POI API Implementation problem
Vishal Sharma
Vishal Sharma
@vishal-pysGmK Oct 26, 2024
hi..
I'm trying to read a .docx file using apache poi api methods.. But i'm facing a few problems..
Can anyone suggest me the changes to be made in this code??
    package apiole;
    import java.io.*;
    import org.apache.poi.xwpf.extractor.XWPFWordExtractor;
    public class Apiole {
    public static void main(String[] args) throws IOException {
    File f = new File("D:\\vishal\\java_projects\\doc.docx");
    InputStream in = new FileInputStream(f);
    String test = extractText(in);
    System.out.print("text: "+test);
    public static String extractText(InputStream in) {
    XWPFDocument doc = new XWPFDocument(in);
    XWPFWordExtractor ex = new XWPFWordExtractor(doc);
    String text = ex.getText();
    return text;
  • Vishal Sharma
    Vishal Sharma
    @vishal-pysGmK Feb 19, 2013
    no response??? 😲
    anyway, problem solved...........
    @thebigk Feb 19, 2013
    Vishal0203
    no response??? 😲
    Why not share the answer so that others who're facing the problem will know how to solve it? 😀
    I'm sorry to hear that the question didn't get any response.
  • Vishal Sharma
    Vishal Sharma
    The_Big_K
    Okay!!
    So, the above program doesn't work because I've not imported another archive..
    import org.apache.poi.xwpf.usermodel.XWPFDocument;
    this is present in poi-ooxml-....-.jar (not mentioning the full name, its big 😛 )
    you need to add this archive in the library (I used netbeans) as a part of project.
    This is the basic thing.. and the code that works fine is as below!
    package apiole;
    import java.io.*;
        public static String extractText(InputStream in) throws IOException {
        return text;
