linked list in C II
durga ch
durga ch
@durga-TpX3gO Oct 22, 2024
ok,,
I have seomthing of this format
this represents my node format, and I have another structure defined within this struture and say one of the declarations of the structure xyz is int k
As far as i remember C , I can call the value of the variable k as below right?
typedef struct
struct xyz
} node ;
node ->xyz.a ?
  • pradeep_agrawal
    pradeep_agrawal
    @pradeep-agrawal-rhdX5z Jun 19, 2009
    @Durga, few corrections.
    The declaration that you have done is declaration of a new data type and not a variable (as you are using typedef). Also it has some syntax errors.
    If we have to define a struct x which contains variable var_y of another struct y which itself contains a variable int z, then the declaration will look like:
    struct x {
      struct y {
        int z;
      } var_y;
    or
    struct y {
       int z;
    struct x {
      struct y var_y;
    The point to note in first case is that if you declare only struct and not a variable of that struct, compiler will throw a warning that the declaration does not declare anything. Also logically such declaration does not make sense.
    A variable of struct x can be declared as:
    struct x var_x;
    And the internal variable z can be accessed as:
    var_x.var_y.z.
    Please refer below example for the details specified above:
    #include "stdio.h"
    struct x {
      struct y {
        int z;
      } var_y;
    int main() {
      struct x var_x = { 0 };
      printf("z = %d\n", var_x.var_y.z);
      return 0;
    -Pradeep
  • durga ch
    durga ch
    @durga-TpX3gO Jun 21, 2009
    ahem!Thanks!
    My deadline has passed for project and I am not done with it, I submitted a project which is 80% done. Planning to resume it in holidays as a learning program, so I will pop up with many such syntax related questions 😉
    thanks again
