SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
// use fat16 quick format instead of init routine if a formatting is needed
if (Mmc_Fat_Init() == 0)
UART1_Write_Text("mmc fat initialised");
// reinitialize spi at higher speed
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
Mmc_Fat_Assign(&filename, 0x80); // Find existing file or create a new one
Mmc_Fat_Rewrite();
Mmc_Fat_Write(txt,21);
for(;๐;
2:
* Project name:
Mmc_Fat16_Test(Demonstration of usage of Mmc_Fat16 library)
* Copyright:
(c) MikroElektronika, 2012
* Revision History:
20081218:
- initial release;
20111012;
- revision (JK);
* Description:
This project consists of several blocks that demonstrate various aspects of
usage of the Mmc_Fat16 library. These are:
- Creation of new file and writing down to it;
- Opening existing file and re-writing it (writing from start-of-file);
- Opening existing file and appending data to it (writing from end-of-file);
- Opening a file and reading data from it (sending it to USART terminal);
- Creating and modifying several files at once;
- Reading file contents;
- Deleting file(s);
- Creating the swap file (see Help for details);
* Test configuration:
MCU: PIC18F45K22
Dev.Board: EasyPIC7
Oscillator: HS-PLL, 32.00000 MHz
Ext. Modules: ac:MMC-SD_Board on PORTC
SW: mikroC PRO for PIC
* NOTES:
- Make sure that MMC card is properly formatted (to FAT16 or just FAT)
before testing it on this example.
- Connect RS232 cable and turn on RS232 switches SW1.1 and SW2.1 (board specific).
- This example expects MMC card to be inserted before reset, otherwise,
the FAT_ERROR message is displayed.
sbit Mmc_Chip_Select at LATC0_bit; // for writing to output pin always use latch (PIC18 family)
sbit Mmc_Chip_Select_Direction at TRISC0_bit;
// eof MMC module connections
const LINE_LEN = 43;
char err_txt[20] = "FAT16 not found";
char file_contents[LINE_LEN] = "XX MMC/SD FAT16 library by Anton Rieckert\n";
char filename[14] = "MIKRO00x.TXT"; // File names
unsigned short loop, loop2;
unsigned long i, size;
// UART1 write text and new line (carriage return + line feed)
void UART1_Write_Line(char *uart_text) {
UART1_Write_Text(uart_text);
UART1_Write(13);
UART1_Write(10);
// Creates new file and writes some data to it
void M_Create_New_File() {
filename[7] = 'A';
Mmc_Fat_Set_File_Date(2010, 4, 19, 9, 0, 0); // Set file date & time info
Mmc_Fat_Assign(&filename, 0xA0); // Find existing file or create a new one
Mmc_Fat_Rewrite(); // To clear file and start with new data
for(loop = 1; loop <= 99; loop++) {
UART1_Write('.');
file_contents[0] = loop / 10 + 48;
file_contents[1] = loop % 10 + 48;
Mmc_Fat_Write(file_contents, LINE_LEN-1); // write data to the assigned file
// Creates many new files and writes data to them
void M_Create_Multiple_Files()
for(loop2 = 'B'; loop2 <= 'Z'; loop2++) {
UART1_Write(loop2); // signal the progress
filename[7] = loop2; // set filename
Mmc_Fat_Assign(&filename, 0xA0); // find existing file or create a new one
for(loop = 1; loop <= 44; loop++) {
// Opens an existing file and rewrites it
void M_Open_File_Rewrite() {
filename[7] = 'C';
Mmc_Fat_Assign(&filename, 0);
Mmc_Fat_Rewrite();
for(loop = 1; loop <= 55; loop++) {
// Opens an existing file and appends data to it
// (and alters the date/time stamp)
void M_Open_File_Append() {
filename[7] = 'B';
Mmc_Fat_Set_File_Date(2010, 4, 19, 9, 20, 0);
Mmc_Fat_Append(); // Prepare file for append
Mmc_Fat_Write(" for mikroElektronika 2010\n", 27); // Write data to assigned file
// Opens an existing file, reads data from it and puts it to UART
void M_Open_File_Read() {
char character;
filename[7] = 'B';
Mmc_Fat_Reset(&size); // To read file, procedure returns size of file
for (i = 1; i <= size; i++) {
Mmc_Fat_Read(&character);
UART1_Write(character); // Write data to UART
// Deletes a file. If file doesn't exist, it will first be created
// and then deleted.
void M_Delete_File() {
filename[7] = 'F';
Mmc_Fat_Assign(filename, 0);
Mmc_Fat_Delete();
// Tests whether file exists, and if so sends its creation date
// and file size via UART
void M_Test_File_Exist() {
unsigned long fsize;
unsigned int year;
unsigned short month, day, hour, minute;
unsigned char outstr[12];
filename[7] = 'B'; //uncomment this line to search for file that DOES exists
// filename[7] = 'F'; //uncomment this line to search for file that DOES NOT exist
if (Mmc_Fat_Assign(filename, 0)) {
//--- file has been found - get its create date
Mmc_Fat_Get_File_Date(&year, &month, &day, &hour, &minute);
UART1_Write_Text(" created: ");
WordToStr(year, outstr);
UART1_Write_Text(outstr);
ByteToStr(month, outstr);
WordToStr(day, outstr);
WordToStr(hour, outstr);
WordToStr(minute, outstr);
//--- file has been found - get its modified date
Mmc_Fat_Get_File_Date_Modified(&year, &month, &day, &hour, &minute);
UART1_Write_Text(" modified: ");
//--- get file size
fsize = Mmc_Fat_Get_File_Size();
LongToStr((signed long)fsize, outstr);
UART1_Write_Line(outstr);
else {
//--- file was not found - signal it
UART1_Write(0x55);
Delay_ms(1000);
UART1_Write(0x55);
// Tries to create a swap file, whose size will be at least 100
// sectors (see Help for details)
void M_Create_Swap_File()
unsigned int i;
size = Mmc_Fat_Get_Swap_File(5000, "mikroE.txt", 0x20); // see help on this function for details
for(i=0; i<512; i++)
f16_sector.fSect = i;
if (size) {
LongToStr((signed long)size, err_txt);
UART1_Write_Line(err_txt);
for(i=0; i<5000; i++) {
Mmc_Write_Sector(size++, f16_sector.fSect);
UART1_Write('.');
// Main. Uncomment the function(s) to test the desired operation(s)
void main()
#define COMPLETE_EXAMPLE // comment this line to make simpler/smaller example
//ANSELC = 0; // Configure AN pins as digital
//SLRCON = 0; // Set output slew rate on all ports at standard rate
// Initialize UART1 module
UART1_Init(19200);
Delay_ms(10);
UART1_Write_Line("PIC-Started"); // PIC present report
// Initialize SPI1 module
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
UART1_Write_Line("mmc initialised.");
//--- Test start
UART1_Write_Line("Test Start.");
//--- Test routines. Uncomment them one-by-one to test certain features
M_Create_New_File();
#ifdef COMPLETE_EXAMPLE
M_Create_Multiple_Files();
M_Open_File_Rewrite();
M_Open_File_Append();
M_Open_File_Read();
M_Delete_File();
M_Test_File_Exist();
M_Create_Swap_File();
#endif
UART1_Write_Line("Test End.");
else if(Mmc_Fat_Init() == 255)
UART1_Write_Line("memory card not found);
//UART1_Write_Line(err_txt); // Note: Mmc_Fat_Init tries to initialize a card more than once.
// If card is not present, initialization may last longer (depending on clock speed)
else if(Mmc_Fat_Init() == 1)
//UART1_Write_Line("boot sectror not found");
Mmc_Fat_Write(" End ", LINE_LEN-1); // write data to the assigned file
