@thebigk • Aug 25, 2009
@itchap-RKJQDB • Aug 25, 2009
// Using friend functions to
// overload addition and subtarction
// operators
#include <iostream.h>
class myclass
int a;
int b;
public:
myclass(){}
myclass(int x,int y){a=x;b=y;}
void show()
cout<<a<<endl<<b<<endl;
// these are friend operator functions
// NOTE: Both the operans will be be
// passed explicitely.
// operand to the left of the operator
// will be passed as the first argument
// and operand to the right as the second
// argument
friend myclass operator+(myclass,myclass);
friend myclass operator-(myclass,myclass);
myclass operator+(myclass ob1,myclass ob2)
myclass temp;
temp.a = ob1.a + ob2.a;
temp.b = ob1.b + ob2.b;
return temp;
myclass operator-(myclass ob1,myclass ob2)
myclass temp;
temp.a = ob1.a - ob2.a;
temp.b = ob1.b - ob2.b;
return temp;
void main()
myclass a(10,20);
myclass b(100,200);
a=a+b;
a.show();
}I think you are asking about operator overloading program in C++ using friend function.
From now onwards please give the exact details about your query. -
namivrm OP
@namivrm-w4iQGm • Aug 26, 2009
thanks... cn u hlp me in opereator overloading usng member function...
@itchap-RKJQDB • Aug 26, 2009
namivrmthanks... cn u hlp me in opereator overloading usng member function...
Yeah I can help you but first of all stop using this sms text in your posts anywhere on CE.
Now tell me what do you want to know about operator overloading using member function..
Overloading operators using a member function is very similar to overloading operators using a friend function. When overloading an operator using a member function:
The leftmost operand of the overloaded operator must be an object of the class type.
The leftmost operand becomes the implicit *this parameter. All other operands become function parameters.
Most operators can actually be overloaded either way, however there are a few exception cases:
If the leftmost operand is not a member of the class type, such as when overloading operator+(int, YourClass), or operator<<(ostream&, YourClass), the operator must be overloaded as a friend.
The assignment (=), subscript ([]), call (()), and member selection (->) operators must be overloaded as member functions.
Overloading the unary negative (-) operator
The negative operator is a unary operator that can be implemented using either method. Before i show you how to overload the operator using a member function, hereโs a reminder of how to overloaded it using a friend function:
class Cents
private:
int m_nCents;
public:
Cents(int nCents) { m_nCents = nCents; }
// Overload -cCents
friend Cents operator-(const Cents &cCents);
// note: this function is not a member function!
return Cents(-cCents.m_nCents);
}Now letโs overload the same operator using a member function instead:
class Cents
private:
int m_nCents;
public:
// Overload -cCents
Cents operator-();
// note: this function is a member function!
Cents Cents:: operator-()
return Cents(-m_nCents);
}Note that this method is very similar. However, the member function version of operator- doesnโt take any parameters.A member function has an implicit *this pointer which always points to the class object the member function is working on. The parameter we had to list explicitly in the friend function version (which doesnโt have a *this pointer) becomes the implicit *this parameter in the member function version.
Remember that when C++ sees the function prototype Cents Cents:๐ฒperator-();, the compiler internally converts this to Cents operator-(const Cents *this), which you will note is almost identical to our friend version Cents operator-(const Cents &cCents)! -
@saandeep-sreerambatla-hWHU1M • Aug 26, 2009
Itchap good programs ๐
A small suggestion dont give all the codes let people try themselves.
Mr.namivrm I hope you are not using these codes for your assignments!!! -
English-ScaredItchap good programs ๐
Mr.namivrm I hope you are not using these codes for your assignments!!!Ok i will take care of that.๐
namivrm OP
@namivrm-w4iQGm • Aug 27, 2009
hey... i'll nt use dis code in my assignments.... i had doubt... thanks for ur help....
@thebigk • Aug 27, 2009
namivrmhey... i'll nt use dis code in my assignments.... i had doubt... thanks for ur help....
Please refrain from using SMS text in your posts on CrazyEngineers.
