@thebigk • Dec 29, 2011
deeptijaipur1987hello ,......i m learning vbscript through net..........i just running a html embedded vbscript prog to print hello world but it is not showing output........even my browser is IE.........reply me pleaseโ
Why not share your code here?
@kr-at-nsngu-XqzcfU • Dec 29, 2011
Which IDE you are using ????
Are you getting the o/p window ?
May be the installation not completed successfully... -
@deeptijaipur1987-XKeG3E • Dec 30, 2011
The_Big_KWhy not share your code here?
this is the code..............
<html>
<body>
<script type="VBSCRIPT">
document.write("This is my first VBScript!")
</script>
</body>
</html> -
K!r@nS!nguWhich IDE you are using ????
May be the installation not completed successfully...i have internet explorer......................nothing install........i also have mozilla...............it shows output window ........corect path at URL.........but not display output inside vbscript.........code is
<html>
<body>
</script>
</body>
</html> -
h
May be the installation not completed successfully...um
what should i install..............i have nothing install.............simply write cod at notepad save as .html////////////
<html>
<body>
</script>
</body>
</html> -
@kr-at-nsngu-XqzcfU • Dec 30, 2011
deeptijaipur1987h
um
<html>
<body>
</script>
</body>
</html>no need to install anything....
are you getting any pop-up like "pop-up blocked" allow pop-ups now.
go to tools->Internet options->Privacy tab->uncheck allow pop-up -
th
K!r@nS!nguno need to install anything....
thanku ,..................my atleast one code is shown output..............thanku very much -
deeptijaipur1987th
thanku ,..................my atleast one code is shown output..............thanku very muchWhy not ?? try one more program you will get o/p for sure...๐
@manishks-AZybhs • Dec 31, 2011
yeah theres nothing to install....just save thd file with .html extension...
@praveenkumar-66Ze92 • Jan 5, 2012
Guys... Its MsgBox not document.write. document.write is JavaScript!
