@silverscorpion-iJKtdQ • Feb 7, 2009
what exactly do you want? code for noise generation or noise removal..
As to jammers, it's very easy. if you know the frequency you want to jam, you can generate some random signal of that frequency and greater amplitude. That's it.
If you dont know the frequency, then it becomes somewhat more difficult. Then you have to use hardware also. It cant be done only with matlab code. ie, use your receiver and receive the signal. know the frequency components in it and then generate that frequency. Clear? -
@vila-4EJWAr • Feb 8, 2009
Hii,
I need matlab codes for noise generation and also codes for broadband noise jammer.
Thank you... -
@silverscorpion-iJKtdQ • Feb 8, 2009
hey you!
I just answered your question and you are reposting the question again. I'll again tell you, we dont give you the code here. You do the code, if there are any problems, we'll be happy to help. -
@durga-TpX3gO • Feb 8, 2009
VilaHii,
Thank you...what type of noise are you refering to?
gaussian? -
Hiii,
Gaussian, AWGN or Broadband noise, either one can do..
Thank you. -
Hiii,
Mmm well i have some codes here, its shows errors. to whom i have to show them to get rectified? Do i just post the codes here?
Thank you. -
just post that section of the code which has errors in it. Or if it's ok for you, posting the full code is no harm, either.. Post it in this thread itself.
@durga-TpX3gO • Feb 9, 2009
VilaHiii,
Thank you.If your matlab has communications tool box, you have function 'awgn' which generated white gaussian noise and adds it to your signal depending on the impedance and nosie DB
may be you can search the 'help ' section in your matlab for 'awgn' command
for more infomration you can as well refer to the MATLAB help link
#-Link-Snipped-# -
@vila-4EJWAr • Feb 9, 2009
This program should show the effect of Gaussian filter.
%%%%%%%%%%%%% The main.m file %%%%%%%%%%%%%%%
clear;
% Parameters of the Gaussian filter:
n1=10;sigma1=3;n2=10;sigma2=3;theta1=0;
% The amplitude of the noise:
noise=0.1;
[w,map]=gifread('lena.gif');
x=ind2gray(w,map);
filter1=d2gauss(n1,sigma1,n2,sigma2,theta);
x_rand=noise*randn(size(x));
y=x+x_rand;
f1=conv2(x,filter1,'same');
rf1=conv2(y,filter1,'same');
figure(1);
subplot(2,2,1);imagesc(x);
subplot(2,2,2);imagesc(y);
subplot(2,2,3);imagesc(f1);
subplot(2,2,4);imagesc(rf1);
colormap(gray);
%%%%%%%%%%%%%% End of the main.m file %%%%%%%%%%%%%%%
When i tried to run them, it shows this error message:
Error in ==> gaussian at 7
Thanks for helping...
These are another set of codes in which it should display Rayleigh function graph:
%Initialization D=1 (D = interleaving depth)
clear;
Ts=1/1e3; % tx rate = 10k bps
NA=10000;
A=floor(rand(1,NA)+0.5);
%A=randint(1,NA);
input=A;
G=[1 0 0; 1 0 1; 1 1 1];
k=1;
N=length(channel_output);
SNRdB= -10:5:20;
SNR=10.^(SNRdB/10);
Counter=zeros(1,length(SNRdB));
loop=0;
% AWGN + fading *
Fd=66; % Actual fading rate
fm=round(Fd*NA*Ts);
%Generate two inputs of 1 x N matrix
xin=randn(1,(NA+2)*3);
yin=randn(1,(NA+2)*3);
%Loop for all values of frequencies and truncate at just before f=fm
for f=1๐fm-1)
filter(f)=1.5/(pi*fm*sqrt(1-(f/fm)^2));
end
for f=(fm-1)๐NA+2)*3
filter(f)=0;
end
%Inputs of the filter is multiplied with the filter transfer function
xout=xin.*filter;
yout=yin.*filter;
%Perform inverse Fourier Transform on both output
xifft=real(ifft(xout));
yifft=real(ifft(yout));
% normaliation so that E{R^2}= 1 / in Watt = 0 dB
std_x=std(xifft);
std_y=std(yifft);
xifft=xifft/std_x/sqrt(2);
yifft=yifft/std_y/sqrt(2);
%Sum the square the of the IFFT and take the square root of it
rx=sqrt(xifft.^2+yifft.^2);
%Calculate for all value of SNRdB in AWGN + fading
loop=0;
for b=sqrt(SNR) %b is the signal level
loop=loop+1;
dfad=0;
for n=1๐NA+2)*3 %n = no of bits
x=randn;
t=channel_output(n);
if t>=0.5
a=b*rx(n);
r=a+x;
if r<0
dfad=dfad+1; % error has occured, increase counter
Df(n)=0;
else
Df(n)=1;
end
else
a=(-b)*rx(n);
r=a+x;
if r>0
dfad=dfad+1;
Df(n)=1;
else
Df(n)=0;
end
end
Counterf(loop)=dfad; % w/o decode
end
output=viterbi(G,k,Df); % E is output of decoder
zf=0;
v=1;
for v=v:1:length(A);
if xor(input(1,v),output(1,v))==1
zf=zf+1;
end
end
Counter_wcf(loop)=zf;
end% loop for signal (b) in AWGN + fading
%plot simulation in AWGN + fading without coding
Pef=Counterf/N;
%semilogy(SNRdB,Pef,'b');
%hold on;
%plot simulation in AWGN + fading with coding
Pe1f=Counter_wcf/NA;
save D1_66SNRdBPe1fPef
%semilogy(SNRdB,Pe1f,'b'); %D=1 no interleaving
%hold on;
but when i tried running them, it shows this error message:
Error in ==> Rayleigh at 12
Please help me..thank you
@silverscorpion-iJKtdQ • Feb 9, 2009
In the first piece of code, try using imread() instead of gifread(). I'm not sure if a function gifread() to specifically read gif files exist.
In the second piece of code, you dont seem to have defined what is 'channel_output'. you have used channel_output as a function in the later part of the code, and in the top part, you have tried to find the length of a function. That might be the problem. -
I dotn see channel_output being defined. Did yu put up the whole code mate?
@vila-4EJWAr • Feb 10, 2009
It gives the same error even if i use imread() instead of gifread()
Yes whole code mate, how do i define the channel_output then? -
@durga-TpX3gO • Feb 10, 2009
Hi
clear;
NA=10000;
%A=randint(1,NA);
input=A;
k=1;
SNRdB= -10:5:20;
SNR=10.^(SNRdB/10);
loop=0;
if ts is your transmitted signal then your channle output should be a convolution of you input signal and noise.
ie your channel output should be on lines of
output = H * input;
where H is is your channel matirx and inout in Tx -
@vila-4EJWAr • Feb 11, 2009
Hiii thanks a lot,
Now i have a set of coding over here but i dont know how to determine which one is the information signal and which one is the carrier signal, wheter xin, yin, xout or yout..and what is NA?
clear;
NA=1000;
%A=randint(1,NA);
input=A;
G=[1 0 1 1 0 1 1; 1 1 0 0 1 0 1; 1 1 1 1 1 0 1];
%G=[1 0 0; 1 0 1; 1 1 1];
k=1;
channel_output=cnv_encd(G,k,A);
SNRdB= -10:5:20;
SNR=10.^(SNRdB/10);
loop=0;
L_one=length(G)-1;
no_rows=size(G,1);
encoder_output_bits=(NA+L_one)*no_rows;
% AWGN + fading *
Fd=2000; % Actual fading rate
fm=round(Fd*NA*Ts);
xin=randn(1,encoder_output_bits);
yin=randn(1,encoder_output_bits);
for f=1๐fm-1)
end
for f=(fm-1):encoder_output_bits
filter(f)=0;
end
xout=xin.*filter;
yout=yin.*filter;
std_x=std(xifft);
std_y=std(yifft);
plot(xout);
plot(yout);
Thank you mate...
@durga-TpX3gO • Feb 11, 2009
VilaHiii thanks a lot,
NA=1000;
%A=randint(1,NA);
input=A;
k=1;
hmm, tell me one thing has this code been picked off from the net?
anyways
A is your input signal. it s a randaom signal generated. NA can be any number and you rand 1,1000 .
and your G is the convoluional encoder in polynomial representation -
@vila-4EJWAr • Feb 12, 2009
Hiii...yes its from the net...if A is the input signal then how about xin and yin?
@stylishdudevicky-fqNdGH • Mar 22, 2010
Hi,
I know few people who can write any Matlab or programming codes as a pay service. contact them at #-Link-Snipped-#
Hope this helps. -
@robben71-70AYpV • Apr 5, 2011
Hi, does anyone have code for gray world and white point (image processing)?
@krishtce-mmP8lu • Feb 17, 2015
Hi...... i need the verilog code for generating jamming signal......... can anyone tell me the logic for generating???
@danish-salim-soonka-BIWksP • Aug 20, 2016
i need to implement a jammer model can anyone help?
