Linux Problem
raj87verma88
@raj87verma88-ZpL2Wn โ€ข Oct 26, 2024
I tried to upgrade using
sudo apt-get upgrade
sudo apt-get update
but it showed the error
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
Tried using add/remove application but got the same error
ran : dpkg --configure -a
but then this message comes: dpkg: requested operation requires superuser privilege
This is driving me crazy
P.S. I am using Ubuntu 8.04 (Hardy Version)
  • raj87verma88
    @raj87verma88-ZpL2Wn • Jun 23, 2008
    when I am trying to update or install anything new then i get this error
    E: _cache->open() failed, please report.
  • Ashraf HZ
    @Ash • Jun 23, 2008
    When you say you tried using the add/remove application, do you mean the Synaptic one? What are package planning to download?
    I think you need to be logged in as "root" to use this command:
    "dpkg --configure -a"
    [EDIT]
    Try:
     sudo dpkg --configure -a
