@Ash • Nov 30, 2007
Hm, I've never used an ICD before. Im not too familiar with MPLAB too cause I've used another compiler.. though I believe MPLAB is a kick ass program anyway. Does the ICD have an ICSP function to flash the PIC? If you have sucessfully compiled the c code, you should be able to find it's HEX file. All you need to do is download (or is it upload?) this into you PIC. Try looking through the manual of MPLAB v5.40 to see the instructions, since only this version is compatible with the ICD1, right?
preeste OP
@preeste-Q3d5XK • Dec 5, 2007
hey....sory for the delay...yeah thats right...mplab v5 is the only one that supports the icd1. i could find the hex file, the problem though is once its downloaded you cannot actually hit the run button...it was all really weird...going to leave it for a while though....really busy at work.
Ash i need to thank you once again for all your help....it really was priceless and i cant ever tell you how helpful it was.
this site rocks!!!!! -
@Ash • Dec 5, 2007
No problemo.. glad to help! Well, usually once you download the HEX, the code will run immediately. It was quite a revelation to me when we tested our motors.. the robot almost drove off the table, tangling the serial cable attached to it, haha.
preeste OP
that must have been a great feeling....well tons better than just gawking at your motor hopin it would move if you stared hard enough! .....anyways later
