material sought
harshinde
@harshinde-Hv4Q9E Oct 25, 2024
I'm a electronic student and im working on a project which requires a material which could rapidly heat and cool to a preset temperatures( around 35C-39C) the time limit on heating and cooling to be around 1 to 2 seconds.
i would be grateful if some one could help me out in this regard....
  • harshinde
    @harshinde-Hv4Q9E Mar 1, 2009
    im an electronic student and im working on a project which requires a material which heats and cools rapidly to preset temperatures( around 35C to 39C) the time limit being 1 to 2 seconds... i would be grateful if someone could help me in this regard..
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M Mar 2, 2009
    harshindeim an electronic student and im working on a project which requires a material which heats and cools rapidly to preset temperatures( around 35C to 39C) the time limit being 1 to 2 seconds... i would be grateful if someone could help me in this regard..
    what is the temperature limit you want to heat that material ?
    what is the procedure of heating the material?
  • gohm
    @gohm-F3UUpP Mar 2, 2009
    Also, does it need to be a solid?
  • KINETIC_JOULES
    @kinetic-joules-Qk9kmk Mar 2, 2009
    Can you please specify what you will be using to heat this material?
  • harshinde
    @harshinde-Hv4Q9E Mar 2, 2009
    Material required
  • gohm
    @gohm-F3UUpP Mar 3, 2009
    Re: material reqdf
    Please do not multiple post. How about answering the couple questions members had posted on your original thread? That way we can help you better get your answer.
  • harshinde
    @harshinde-Hv4Q9E Mar 3, 2009
    Re: material reqdf
    sorry, but the link didn directly connect me back to the thread stating technical difficulties, so re-posted the thread.
    we plan to heat the material by differential passage of current through it. and as posted above we need to heat the material to preset temperatures 34C - 39C.
    one of my friends suggested silver as a material which could be used, is that possible??
  • gohm
    Re: material reqdf
    Sure, many of the precious metals are molten in that way, it is very efficient. A coreless induction furnace. The electromagnetic field in the coil not only melts but stirs the molten metal. Then there are electrc arc furnaces, these expose the material directly to the charge. Silver melts at 960 degrees celsius.
    You might be better served to have this thread merged into the previous in the metallurgy forum.
  • morganparkar
    @morganparkar-wuhi5a Mar 24, 2009
    Hi Friend,
    Material sought is not a part of temperatures heat and coll at present so the limit of it is fixed about material. So, we can't do this types of thing in material sought.
    Thanks
  • harshinde
    @harshinde-Hv4Q9E Mar 24, 2009
    ohk, considering the fact that the material for the preset temperatures which we want would not be available in the market, we would like to know if there is a device or a circuit which would heat the material to the same required temperatures..i.e. 35C as the lower limit and 39C as the upper limit.
    we have considered using silver as the material and would be grateful if someone could suggest any reference for the same above....
  • g_rakesh2
    @g-rakesh2-CVEauh Apr 1, 2009
    you can use circuit breakers which will cut off the current when temp rises above 39c.
  • harshinde
    @harshinde-Hv4Q9E Apr 2, 2009
    yes we tried looking up for the same, but the problem here is that we need a circuit which is as small as possible; the size preferable in one or two centimeter
