MATLAB Problem
sindhya
@sindhya-OYYUXw โ€ข Oct 24, 2024
I have a 400 by 640 matrix of ones and zeros. The zeros are near each other and I want to know if there is a function by which i can find the index of the middlemost zero in each column.
For example if in the first column, the entries are
1
1
1
1
the middlemost zero is in the 6th row and i want to get the number 6. please help me with this.
  • Predictor
    @predictor-lfVrRm • Apr 5, 2009
    sindhyaI have a 400 by 640 matrix of ones and zeros. The zeros are near each other and I want to know if there is a function by which i can find the index of the middlemost zero in each column.
    1
    1
    1
    1
    For each column:
    S =
    1
    1
    1
    1
    >> find(S == 0)
    ans =
    4
    5
    6
    7
    8
    >> median(find(S == 0))
    ans =
    6
    Note that if there are an even number of zeros, the median will include a fractional part, 0.5. Use round, ceil, etc. to fix this.
    -Will Dwinnell
    <a href="https://matlabdatamining.blogspot.com/" target="_blank" rel="nofollow noopener noreferrer">Data Mining in MATLAB</a>
  • silverscorpion
    @silverscorpion-iJKtdQ • Apr 5, 2009
    The above method is correct.
    Btw, it should be noted that it will only work if all the zeros occur continuously, and they occur in the middle of the sequence.
  • Predictor
    silverscorpionThe above method is correct.
    Btw, it should be noted that it will only work if all the zeros occur continuously, ...
    Yes, although I assumed this was the case, given this phrase in the original post: The zeros are near each other
    silverscorpion... and they occur in the middle of the sequence.
    I don't believe that this is a necessary condition for my suggestion to work:
    S =
    1
    1
    1
    1
    ans =
    3
    -Will Dwinnell
