Random Access Memory
Amit kumar Gupta
@amit-kumar-gupta-UfFe2p โ€ข Oct 25, 2024
Random-access memory (usually known by its acronym, RAM) is a form of computer data storage. Today, it takes the form of integrated circuits that allow stored data to be accessed in any order (i.e., at random). The word random thus refers to the fact that any piece of data can be returned in a constant time, regardless of its physical location and whether or not it is related to the previous piece of data.
Modern types of writable RAM generally store a bit of data in either the state of a flip-flop, as in SRAM (static RAM), or as a charge in a capacitor (or transistor gate), as in DRAM (dynamic RAM), EPROM, EEPROM and Flash. Some types have circuitry to detect and/or correct random faults called memory errors in the stored data, using parity bits or error correction codes. RAM of the read-only type, ROM, instead uses a metal mask to permanently enable/disable selected transistors, instead of storing a charge in them.
"I got this information from WIKIPEDIA"
www[dot]joshforce[dot]blogspot[dot]com
  • Amit kumar Gupta
    @amit-kumar-gupta-UfFe2p • Sep 13, 2009
    can anyone tell me exactly about the DDRAM ,SDDRAM ,TTRAM and ZRAM ???
    #-Link-Snipped-#[dot]joshforce[dot]blogspot[dot]com
    @thebigk • Sep 13, 2009
    Amit - copy pasting information from the web won't help. You need to initiate discussions.
