Solving the charging problem for hybrids
Gurjap
@gurjap-blPmg9 โ€ข Oct 22, 2024
Even a Tesla roadster, today's most advanced and relatively popular completely electric vehicle needs at least 1 and a half hour to charge completely. This is a far cry indeed from refueling time needed for any conventional engine, which would be in mere minutes. This is a serious problem indeed, and not yet resolved.
Here is my question: can we feasibly use a whole array of batteries, each one of whom is small enough so it takes about a minute to recharge one on a household charging outlet, but the number of such batteries is large enough to drive an automobile for about a hundred miles on full charge? All these batteries would be simultaneously charged when the vehicle in plugged in, which means the whole array would be charged in about a minute.
Another question for the mechanical engineers: is it actually possible to design an automobile so its main battery is replacabe? I mean, that you could just replace a used battery with a charged one easily and quickly?
Note: my speciality being mechanical engineering, my knowledge of electrical engineering is rather basic.
    @ramani-VR4O43 • Mar 21, 2013
    The issue is power transfer. The time taken to put in X amphrs charge will be independent of whether it is one large battery of X capacity or 20 batteries of x/20 capacity for a given type of battery.
    There have been concepts describing changing a power pack at outlets. The problem has to do with life of batteries. If I pull in to a charging station with a brand new power pack needing to be charged, I may not be too keen on geeting a charged pack at the end of its life. This concept was proposed for power packs based on primary cells, which cannot be recharged. The chemicals can be recycled off line.
  • Gurjap
    @gurjap-blPmg9 • Mar 21, 2013
    Interesting argument about the charging time. This kinda crossed my mind too, and forgive me for being naive, but if we were to simply upgrade the voltage and amperage being applied to a battery, wouldn't that decrease the time require to charge it to a specified kwh rating?
    Also, an array of discrete batteries makes sense in another way: if a single battery malfunctions or is otherwise damaged, it would be easier to replace. Also, I believe (can't cite sources right now) lithium ion batteries last longer if they are discharged completely and then charged, as compared to charging them halfway depleted. Having an array would make it easy to discharge one cell completely, and then another, and so on.. And ensure better overall battery life.
  • lal
    lal
    @lal-R60Xjx • Mar 21, 2013
    Actually it is the NiCd cell that lasts longer if charged and discharged as you mentioned. Lithium batteries would provide a longer life if they are charged within 50% of their total capacity.
  • Gurjap
    @gurjap-blPmg9 • Mar 24, 2013
    I do believe you are right about that. Looks like recycling chemicals after, say, a hundred charges might just be our best bet.
    So, what other ideas on solving this problem?
  • Gurjap
    @gurjap-blPmg9 • Apr 4, 2013
    Following up on this thread: I did some research on charging batteries (Lead Acid ones, specifically) and as it turns out, you can't just ramp up the supply current while charging and hence reduce the time. It looks like doing that will only charge the electrolyte that is closest to the electrode and leave the rest as it is.
    So I am thinking, and forgive me if this sounds retarded to the electric experts, why not use some acid resistant pump to swirl around the acid while charging the battery? Would this reduce charging time?
    @ramani-VR4O43 • Apr 4, 2013
    Electrolyte cannot hold any charge. In a rechargeable battery a reversible reaction takes place. During discharge the reaction goes to a thermodynamically less energetic state. The heat of reaction is released as current through the external circuit. During charging the reverse reaction reproducing the original high energy state reactants takes place consuming theoretically the same amount of energy as released during discharge. In reality efficiency is less than 100% and so some energy is lost.
    If too high a charging current is used usually some other irreversible reaction also takes place, leading to products that do not revert. In lead acid batteries sulphation takes place. The lead sulphate cannot take part in the electrochemical reaction
    I am afraid that swirling the electrolyte around will not help much.
    There will be some benefit because the ions in the acid have to move by diffusion, which will be accelerated by the pumping action. If I can hazard a guess, the energy spent on the pump may not be recovered by the benefit accrued.
  • Gurjap
    A.V.RamaniElectrolyte cannot hold any charge. In a rechargeable battery a reversible reaction takes place. During discharge the reaction goes to a thermodynamically less energetic state. The heat of reaction is released as current through the external circuit. During charging the reverse reaction reproducing the original high energy state reactants takes place consuming theoretically the same amount of energy as released during discharge. In reality efficiency is less than 100% and so some energy is lost.
    Of course, I meant 'charge' in the general sense. Correcting my own words, only the electrolyte that is nearest to the electrodes would transform into a high energy state while charging at a high current rate.
    As for the energy loss, I suppose it cannot be helped.
    Good point about the energy efficiency. But maybe if the battery were to be large enough, or/and it were to use a gel electrolyte ..?
  • oprime
    @oprime-Myffqx • Apr 4, 2013
    #-Link-Snipped-# Check out this website - #-Link-Snipped-#
    This company swaps out depleted battery packs with fully charged batteries.
    @thebigk • Apr 4, 2013
    oprime#-Link-Snipped-# Check out this website - #-Link-Snipped-#
    BetterPlace is doing an excellent job and I think the technology they have've developed has a great chance of being adopted in a smaller sized country. Israel is very small in size and it's possible for the company to setup the battery changing station throughout the roads. But not an ideal solution in bigger countries - as the cost of setting up stations would be huge.
    PS: Just got nostalgic about my visit to Better Place -
    Kaustubh KatdarePhotos from the "Better Place" - the 100% electric car company -
    Better Place Car
    That's me, getting ready to accelerate!
    DrivingElectricCar
    What do you think, folks? ๐Ÿ˜
  • Gurjap
    @gurjap-blPmg9 • Apr 5, 2013
    A.V.RamaniI can hazard a guess, the energy spent on the pump may not be recovered by the benefit accrued.
    It just came to my mind: we are not hunting down efficiency while charging from an outlet, we are trying to reduce the charging time!
  • Gurjap
    Thank you for this reference. I did check it out.
  • Gurjap
    @kasturbh what was your overall "feel" of the company and its Oscar? How did the car handle? How was its noise, its acceleration? Did it have regenerative braking? How was the "feel" of the regen brakes?
    Aw man, I have a thousand questions. ๐Ÿ˜›
    @thebigk • Apr 5, 2013
    Gurjap@kasturbh what was your overall "feel" of the company and its Oscar? How did the car handle? How was its noise, its acceleration? Did it have regenerative braking? How was the "feel" of the regen brakes?
    The company is definitely doing a great job. I had never driven any electric car earlier so it was a pleasing experience for me. The car is of course totally noiseless and you won't know whether the car is on or not if the dashboard lights don't tell you.
    The acceleration was beyond impressive and it's expected because they've really amazing electric motors producing high torque. I couldn't get the technical details of the drive system though.
    The car performed well on turns and since we drove the car on the test track, we had to follow speed limits ๐Ÿ˜. The braking system was second to none. Overall I'd say the car would score above any IC engine any day.
    However, I think electric cars may not make it to India in sooner future. The distances we cover and the networks of charging station would prove to be a very costly affair. It's a great ride in the city though.
  • Gurjap
    @gurjap-blPmg9 • Apr 6, 2013
    You're a lucky guy. Mind me asking hiw you ended up in Israel in the first place? ๐Ÿ˜€
    @thebigk • Apr 8, 2013
    GurjapYou're a lucky guy. Mind me asking hiw you ended up in Israel in the first place? ๐Ÿ˜€
