@silverscorpion-iJKtdQ • Dec 6, 2010
Re: Calling all CE's - Explain this!!
Hmm, yeah. Interesting paradox!!
I know of a way to explain this.. I'll wait for other explanations before giving mine!! ๐๐ -
@thebigk • Dec 6, 2010
I've a problem with the 'Repeat To Infinity' part. It's still zig-zag and can never be a circle.
@gohm-F3UUpP • Dec 6, 2010
Biggie is correct
Yes. This arises due to the difference between countably infinite and uncountably infinite points..
In case of removing corners from a square, even after infinite iterations, only a finite number of points of the square will be on the circle.
But a circle has infinite number of points.
So, even at infinity, the square with corners removed will approach a circle, but never rally become a circle.
So, we can say that after infinite iterations, maybe, the area of the two curves are equal. ie., the square converges to a curve with the same area as the circle, but their perimeters are still different. -
@makru921-Am65Ah • Dec 6, 2010
Biggie, repeating to infinity means considering that a circle is made of zig zag lines with infinitesimally small length. We can counter the paradox by stating that a circle has infinite points and after infinite iterations the area might become equal to that of the square, like silverscorpion did. However it is quite possible to imagine that a circle is formed by such very small lines. In that case, the paradox wins! I tried to convince myself that this is impossible but the thought of that possibility remains.. It is really scary!
Consider this -
1) /\/\/\/\/\/\/\/\/\/\/..... (infinity)
2) ------------------.....(infinity) [Consider this as a continuous line ๐ ]
The first zig-zag line is almost twice (just an approximation) that of straight line #2 for any section cut at equal distance from the start point.
If I make the first line small enough, still maintaining the zig-zag nature; the length will still be twice that of line 2. That's exactly I meant. Even if you go about infinity - it will NEVER be a 'straight' line; thus these two lines can never be of the same length.
![[โIMG]](proxy.php?image=http%3A%2F%2Fcheezfailbooking.files.wordpress.com%2F2010%2F11%2Fmemebase.jpg%3Fw%3D350&hash=69d98131995fe5b5b3f2ef20e8458043)
