PSNR code in java not working plzz help
zion
@zion-6KgmEO โ€ข Oct 26, 2024
It is psnr code that is not working ..can someone help plz
import java.io.*;
public class Psnr {
  public static double log10(double x) {
    return Math.log(x)/Math.log(10);
  public static void main (String[] args) {
    int     nrows, ncols;
    int     img1[][], img2[][];
    double  peak, signal, noise, mse;
    if (args.length != 4) {
      System.out.println("Usage: Psnr <nrows> <ncols> <img1> <img2>");
      return;
    nrows = Integer.parseInt(args[0]);
    ncols = Integer.parseInt(args[1]);
    img1 = new int[nrows][ncols];
    img2 = new int[nrows][ncols];
    ArrayIO.readByteArray(args[2], img1, nrows, ncols);
    ArrayIO.readByteArray(args[3], img2, nrows, ncols);
    signal = noise = peak = 0;
    for (int i=0; i<nrows; i++) {
      for (int j=0; j<ncols; j++) {
        signal += img1[I][j] * img1[I][j];
        noise += (img1[I][j] - img2[I][j]) * (img1[I][j] - img2[I][j]);
        if (peak < img1[I][j])
          peak = img1[I][j];
    mse = noise/(nrows*ncols); // Mean square error
    System.out.println("MSE: " + mse);
    System.out.println("SNR: " + 10*log10(signal/noise));
    System.out.println("PSNR(max=255): " + (10*log10(255*255/mse)));
    System.out.println("PSNR(max=" + peak + "): " + 10*log10((peak*peak)/mse));
    @anoop-kumar-GDGRCn • Mar 26, 2014
    Did you copied this code from somewhere??
    Clearly ArrayIO is not from standard Java library. You need to find out which library to use.
  • zion
    @zion-6KgmEO • Mar 26, 2014
    yeah ..copied it ..
  • VimleshMishra
    @vimleshmishra-rWc8Yv • Mar 26, 2014
    zion as anoop told ArrayIO is not from standard java library which giving error while compilation try below link #-Link-Snipped-#
