@thebigk • Jul 30, 2012
Welcome to CE, friend. We're happy to have you with us. Hope to see you active here. Explore our Mechanical Engineering section and post your ideas there.
@ramani-VR4O43 • Jul 30, 2012
IR rain sensors are already in the market and in use for closing sliding roofs and such when it rains. They can easily be used for your application.
You can easily integrate this with a photo resistor with a suitable grey filter to do the same when the incident sunlight is above a designed value.
Something on these lines:
@harshad-ukH5ww • Jul 30, 2012
Welcome to CE. Now you have reference design start working buddy.
@zaveri-5TD6Sk • Aug 1, 2012
imhomohneed any assist to achieve these
welcome dude. come to the mechanical section and explain your problem in detail.
@kedar-crbktt • Aug 3, 2012
Welcome to CE!
Lot's more to explore in mechanical section! -
@kn081993-bzlfx7 • Jul 20, 2016
can anybody give the correct answer of this question?
in a particular arc welding operation 5 mm thick steel plate require 40 A current , what should be the current requirement for welding 10 mm thickness plate?
a) 10 A
b) 20 A
c) 60 A
d) 160 A
pls answer -
@ramani-VR4O43 • Jul 20, 2016
<a href="https://www.mig-welding.co.uk/arc-flat-joints.htm" target="_blank" rel="nofollow noopener noreferrer">Arc (MMA) Welding Flat Joints</a>
sir i watched this topic but i am not getting any help ..i m not getting any formula for answer of this question..pls help...
There cannot be a formula as such. The heat transfer during welding is far from steady state. Too many factors are involved. Thickness is only one. The practice is to start with a smaller current and increase it gradually till a satisfactory weld is got.
My knowledge in welding is very limited and non structural. -
ok sir
@azar-YZifUn • Aug 19, 2016
kn081993can anybody give the correct answer of this question?
a) 10 A
b) 20 A
c) 60 A
d) 160 A
pls answerC)60
