Simple explanation of Piezoelectric Effect
Tarun Goel
Tarun Goel
@tarun-TYZzQz Oct 26, 2024
Hello, I am Tarun and I am studying electronics engineering. I want to know what is the actual meaning of peizoelectric effect? Please explain it in simple words.
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Oct 9, 2012
    The tendency of generating charges when a force is applied on a crystal by external agents
  • Tarun Goel
    Tarun Goel
    @tarun-TYZzQz Oct 9, 2012
    Hey then why we don't adopt this tech. in metroes or railways or anywhere, by putting some crystals so that by the mechanical force of us during walking this produce charge and we can store this in some battery .
    OR we can simply use a MAT formed of crystals.
  • Jeffrey Arulraj
    Jeffrey Arulraj
    The cost and the power they generate are little below efficient
    They are under research and can be implemented in a small scale cause of the price tag they come with
    Additional circuitory is needed to amplify the power derived from the crystal these circuits consume almost 100 % of power generated by the crystals
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Oct 10, 2012
    Steven Brooks
    Hello Members,
    'Piezoelectricity' is the ability of certain crystals to produce a voltage when subjected to mechanical stress. Piezoelectric effect is the property of some materials to convert mechanical energy to electrical current.
    Thanks and Regards,
    Steven Brooks
    I think you are mistaken pal
    The current produced due to piezoelectric effect is called piezoelectricity and the ability of the crystal is called as piezo property and the process involved is called as piezoelectric effect
  • Henri
    Henri
    @henri-7eYVw8 Oct 10, 2012
    when pressure is applied on two crystals....a given amount of that pressure causes the generation of a small voltage,,,
  • Jeffrey Arulraj
    Jeffrey Arulraj
    Henri
    I getting a little confused her what do you mean
    Do you mean that a little of this pressure is converted into potential
  • Henri
    Henri
    Steven Brooks
    Hello Members,
    Thanks and Regards,
    Steven Brooks
    i think you are wrong...Piezzoelectricity has nothing to do with conversion of mechanical energy to electric current,And it only applies to crystals....plus instead of using the term mechanical stress which is broad..it would be better to say PRESSURE
    jeffrey samuel
  • Henri
    Henri
    it is not the pressure that
    jeffrey samuel
    is converted into electricity...the pressure causes movement of sub-atomic particles within the crystal structure,,,when a conductor is present...say a wire connected to a bulb from the two crystals....work is done to drive electrons through that conductor....causing somewat a p.d
    Ramani Aswath
    @ramani-VR4O43 Oct 10, 2012
    Steven is right.
    Some crystals when subject to a mechanical stress (squeezed) produce a voltage. Conversely if a voltage is applied to these crystals there will be a mechanical distortion.
    The first effect is used in piezoelectric devices like a gas lighter. When you push the plunger a spring releases the push energy in a sudden kick which produces the spark that lights the gas. The same effect is used in many other devices as well.
    The reverse effect is used for generating ultrasound. When an ultra sound frequency voltage is applied to the crystal it starts vibrating mechanically at that frequency producing ultra sound.
  • Henri
    Henri
    @henri-7eYVw8 Oct 12, 2012
    bioramani
    Steven is right.
    when subjected to stress,,,,well according to Steven..it is that mechanical force that is converted to voltage...i think that is wrong
    Ramani Aswath
    @ramani-VR4O43 Oct 12, 2012
    Henri
    Nothing wrong in that. When a crystal is distorted the change in the shape of the constituent unit cells changes the charge separation distance, which appears as a change in the surface charge. Conversely if a voltage change is applied to the crystal it deforms mechanically, which is how an ultrasonic transducer works.
  • Henri
    Henri
    bioramani
    bioramani...i see what you mean...but don't you think its far-fetched?
    Ramani Aswath
    Henri
    I am sure that you have used gas lighters, where you push a lever on top. The lever moves slowly and then there is a sudden jerk with a spark coming between the bottom two electrodes. This is because of this effect.
    [​IMG]
    <a href="https://en.wikipedia.org/wiki/Gas_lighter" target="_blank" rel="nofollow noopener noreferrer">Gas Lighter</a>
  • Henri
    Henri
    @henri-7eYVw8 Oct 14, 2012
    haha....100
    bioramani
    [​IMG]
    hahaha...100% agreement with you
