@thebigk • Mar 18, 2014
I guess because it includes the null at the end; the terminating \0. By the way the correct way to get the length of string would be strlen() and not sizeof(); because sizeof will return the length of the array, not the string.
C/C++ experts may offer better help.
PS: Been away from programming since eternity. -
@jason-IQjfPQ • Mar 18, 2014
The sizeof() function provides the size of the data type in bytes. The character array consist of a terminating character '\0' (hence name[5]='\0') (as told by #-Link-Snipped-# ) and since each char value occupies a space of one byte, hence the result is 6 ... 6 bytes.
And again as #-Link-Snipped-# said, if you want the length of the string use strlen() function. Then you would get the answer as 5. -
@shailaja-tiwari-lKhGjd • Mar 18, 2014
Yes it is the null character assumed to be appended at the end of the string ....
Aadit Kapoor OP
@aadit-kapoor-EBxnXT • Mar 18, 2014
Thank you friends!
