Sms based query System
i want to make a based query system.
By Using which A user can:
Query Information
Modify his records.
So main Work of the application is going to be querying a database,formatting the result And sending it to the users
what tools will i need for this ? Do i need to purchase some Special SMS plan or i can simply use normal SMS plan.
And i am thinking of making this project with wcf so that any application can implement it.
    @thebigk Oct 11, 2015
    Depends on the level at which you wish to operate. You can build a prototype using your own mobile and computer. If it works; you may opt for a plan. There are pretty cheap bulk SMS plans available. I'd however recommend integrating with WhatApp. Text messages (SMS) are so 2009.
  • Jatin Kumar
    @jatin-SWWqiE Oct 12, 2015
    Kaustubh KatdareDepends on the level at which you wish to operate. You can build a prototype using your own mobile and computer. If it works; you may opt for a plan. There are pretty cheap bulk SMS plans available. I'd however recommend integrating with WhatApp. Text messages (SMS) are so 2009.
    Do you know how i can implement this?
