Question about measuring power dissipation
I am using a single pole double throw switch IC for switching applications (part number ADG436) for battery powered applications. I am trying to measure the power dissipation for this device, and did it by simply just connecting the power supply to the VDD and GND and using an ammeter to measure the current on it. However, no values came up on the ammmeter. Isn't this the way to go in measuring power dissipation?
Or since this is a switch IC, should I be measuring the source and drain terminals instead?
Also, do you guys think power dissipation of the chip itself will change if I use a virtual ground setup to set up a +/- voltage rail using a single supply for this chip?
Thanks for all your help.
Feel free to leave comments and/or suggestions!
